rear window squeak???
ok so my buddys 94 2 door blazer has a horrible squeak coming from the rear window while driving and going over bumps.was wondering if anybody has the same problem and if you could tell me some remedies?
Stealin JTC's sandwichs
Location: In jtc's basement eating the salami sandwich from his fridge User is: OffLine |
Re: rear window squeak???
Its been years since I had to chase a noise in the back of one of those. I seem to recall a work latch and at one time there was some felt stuck to a latch that was worn thin causing a rattle I think.
Another thing your buddy could try is cleaning the seal and applying some pertrolium jelly, KY jelly, anal eze, what ever. Even on the door seal. My Camaro flexing would cause a squeak from the door seals rubbing. New seals snugged it all up. |
I get the very same issue with my jimmy every couple of months.....to take care of it all I do is take some lithium grease and spread it on the latching part that is on the glass.....the squeeking is coming from the metal on metal of the portion in the tailgate and the portion on the glass.
At first I used a piece of copper( it does not squeak). Then I used some petroleum jelly. It has been 3 months with no squeak.
he greased up the latched but i doesnt seam to do anything.i cant remember what kind of grease he used though.and mott when you say you used a piece of copper what are you talking about useing it for?
I wraped a thin piece of copper around the metal part on the window. A piece of 1/4 tubing split lengthwise will work. The only problem is the latch in the tailgate will chew up the copper after a while.
White lithium greese works fine.
Used to wrap my latch with electrical tape, it works for a few months.
Long live the Rat Fink
I have the same problem the latch it self on the window part is worn from striking the latch itself.
I have the same issue and it's the most annoying damn thing in the world!! I have never tried anything just turn up the music. I'll try some of these ideas and tell ya what happens
My problem with that was the latch AND the hinges that connect the glass to the top. Pop the plastic covers off the part on the glass & there should be 3 torx screws i believe. Tighten em up
I ended up doing that, greased the latch, & used weather stripping to finally get that under control. elec tape on the glass catch works but wears out quick. been there ![]() |
4x4 v6 blazer
Duct tape lasts longer |
half10
i just fliped the hook around. and installed thiner shim....if u look at it the latch catches slightley off center so by flipping it u get back to the unused metal and the thinner shim makes it suck in tighter...seams to work pretty good i only get noise on realy hard jolts( but then everthing rattles!)
