wiper help.
Go Back   S-10 Forum > Specific Model Forums > 1st Gen Forums > Blazer / Jimmy / Bravada
Old 06-26-2008, 10:11 AM   #1
thats my boy with the box
rladieu3's Avatar
rladieu3
wiper help.
i have a 94 blazer and the wipers stoped working??? i checked the fuse and it is fine....i don't see a relay in the book what could it be??
Old 06-27-2008, 06:17 AM   #2
Sucking dick while being Banned
SH-60B can only hope to improve
Re: wiper help.
Could be just a rusty connector or a bad ground. Sometimes just unplugging and re-plugging can knock enough rust off to connect power again.
Old 06-30-2008, 06:15 PM   #3
AWOLMIND's Avatar
AWOLMIND is on a distinguished road
Re: wiper help.
Its the pulse board on the wiper motor, you don't have to replace the motor. Advance has the Pulse Board ACI PN 172361 for $29.00, Autozone has it for $19.00 PN 70000. Sometimes you can try and clean the contacts an apply some dielectric grease to them and it may work for a while. You don't have to remove the motor to replace it, just remove the screws on the cover an there it is. unplug and replace. Hope this helps
Old 06-30-2008, 09:45 PM   #4
rladieu3's Avatar
rladieu3
Re: wiper help.
thank you for your help
Old 07-14-2008, 08:06 AM   #5
rladieu3's Avatar
rladieu3
Re: wiper help.
well i orded the part from autozone and when it come in it was for a new s10 . and that was the only one thay could get same with advance.so i took a to the junk yard and pulled one for $5. and thay still don't work.what now???
Old 07-14-2008, 11:25 AM   #6
Re: wiper help.
Put 12 volts directly to the motor. If it works the switch is bad, if it doesn't work the motor is bad.
Old 07-14-2008, 03:54 PM   #7
Bill Wheats's Avatar
Bill Wheats is on a distinguished road
Re: wiper help.
Those motors don't burn out in 300K miles. The problem associated in the motor, is the internal + feed wire is bare and hangs real close to the gears. Often it will eventually touch, dump the voltage causing it not to run.
We just drill out the rivets. Tape a sleave around the wire and screw the casing back together using about $2 worth of stainless steel screws and nuts. It'll go at least another 10 years.
Page generated in 0.10398 seconds with 11 queries
