Interactive Custom Door Panels
Go Back   S-10 Forum > General Tech > S-Series How-To > Interior How-To
Old 03-21-2002, 03:44 PM   #1
Self Portrait
rhenry01's Avatar
Post Interactive Custom Door Panels
OK First Gen'ers, when I bought my truck used there was an unidentifiable substance in the bottom of the map pockets that had successfully chemically bonded some pennies to the bottom of the pockets. Since they have that fuzzy stuff on them cleaning them was almost out of the question. Besided, my wife think that they make excellent junk collectors! Well I'm doing away with the pockets and I'm going to be doing it as inexpensively as possible. I am going to be taking lots of pictures so I'll post them here so you all can follow along. This is interactive so if you have any questions or comments, fire away.
The first thing that you will need is 18 (9 each side) of the plastic panel retainers as you are going to break them taking the door panel off. I paid $.35 each for them at a local auto upholstery place.
Old 03-21-2002, 03:52 PM   #2
Long Bed Member
92S10LB's Avatar
HAHAHAA! but yea id like to know mine are useless and have pennies stuck in them too (hmmmm factory option maybe?) so keep us posted
Old 03-21-2002, 03:52 PM   #3
Self Portrait
rhenry01's Avatar
Pull off the door panel!
Take the two screws out of the door handle. If you have manual windows you have to get the window cranks off too, this requires a special tool, but while your at the upholstery shop ask them if they would pop them off for you real quick....don't forget to tip the guy is he doesn't charge you! (tips count, you'd be suprised how fast I get helped at the shop I go to!!!) Now just pull the panel away from the door frame. If you have power windows be careful of the up/dn switch wire the wire is attached to the door and the switch is attached to the door panel. Once you have poped all the plastic retainers lift up on the panel and it comes right off.....remember there 9 per door.
Old 03-21-2002, 04:01 PM   #4
Self Portrait
rhenry01's Avatar
Talking Peel Off the carpet and take the carpet backer off!
LAy your door panel on a solid work surface. Grab that nasty carpet that covers the map pocket at one corner and pull it off the door. You'll notice that there is a black plastic backing that is under the carpet. This plastic backer is attached to the door panel by melt-down plastic rivets, about 18 of them. Take a center punch and punch a small dimpel in each one of the rivet heads, you may have to rub off the carpet fibers to find all of them. DO NOT DESTROY THIS PLASTIC BACKING PIECE!!! We will use it later. Once you have the heads dimpeled drill them out with a 3/8 drill bit(or as big as you have.) It's no necessary to go all the way through.
Old 03-21-2002, 04:04 PM   #5
Self Portrait
rhenry01's Avatar
Thumbs up Now take off the pocket
Unlike what is shown in the picture above, the pocket doesn't come off with the plastic carpet backing. There are 4 more Melt points to drill out to get the pocket off. Drill these from the back side.
Old 03-21-2002, 04:06 PM   #6
Self Portrait
rhenry01's Avatar
The pocket is off!
Here is a pic of the pocket that is removed with the rivet locations indicated.
Old 03-21-2002, 04:19 PM   #7
Self Portrait
rhenry01's Avatar
Here is the Naked door panel
OK, the nasty pocket and the ratty looking carpet are off. In the next series of pics I'm going to cut a melamine backing piece. Mark and attach some tee nuts to the backing piece. Pad the backing piece. Stretch some left over silver vinyl over the padded backing piece. Attach the covered piece to the door panel then reinstall the panel on the door with our new retainers. I'll have these pictures up as soon as I get the work done, I am out of glue at the moment but I may go get some tonight. This is just the passengers side, if you guys are interested I'll do a custom speaker pod on the drivers side. Let me know!
Old 03-21-2002, 04:22 PM   #8
little pink pink
xtremer-pxl's Avatar
Looks Good So Far!!
Lets See ya do a Custom Speaker Pod!!
Old 03-21-2002, 07:07 PM   #9
Beyond Basic.
