Updated the look of the Jimmy a bit
Go Back   S-10 Forum > Specific Model Forums > 1st Gen Forums > Blazer / Jimmy / Bravada
Old 05-28-2008, 08:09 PM   #1
WNYTrucks Creator
White2000LS's Avatar
White2000LS is on a distinguished road
So i got some parts off of a local S10 Guy for the Jimmy, including a non broken glove box, some new "ears" , rear ash trays and speaker covers, because mine are trashed
But heres some pics...
Before
After the factory "sport" Mirrors
I have no idea why that shot came out so angled, sorry forv the poor quality, cell phone is all i had
And of course, some extra money shots
I got lucky and was able to pry this logo off the broken glove box that came on the jimmy and swap it over to the one i got from the blazer. little bit of contact cement and you cant even tell thats not the original glove box. Hey, gotta keep it a Gypsy, right?
and of course the wonderful 4x4 under hood liner
once i get a better camera, i will be taking retarded amounts of pictures, camera phone doesnt do this thing justice as to how clean it still is
Little background on the Jimmy, I picked it up from a local S10forum member for 400 bucks. It is a 1988 GMC Gypsy 2.8L 4x4 LOADED with the factory Z71 Offroad package, factory sunroof, Optional Guage cluster with Tach. It is a Gypsy, and it is loaded to the hilt. Reason guy was selling it so cheap is because it had a blown motor. He had 4500.00+ in new parts with recepits on the thing.
Old 05-28-2008, 09:49 PM   #2
Mr. Sparkle
Onimun's Avatar
Onimun will become famous soon enough
Re: Updated the look of the Jimmy a bit
Never heard of the factory Z71 package...
You are the first person i have met with a factory sunroof in 88, other then myself. Can you get me a pic of the switch?
Old 05-28-2008, 11:39 PM   #3
Mr. Clean
EYEROCK89's Avatar
EYEROCK89 is on a distinguished road
Me niether. 1988 was the first year for the Z71 silverado, but I thought it was only the full size trucks.
Old 05-28-2008, 11:55 PM   #4
WNYTrucks Creator
nopers RPO code in glovebox says Z71, and its not a power sunroof, unfortunatly lol its manual
Old 05-30-2008, 06:28 PM   #5
Mr. Sparkle
Onimun's Avatar
Then its not factory. There is no such thing as a Z71 S-10 Blazer.
Oh and your underhood light is out.
Old 05-31-2008, 09:19 AM   #6
"The Recruiter"
jtcfanof3's Avatar
jtcfanof3 is on a distinguished road
You need to find these rare fender emblems,I found mine on EBAY and made it a toolbox trophie!
Anybody have the factory sunroof RPO code?My 89 Blazer has that basically same sunroof,down to the squares on the outer portion of the glass.
BTW,most 88 Blazer/Jimmys have the tach,mainly 86-88's got that tach,my 88 Blazer has one as well and so does one of my buddies 86 S-10 Ext cab.
Old 05-31-2008, 10:13 AM   #7
billythekid is on a distinguished road
Hello:The Off Road package &
The Tachometer
had to be ordered that way or you didn't get it.
It could be a Dealer, Sales Manager. Salesman,
or it could a promo, who did it?
But somebody did it.
Billy the Kid AGF
Old 05-31-2008, 11:40 AM   #8
"The Recruiter"
jtcfanof3's Avatar
Well every 88 Blazer cluster I have found(found alot!)and seen have had the tach,minus the plain jane packages.Musta been part of a Tahoe package.
Old 05-31-2008, 12:33 PM   #9
It isn,t part of any package.
It is a stand alone Item, Like a radio.
have seen Forest Service Trucks with no
options, but with a Tach??? Weird
Billy the Kid AGF
Old 05-31-2008, 02:06 PM   #10
Mr. Sparkle
Onimun's Avatar
I have a Tach on my 88 4x4. Its not a tahoe package either.
I have ( to my knowlage) the only factory power sunroof on the forum. I have not met anyone else with one, on an 88.
Old 05-31-2008, 02:34 PM   #11
WNYTrucks Creator
i ran the RPO's and one of the last ones is Z71..
