smells like rotten eggs 4.3 c.p.i - S-10 Forum
post #1 of 18 Old 09-23-2010, 05:07 AM Thread Starter
User is: juicedon20s is offline
Lightbulb smells like rotten eggs 4.3 c.p.i
i have a 87 s10 truck with a 94 cpi 4.3 motor. it has just been rebuilt and after firing the motor up for the first time it fouled all 6 plugs simutaneously. thought maybe timing was off, so made an adjustment through the distributor after setting tdc and insted of the sulfer smell and fouling the next set of plugs, it smells like rotten eggs and fouled them again. any suggestions on what i should check next? please help thx
Name:	art of noize 2010 feb 21st.JPG
post #2 of 18 Old 09-24-2010, 11:25 AM
blazerfun's Avatar
User is: blazerfun is offline
Re: smells like rotten eggs 4.3 c.p.i
Burnt electric components, smells weird.. Maybe you could call it "rotten eggs" .. Gas from overloaded battery or blown battery, bad groundings (very bad), blown ignition module..
1992 Chevy S-10 Blazer sport, 4,3 Aut. 235K, black.
1994 Chevy S-10 Blazer Tahoe, 4,3 Man. 225K, black.
1995 Toyota Carina E, 2,0Diesel Man.470K, Greenish.
1986 Massey-Ferguson 699-4
4wmoto ChinaATV, 2010, 200ccm, black.
2003 Peugeot Speedfight II, 50ccm, blue.
post #3 of 18 Old 09-25-2010, 02:11 AM Thread Starter
i put a new tps on and it seemed fine after that but didnt get a chance to run it too long had a small leak in my rad that turned into a fire hydrant bout 5 min after changin tps out. this truck is possessed. everything new on her never had problems before the build but now everything wants to go on it so now everythings new. what you think on the tps? it was runnin closed throttle was .50 volts, wide open was 5.10 volts with the bad one. .54 volts closed and 4.2 volts open throttle. standard voltage is less than 1.25 closed, and no more than 4.5 open.
post #4 of 18 Old 09-25-2010, 02:13 AM Thread Starter
truck weas idling funny before the tps swap and now no idle prob no idea.
post #5 of 18 Old 09-25-2010, 03:07 AM
Ruff ruff
BigTDawg's Avatar
User is: BigTDawg is offline
Coolant is leaking from somewhere possibly. It could be a failed intake manifold gasket or cracked cylinder head, I've seen gasket failures without whitesmoke at first. Normally the sulphar smell is from unleaded gas but fouled plugs is more than gas.
BigTDawg is offline
post #6 of 18 Old 09-25-2010, 04:49 PM Thread Starter
Thx BIGDAWG I appreciate it man
post #7 of 18 Old 09-25-2010, 04:49 PM Thread Starter
thx BLAZER.
post #8 of 18 Old 09-25-2010, 05:01 PM
Budget Ballin FTS!
BrandonR's Avatar
User is: BrandonR is offline
Are you running a catalitic convertor? Might be stopped up and this will do all the things your describing.
2001 4 door blazer All brand new suspension, bagged
BrandonR is offline
post #9 of 18 Old 09-25-2010, 05:26 PM Thread Starter
I CHANGED OUT THE CAT BECAUSE I WOULD HAVE THE PIPE UP TO THE MANIFOLDS AND IT WOULDNT START, BUT I DROP THE PIPE FROM THE MANIFOLDS, IT WOULD START. SO I FIGURED CLOGGED CAT. I CHANGED IT OUT AND THAT CURED THE SULFER SMELL, AND RAN FINE AS FAR AS SMELL GOES BUT THEN AFTER I SHUT IT DWN AND LEFT IT SIT FOR ABOUT AN HOUR, I STARTED IT UP AGAIN AND HAD THE ROTTEN EGG SMELL, WHICH I WAS TOLD WAS FUEL RELATED. THAT ALSO MAKES SENSE BECAUSE THE FOULING OF THE PLUGS. IM TELLING U MAN THIS TRUCK IS DEFINITELY POSSESSED. LOL. THX FOR THE SUGGESTION THOUGH.
post #10 of 18 Old 09-25-2010, 05:42 PM
WIP
GMC777's Avatar
User is: GMC777 is offline
It could just be bad gas. ive seen it happen before. if i may ask where are you buying gas?