Basic's Avatar
sweet i hate those pockets, and it also makes your truck look custom somewhat, hehehee
Old 03-21-2002, 09:26 PM   #10
Self Portrait
rhenry01's Avatar
A little more prep work
With the door panel naked I decided to give it some clean-up and paint the plastic piece around the door handle and switches. So I used a lot of 409 to clean up the panel then removed a plastic hump where our new backing piece will lay. Here is the hump.
Old 03-21-2002, 09:28 PM   #11
Self Portrait
rhenry01's Avatar
Hump REmoved
Here is a shot of the hump removed. You'll notice that the panel is upside down in the picture, as it was in the last picture. Sorry if this was confusing.
Old 03-21-2002, 09:32 PM   #12
Self Portrait
rhenry01's Avatar
REmove the arm rest
Now remove the arm rest so that you can clean under it. All you have to do is push it in the direction of the arrow on the picture. Mine was snug but a pop on the front with the palm of my hand in the direction of the arrow made it come right off. It was nasty behind there!
Old 03-21-2002, 09:39 PM   #13
Self Portrait
rhenry01's Avatar
Remove the trim panel
Edited!!!!!!
To remove the trim panel to paint it you have to remove the 6 metal retainers. After having struggled with mine for about half an hour I have decided that the only way to get the retainers off safely is to snip the ends with a pair of diagonal cutters and put new ones on to reattach the trim piece. After their off, pop out the trim panel, sand it, spray it the color you want then put on a couple coats of clear to help protect the color coat. Here is a pic of the retainers. I will have more to say about this later in the thread I just don't want to be hopping around different subjects.
Old 03-21-2002, 09:41 PM   #14
Self Portrait
rhenry01's Avatar
Here are the pennys in the pocket
This is why I wanted to get rid of the nasty things! YUK!
Old 03-21-2002, 10:02 PM   #15
CHANGE YOUR EMAIL ADDRESS
For those of you that do use your door pocket, but you want it to look like new or custom paint it red or something unique, there is interior car paint.
Old 03-21-2002, 10:12 PM   #16
Self Portrait
rhenry01's Avatar
Kropelin, on first Gens the pocket is lined with this fuzzy crap and you would probably have to use fiberglass resin to smooth it out before you could paint it. And we will be using the area where the pocket is to put a speaker pod to hold something a little more exciting than a map of Detroit! Maybe some lights too....who knows...we're just having fun here and we'll see where it takes us. Your input is always welcome! Stop back often.
Old 03-22-2002, 02:27 PM   #17
Self Portrait
rhenry01's Avatar
Here is the Vinyl
This is the left over vinyl from a project my wife did. She picked up a yard of the stuff from the fabric store for $4.00 as a remnant but you only need a yard and the normal cost was about $8.00.
Old 03-22-2002, 02:39 PM   #18
Self Portrait
rhenry01's Avatar
This is the hardboard
I had to buy a 4'X8' sheet of 1/4" hardboard because my local Home Depot was out of the smaller pieces. If you can find a 2'X4' piece, it will work fine. The cost for my piece was $10.00. You don't really have to use hardboard, if you have a piece of 1/4 plywood it will also work. We will also use some of this when we build our speaker pods so try to waste as little as possible.
Old 03-22-2002, 02:53 PM   #19
Self Portrait
rhenry01's Avatar
Lightbulb Trace the backing piece
Remember me telling you not to destroy the plastic carpet backing piece? This is where we use it again. Lay the backing piece on the hardboard. I lined mine up in the corner to minimize the cutting that I had to do. Trace the outline of the plastic backing piece onto the hardboard. You will have to make up for the missing piece where the pocket use to be but that is easy, trace as much as you can then connect the missing part of the line with a straight edge. I just used the flat part of the backing piece to draw my straight line! Don't forget to trace the inside vent opening if you are keeping the useless vent. If you want to get rid of the vent just cut the vent off of the door panel and don't cut out the opening in the hardboard and it's gone!!