Is it a tahoe package? or the Offroad p[ackage
alli know is it got skid plates over everything, bilstein shocks and fender flares (small)
heres the RPO list
AJ1 WINDOW TINTED , "DEEP, ALL EXCEPT W/S AND DRS"
AM7 SEAT RR , FOLDING
AU3 LOCK CONTROL , "SIDE DR, ELEC"
AU6 LOCK CONTROL , "END GATE WINDOW, REM CONT ELEC RELEASE"
A31 WINDOW , "POWER OPERATED, ALL DOORS"
A78 ADJUSTER FRT ST BK , "MANUAL, DRIVER & PASS, RECLINING"
B34 COVERING FRT , "FLOOR MATS, CARPETED INSERT"
B32 COVERING FRT , "FLOOR MATS, AUX"
C3B ROOF , "SUN, GLASS, SLIDING, ELEC, TRANSPARENT PLASTIC"
C4C PANEL , "TRIM, RR SIDE - NOT INSTALLED"
C4Z MERCHANDISED PKG , SAVER DISCOUNT
C49 DEFOGGER , "RR WINDOW, ELECTRIC"
C51 DEFLECTOR , "RR WINDOW, AIR"
C60 HVAC SYSTEM , "AIR CONDITIONER FRT, MAN CONTROLS"
DC4 MIRROR I/S R/V , "TILT, DUAL READING LAMPS"
D2J COUNTRY , GUINEA
E55 BODY EQUIPMENT , END GATE
E6F COUNTRY , GEORGIA
E9Z KEY , SPEEDO - DELETE
FK2 ARM LH , TORS BAR SPRING ADJ (A)
FK3 ARM RH , TORS BAR SPRING ADJ (B)
GMC PLANT CODE , "PONTIAC, MI, USA"
G80 AXLE POSITRACTION , LIMITED SLIP
H04 AXLE REAR , "4.11 RATIO, SINGLE SPEED"
MX0 MERCHANDISED TRANS , "AUTO PROVISIONS, O/D"
NA5 EMISSION SYSTEM , "FEDERAL, TIER 0"
NV5 SHIELD , DIFFERENTIAL CARRIER
NY7 SHIELD , TRANSFER CASE
N33 STEERING COLUMN , TILT TYPE
N40 STEERING , "POWER,"
N90 WHEEL , 15
P17 COVER SPARE , WHEEL
UX1 RADIO , "AM STEREO/FM STEREO, SEEK/SCAN, AUTO REV"
U16 TACHOMETER , ENGINE
U26 LAMP , "INTR, ENG COMPT, COURTESY"
U66 SPEAKER SYSTEM , "7, CUSTOM"
U73 ANTENNA , "FIXED, RADIO"
VE6 BUMPER , "FRT & RR, IMPACT, COLORED"
V02 RADIATOR , "HEAVY DUTY, WITH TRANS OIL COOLER"
V54 LUGGAGE CARRIER , "ROOF, PAINTED"
YD5 SPRING FRONT , BASE EQUIPMENT
YD6 SPRING , "RR, BASE EQUIPMENT"
YEB TIRE REAR , P235/75R15/N WOL R/PE ST TL OOR
ZEB TIRE SPARE , P235/75R15/N WOL R/PE ST TL OOR
ZK5 Unknown RPO Code
ZQ2 SALES PACKAGE , DRIVER CONVENIENCE
ZY6 COLOR COMBINATION , "TWO TONE, TREATMENT"
Z53 CLUSTER , "INST, OIL, COOL TEMP, VOLTS"
6CA COMPONENT FRT LH , COMPUTER SEL SUSP (6CA)
7CA COMPONENT FRT RH , COMPUTER SEL SUSP (7CA)
72A STRIPE COLOR , "ACCENT, MED GARNET RED (96)"
90U PRIMARY COLOR , "EXTERIOR, GRAY MET (02)"
90U PRIMARY COLOR , "EXTERIOR, BLACK II (02) (OPEL)"
90U PRIMARY COLOR , "EXTERIOR, TARRAGON GREEN MET (03) SATURN"
RPO Check
B33 COVERING REAR , "FLOOR MATS, AUX"
B74 MOLDING WHL OPENING , EXTRA WIDE
B84 MOLDING B/S , EXTERIOR
CD4 WIPER SYSTEM , "WINDSHIELD, PULSE, VARIABLE DELAY"
D34 MIRROR I/S FRT VAN , "LH & RH, SUNSHADE, NO"
D44 MIRROR O/S , COLOR
D55 CONSOLE , "FRT COMPT, FLOOR"
D69 Unknown RPO Code
E52 BODY EQUIPMENT , ONE PIECE LIFT GATE WITH LIFT GLASS
JB3 BRAKE , "POWER, DISC/DRUM, 4,600 LBS"
JM3 BOOSTER , "BRAKE, 240MM TANDEM, HIGH FLOW"
K34 CRUISE CONTROL , "AUTOMATIC, ELECTRONIC"
LL2 ENGINE , "GAS, 6 CYL, 2.8L, 1 TBI, V6, 60 DEG, HO"
MD8 Automatic 4-speed transmission (THM700R4/4L60)
QEB TIRE ALL , P235/75R15/N WOL R/PE ST TL OOR
SLM SALES PROCESSING , STOCK ORDERS
TT4 HEADLAMPS , "HALOGEN, 4"
VA1 RADIATOR , STANDARD