GMC777 is offline
post #11 of 18 Old 09-27-2010, 05:23 PM Thread Starter
circle k is the only gas thats been in it and it was freshly poured into a bone dry tank for the 1st time
post #12 of 18 Old 09-28-2010, 04:22 PM
Budget Ballin FTS!
BrandonR's Avatar
no problem man, Idk what all could cause all of this again if its already been swapped out. Sounds like you got some fuel problems there
BrandonR is offline
post #13 of 18 Old 10-05-2010, 02:32 AM
Ruff ruff
BigTDawg's Avatar
Remove a plug from a port that's visable, crank the engine and see if liquid comes out. I don't think gas would foul plugs right after replacement, I could be wrong but that would have to be some nasty gas. You could drain a little gas to get a look at it.
BigTDawg is offline
post #14 of 18 Old 01-26-2012, 03:08 PM
User is: xtremelyslammed is offline
Unhappy Re: smells like rotten eggs 4.3 c.p.i
Any updates on this issue? I purchased a '94 S15 Jimmy in early December. Truck has 134k on the 4.3. My truck REEKS like old gas after it gets hot. I have put +/- 1,500 miles on it since I bought it. I also did cap n rotor, 6 plugs, plug wires, and put an MSD 6A, but the smell was present before all of that. I noticed on my way home, the smell came in through the a/c.
post #15 of 18 Old 01-26-2012, 09:55 PM
86, 2.5L, 4spd
Blkwdw86's Avatar
User is: Blkwdw86 is offline
Catalytic converter. Time for a new one.
Blkwdw86 is offline
post #16 of 18 Old 01-27-2012, 10:10 AM
86, 2.5L, 4spd
Blkwdw86's Avatar
Sorry, didn't show previous posts before I posted.
While on the way to work this morning following a newer Silverado with burning embers flying up from under his truck (!!!) I got to thinking about your problem more in depth.
About the only thing that will cause a rotten egg smell on these trucks is a blown cat, which is why I answered as such. Cats fail over time, that's a given, it takes some serious abuse throughout it's lifespan and still in spite of that, it's a reliable device.
That's not to say you can't blow one though. The gas smell combined with the rotten egg smell tells me you're blasting unburned fuel into the exhaust system, the number one killer of catalytic converters. Not hard to check, take a decently spirited drive after dark, then poke your head up underneath and look at it, undoubtedly it'll be glowing cherry red. That's NOT normal. It's glowing like that because it's comleting the combustion of raw fuel going into it.
So now we have to figure out why your cylinders aren't burning the fuel. Rich mixture or mechanical defect? Start by changing the O2 sensor, it's the chief controller for mixture. Check your fuel pressure regulator, if it's not holding the pressure down the injector will shoot too much fuel. Go through your ignition system, weak spark will won't fully ignite the fuel. Check timing, too much advance and the combustion is blowing out the exhaust before it's completely burned.
You might have burned up your new cat, check it as well.
Blkwdw86 is offline
post #17 of 18 Old 01-27-2012, 10:20 AM
Thank you, I'm going to do the full exhaust and update!
post #18 of 18 Old 01-28-2012, 10:15 PM
n2o4myfix's Avatar
User is: n2o4myfix is offline
I had a 4.3L in my 94 jimmy that had the same problem, stunk and run rough at idle and would foul plugs. I problem was the egr valve had a chunk of carbon stuck in it holding it open, I replaced the egr gasket with one of these with a screen and never had that problem afterwards.