Old 03-22-2002, 03:01 PM   #20
Self Portrait
rhenry01's Avatar
Post These are the tools you use
Here are the tools you need to cut out the new backing piece. A scroll saw with a fine tooth blade, a drill with the biggest bit you have (not shown), safety glasses and a dust mask. The hardboard makes lots of dust when you cut it and you haven't lived until you have had to hack up a lung after breathing that crap! Use the safety equipment! You can also see part of the traced line on the hardboard in this shot.
Old 03-22-2002, 03:14 PM   #21
Self Portrait
rhenry01's Avatar
Cut out the piece
Now cut out the new backing piece. To get you started on the vent opening use the drill to drill a hole (inside the lines) to make an opening for the blade of the scroll saw. Be careful and cut right on the line.
Old 03-22-2002, 03:38 PM   #22
Self Portrait
rhenry01's Avatar
Now clamp it in place
Clamp the new backing piece in place on the door panel. (your girlfriends hands do count as clamps!) Clamp it lightly at first and align the backing as evenly as you can in the opening. Pay attention to the vent opening if you have kept the vent. When it is aligned to your liking, tighten up on the clamps.
Old 03-22-2002, 03:45 PM   #23
Self Portrait
rhenry01's Avatar
Talking Mark the Mounting holes
With the backing piece clamped to the door panel, flip the door pane over and mark the holes in the door panel onto the back of the backing piece. The picture I used below shows the holes with bolts and washers in them. I used this picture because it is clearer which holes I used. Use a pencil and trace the holes onto the backing piece as these will show us where to position our hardware.
Old 03-22-2002, 03:51 PM   #24
Self Portrait
rhenry01's Avatar
The hardware
Here is a pic of the hardware we will be using to mount the backing piece to the door panel. The hardware is
#6-32 x 3/8" Machine screws
#6-32 x 1/4" Tee Nuts
1/8" x 1" fender washers
I bought sixteen of each, eight per door. But we may use fewer than that....looks like we'll only use 7 per door.
Old 03-22-2002, 03:58 PM   #25
Self Portrait
rhenry01's Avatar
Drill holes and attach tee nuts
Unclamp the backing piece and put it on a working surface. You should now have six or so circles drawn on the back side of the backing piece (remember you are now working on the back side!) . Use your center punch and dimple each circle as close to the center as possible. Drill a 7/32" hole in each circle. Flip the piece over so the front side is up and place a tee nut in each hole and firmly tap it down with a hammer to get it as flush as possible.
Old 03-22-2002, 04:23 PM   #26
Self Portrait
rhenry01's Avatar
Test fit the panel
Now test fit the backing piece to the door panel. Run a machine screw with a washer in from the back side of the door panel. I had to trim one of my washers with a hack saw to get a good fit. At this point if you think it is necessary you may want to put another tee nut and screw in if the piece isn't laying flat enough. I am going to put another on in on mine. It's a little cold to work with contact cement today so the vinyl install will have to wait until tomorrow when the weather man says it will be warmer. We are almost done and you can tell what it's going to look like. This is a cheap mod to freshen up the interior. Here is a rundown on what we have spent so far:
Hardboard $10
Panel retainers $8
Paint $8
Hardware $7
Vinyl $4
Contact Cement $4
Foam $1
Total = $42.....That's cheap for two door panels!
Total Time it has taken me so far is 3 hours.
Old 03-22-2002, 08:51 PM   #27
Self Portrait
rhenry01's Avatar
Start Covering
We have to trim the vinyl down, lay the backing piece on the vinyl and cut out around it leaving about an inch of overhang. The vinyl should be laying face down and the piece face down on it. Position the piece to minimize waste and cutting. This is easy.
Old 03-22-2002, 08:54 PM   #28
Self Portrait
rhenry01's Avatar
Now cut the foam
Now cut a piece of foam (whatever thickness you are using, I'm using 1/4") to the exact size of the backing piece. We don't want any of the foam wraping around the edges. Remember....outside face of the piece should be laying on the foam as you cut it!