UP8 RADIO , "PROVISIONS, AM/FM STEREO, INSTRUMENTATION"
V73 VEHICLE STATEMENT , USA/CANADA
V76 HOOK , TOW
XEB TIRE FRONT , P235/75R15/N WOL R/PE ST TL OOR
YC3 CONVENIENCE PKG , DECOR LEVEL #3
YD3 AXLE , (BASE EQUIP) FOR SCHEDULING GVW PLATE
Z71 CHASSIS PACKAGE , OFF ROAD
Z88 MARKET BRAND , GMC
17L SECONDARY COLOR , "EXTERIOR, DK BLUE GRAY MET (92)"
17L SECONDARY COLOR , "EXTERIOR, SILVERMIST MET (97)"
17L SECONDARY COLOR , "EXTERIOR, SILVER BLUE, (01)"
18B TRIM COMBINATION , "CLOTH, CHARCOAL"
181 Unknown RPO Code
Old 05-31-2008, 03:12 PM   #12
"The Recruiter"
jtcfanof3's Avatar
Billy the Kid AGF
I have seen my share of 88's with tachs so........someone was ordering alot of them that year then!
Old 05-31-2008, 03:15 PM   #13
"The Recruiter"
jtcfanof3's Avatar
Just for example,88 cluster on ebay:
http://cgi.ebay.com/ebaymotors/S-10-...spagenameZWD1V
Old 06-01-2008, 03:45 PM   #14
blazin14's Avatar
blazin14
My 88 Tahoe has a tach
Old 06-01-2008, 06:32 PM   #15
WNYTrucks Creator
got some new picsss NOTE: this truck is a work in progress and is far from done.
Old 06-01-2008, 09:38 PM   #16
"The Recruiter"
jtcfanof3's Avatar
I see a digital dash back there,and just so ya know,unless your changing the tranny,that cluster wont work,you have a cable driven speedo in that 88,so unless your updating it as well,you may be surprised when you remove your stock cluster.
Old 06-02-2008, 12:45 AM   #17
WNYTrucks Creator
yeah i know, got it for free along with the Drac Controller and the cluster plug dont know exactly what i want to do with it yet
Old 06-14-2008, 09:44 PM   #18
WNYTrucks Creator
So uhh Bumporino
Is it normal for the Jimmy to have really thick aluminum skid plates underneath bilstein shocks, and a front steering stabilizer shock?
Old 06-14-2008, 10:37 PM   #19
Yep: It is part of the Off/Road package
Billy the Kid AGF
Old 06-15-2008, 07:25 AM   #20
Sucking dick while being Banned
SH-60B can only hope to improve
Before
"How clean it is" with rusted lower drivers door, dented bumper and fender, blown motor?
Old 06-15-2008, 11:09 AM   #21
WNYTrucks Creator
the surface rust on the door? the easily replaceable bumper, or the motor thats getting replaced right now?
How about 0 underbody rot?
its a 20 year old truck. In my area any vehicle 20 years old with this many miles is a salt eaten wreck. What do you expect? gleaming immaculate paint and a perfect body?
Take your bullshit elsewhere fag and GTFO of my thread.
Old 06-15-2008, 11:30 AM   #22
Mr. Sparkle
Onimun's Avatar
Yeah i wouldnt call surface rust, real rust. Rotted out Frame rails, floors and sidewalls = true rust. I wouldnt say Immaculate paint but it looks good.
Old 06-15-2008, 11:50 AM   #23
"The Recruiter"
jtcfanof3's Avatar
Ya,I dont know anything about that!
Rust eaten salt eatn......what?
LOL
We all have to start somewhere!
Old 06-16-2008, 04:46 AM   #24
It's a ****ing pile of shit. If you say it's "clean" then yes, I would expect good paint & and a rust free body. It's just another POS like any other.
Page generated in 0.19553 seconds with 11 queries
