rear window latch
Go Back   S-10 Forum > Specific Model Forums > 1st Gen Forums > Blazer / Jimmy / Bravada
Old 11-07-2009, 02:28 PM   #1
Question rear window latch
so i can't seem to get my rear window to open with the switch can't tell if the switch went bad or what tried putting a test light to the switch and got nothing and also dont have the key to open it manually so i figured i'd try and replace it so that i could atleast open it with a key so my question is how hard is it to do? and where do i start?
Old 11-07-2009, 03:01 PM   #2
Blazin_Jason's Avatar
Re: rear window latch
Once you get the back cover off it's easy. A little clip holds the latch/lock on. Does your horn work?
Old 11-09-2009, 08:49 PM   #3
nope dont have one hooked up....is there any way i could jump the latch button to get it to open?
Old 11-09-2009, 10:10 PM   #4
Just make sure the fuse is good, it's the same one for the horn I believe. I think you can just jump the leads on the switch and see if that does it.
Old 11-10-2009, 09:38 PM   #5
skunk0526's Avatar
Definitely check the fuse first.
Can you hear the switch trying to open it or the latch makes no noise at all? If it does have someone pull/push the window grip while you rapidly hit the button. If you get it open, lithium grease the latch.
If not, the switches are easy to replace.
Old 11-10-2009, 09:44 PM   #6
make shore its up in park all the way. i had the same problem last week
Old 11-11-2009, 05:57 PM   #7
skunk0526's Avatar
does that make a difference? What vehicle are we talking about here? I always thought the rear window release was a simple 2 wire circuit.
Old 11-11-2009, 05:58 PM   #8
skunk0526's Avatar
My bad. Just read your sig.
Old 11-12-2009, 06:44 PM   #9
the switch doesnt do anything and i checked all my fuses with a test light and made sure...also put the test light to the wires for the switch and also got nothing
Old 11-12-2009, 09:28 PM   #10
skunk0526's Avatar
If you got nothing with the test light and you say the fuse is fine, it could be the wire itself is bad. Did you test the fuse for continuity? they could go bad and not blow.
If all else fails..... run a new wire
Last edited by skunk0526 : 11-12-2009 at 09:32 PM. Reason: making statement clearer
Page generated in 0.56249 seconds with 31 queries
[Output: 70.26 Kb. compressed to 65.79 Kb. by saving 4.47 Kb. (6.36%)]