Old 03-22-2002, 09:01 PM   #29
Self Portrait
rhenry01's Avatar
Tape up the first edge
Since we are going to be stretching the vinyl, it is really important to get the first edge secured well. I like to start by taping off the area where I am applying the glue. Start you first edge on the bottom of the backing piece. Tape it off as in the picture. Position the vinyl, foam and backing piece as they will go together. Apply Contact cemement liberly to the taped off section as well as the vinyl. Follow the application directions on the can.
Old 03-22-2002, 09:03 PM   #30
Self Portrait
rhenry01's Avatar
Peel the tape
Another easy step. Peel the tape off immediately after you apply the cement.
Old 03-22-2002, 09:06 PM   #31
Self Portrait
rhenry01's Avatar
Glue down the first edge
Start at the middle and work your way out to the edges. When they say on the can of glue that it bonds on first contact that is EXACTLY what they mean! Don let the two glued up pieces touch in a place that you don't want. Once they stick together that is it....stuck forever!
Old 03-22-2002, 09:10 PM   #32
Self Portrait
rhenry01's Avatar
Clamp again
Because we want this edge to be strong we will now clamp it overnight. Clamp it up in a way that will apply pressure to the entire bead of glue. For this clamping operation you girlfriends hands will not do, but you can have her stand on the boards overnight. If she loves you she will do it. If not....find a new g/f!
We'll do more glue up tomorrow I hope. This inside the house stuff with that smelly glue is too much!
Old 03-23-2002, 02:24 AM   #33
Hadley Hellhound's Avatar
This is awsome!! I've always wondered how you would go about taking that piece of crap off!
Old 03-23-2002, 09:22 AM   #34
MO. boy missing St.Louis!
tommet's Avatar
Talking Hella job!!
Thanks for the in depth play-by-play man! This is helping me out tremendously! it is looking awesome! Can't wait to get to the custom pods!
Old 03-23-2002, 05:21 PM   #35
Self Portrait
rhenry01's Avatar
Unhappy The Brushes!
I must have had the G3 CD turned up too loud last night cause I forgot to tell ya how to put the contact cement on to the Backing piece and the back of the vinyl! (Could have been the fumes too!) I am using those cheap metal handle paint brushes, the military called them acid brushes, I don't know why. But anyway, I cut about half of the brissles off to make the brush stiffer. Check out the pic below, I use the lower one on the pic.
Old 03-23-2002, 07:35 PM   #36
Self Portrait
rhenry01's Avatar
Lightbulb GLue the top side
Now glue up the top side of the vinyl. When you actually stick the vinyl down really stretch the vinyl so that it is tight across the front of the panel...this is the trick to a good looking panel. AFter you stick it down clamp it an let it setup for a few hours. Here is what is looks like after it has had time to dry.
Old 03-23-2002, 07:40 PM   #37
Self Portrait
rhenry01's Avatar
Here is what we have so far
This is what the front looks like. See the fold marks? Don't fold your vinyl, roll it! If you do get fold marks you have to stretch the out. I will get some more of the fold marks out when I do the vent opening. (if I do the vent opening, I'm gonna test fit it closed to see what it looks like!! )
Old 03-23-2002, 07:50 PM   #38
Self Portrait
rhenry01's Avatar
Cut the rounded edges
Here is a pic of the way I cut the rounded lower corners of the vinyl. Cutting them in this sawtooth pattern the vinly will glue down flat. Try to get close to the edge of the backing piece because the cuts won't show in the front and you will be stretching the vinyl. This part calls for common sence so use it in cutting. If you look at the way the vinyl will lay you should be able to see where it needs to be cut.....take your time and do a good job here.
Old 03-23-2002, 07:54 PM   #39
Self Portrait
rhenry01's Avatar
Red face Glue the back edge
Now glue the back edge of the vinyl to the backing piece. You may have to trim some of the foam if it has stretched any. Only glue the flat piece and really stretch the snot out of it to pull out the wrinkles! We'll glue the sawtooth tabs later! Here is a pic of the glue on the pieces that need to be attached at this point.
