How To: Steering Wheel Removal
Go Back   S-10 Forum > General Tech > S-Series How-To > Interior How-To
Old 05-14-2007, 08:32 PM   #1
Moderator
What?'s Avatar
You remove the negative cable
http://i42.photobucket.com/albums/e3...To%20Ig/10.jpg
You remove the Air Bag fuse
This is location where you will see 2 holes even though its hard to see in picture but you know the location now
You need a small screwdriver and PATIENCE, NO RUSH, TAKE YOUR TIME
This is what it should look like, once u put it through the hole, you will need to lift UP the screwdriver, theres clip that holds airbag, think of it as opening the clip which the airbag side will slide out
NOW once you get it clip open to slide out, it will look like this
ONCE again, put it in straight and once u reach the end(not too hard) lift screw driver up, try to wiggle around, it will take time so take ur time and u will not damage it as you install it again
Now you have remove both side, it should look like this
HOLD IT once you remove it, air bag connector is on
Using screwdriver, pop it open
Pull it out carefully
Lay the air bag FACING UP on safe, flat surface
Next,you remove the horn prong, you PUSH down and TURN left, itll come right off
Remove the aig bag wiring OFF the clip FROM the steering wheel
NOW, USING 21mm, you loosen this nut
GO BUY OR RENT/BORROW the steering wheel removal kit from Auto zone(10-15bucks)
Old 05-14-2007, 08:41 PM   #2
Moderator
What?'s Avatar
Re: How To: Steering Wheel Removal
http://i42.photobucket.com/albums/e3...To%20Ig/27.jpg
You have the bar as low you can on the BLACK BOLT, MAKE SURE you USE correct BOLT size! TO insert STEERING WHEEL bolt hole!
Using 13mm, i tighten both BOLT EVENLY to where it stop, DO NOT GO FURTHER, make sure you have like 2,3 thread turn left before it stops
NOW, using 16mm for the BLACk bolt to loosen the steering wheel
Keep turning and the steering wheel will pop out
Remove steering wheel puller away and carefully taking steering wheel off
Congratulation, you got the steering wheel OFF
NOW, reverse procedure, you put steering wheel back on, TIGHTEN the nut as much u can(make sure u DONT overtighten, BUT use 1/2" rachet to tight and you're good to go)
When you put air bag back on
make sure its mounted properly
NOW keep going in reversal order(fuse, connector)
You're Done!
Average time 15minutes-45minutes
Page generated in 0.56843 seconds with 31 queries
[Output: 48.29 Kb. compressed to 46.61 Kb. by saving 1.68 Kb. (3.47%)]