Old 03-24-2002, 01:27 PM   #40
Self Portrait
rhenry01's Avatar
The Corner glued down
Here is what the corner should look like after you have it glued down. Remember, pull the vinyl tight!
Oh, see those arrows, they point to the tee nuts which have been covered by the vinly. Don't put glue directly on the tee nuts!
Old 03-24-2002, 01:35 PM   #41
Self Portrait
rhenry01's Avatar
Wink What you didn't see!
What I didn't show you was this. Since this is my door panel and I'm not pressed for time, I clamped the corners so that I know I got good contact. Don't get in too much of a hurry.
Remember this. While it has taken me three or four days to do this up to this point, it should only take you one day. I have to stop at each step to take pictures and let glue dry and things like that (and my wife keeps interupting me and the kids need help with their calculus!) You can cut all your vinyl at the same time, top and bottom for both sides and glue them all at the same time.
Old 03-24-2002, 01:41 PM   #42
Self Portrait
rhenry01's Avatar
Talking Speaking of the top panel!
While we're waiting for the glue to dry we can disassemble the top panel and get ready to cover it! I really wanted to wait to do this until after I did the bottom panel so that I could show you each step but it is getting kind of hard to stop at each step. So If you're not going to do the top panel you can skip these steps.
To get the top panel off you have to remove these 6 nut type fasteners.
Old 03-24-2002, 01:45 PM   #43
Self Portrait
rhenry01's Avatar
Lefty Loosey
Pry up at the edges of the fasteners so that you can get a little bite with your needle nose pliers then unscrew them. The needle nose plliers are going to slip off and snap shut so don't let any of your skin get in there or you will be yelling multiple nasty words! You have to approach the fasteners from directly over top of them to grab the edges. The picture doesn't show this, just where to grab and with what tool!
Old 03-24-2002, 01:47 PM   #44
Self Portrait
rhenry01's Avatar
Remove the staples
Remove the staples from the back of the door panel. Mine had 4 in it, yours may have more. Pry up one side of the staple with a small flat blade (see picture) and pull it the rest of the way out with a pair of pliers.
Old 03-24-2002, 01:51 PM   #45
Self Portrait
rhenry01's Avatar
That's it, it's off
Here you are, one really naked door panel!
Old 03-24-2002, 01:54 PM   #46
Self Portrait
rhenry01's Avatar
Remove the fabric from the top panel
This fabric should come off easily. Take care not to destroy the padding underneath the fabric as we will leave is on and just add more foam to it. Also take care not to seperate the cardboard portion of the panel from the metal portion. If that happens try some 5 min epoxy to glue them back together.
Old 03-24-2002, 01:56 PM   #47
Self Portrait
rhenry01's Avatar
And here is the back side
The back side.
Old 03-24-2002, 02:28 PM   #48
Self Portrait
rhenry01's Avatar
Thumbs up Look Mom......No Vent
OK! With the bottom panel semi-complete I wanted to show you what the dor panel would look like. I put the pieces back on the door panel but didn't attach anything so you could see the results. I like the look but I'm going to cut out the vent opening in the vinyl so that the vent is operational. I'm not going to show the steps involved because you can probably do them yourself. The easiest way to open the vent is to lay it on a work surface and cut out the opening from the back with a box knife or X-Acto, leaving yourself 1" of vinyl to work with. Trim the foam up flush with the backing piece. Cut the corners straight (not sawtooth) and glue the sides down..really easy stuff now that you know how to do it.....right?
Old 03-24-2002, 02:32 PM   #49
Long Bed Member
92S10LB's Avatar
man that looks sweet with no ugly useless pocket!
Old 03-24-2002, 05:32 PM   #50
Self Portrait
rhenry01's Avatar
Now the trim panel
Here is the trim panel off the door panel. I cut the end of the retainer clips with a set of diagonal cutters. This is the safest way to do it. In the pic I opened up the clips to show you how to cut them.
Page generated in 0.17250 seconds with 29 queries
[Output: 240.24 Kb. compressed to 217.59 Kb. by saving 22.65 Kb. (9.43%)]
