no key and need to move it
Go Back   S-10 Forum > Specific Model Forums > 1st Gen Forums > Blazer / Jimmy / Bravada
Old 11-06-2009, 04:37 PM   #1
Hello. I have a 1986 GMC Jimmy low rider with convertible back and we just got. My dads boss got a new building and there was a lot of crap in it. So there was 3 trucks in there that some one was storing. 2 of the trucks are gone now and we get the Jimmy the only problem is no keys to the jimmy and we need to push it out of the building so we can get it towed to are place. Is there away to get the truck in gear and get the steering wheel unlocked? All so the truck is not running its been sitting for 6+years.
here are some pics.
Old 11-06-2009, 04:44 PM   #2
Ticket Magnet
Rhotpursuit's Avatar
Re: no key and need to move it
Pop a door lock if it's the same key as the ignition and have one made. If not, go by a new ignition cylinder and replace the old one...cheap and fast.
Edit...they are different...get a new igniton cylinder
Old 11-06-2009, 04:48 PM   #3
thanks
what do all i need to take the old one out?
Old 11-06-2009, 04:57 PM   #4
Banned
Dukeboy320's Avatar
If its a 4x4 u could put it in neutral with the 4x4 stick
Old 11-06-2009, 05:14 PM   #5
it is not 4x4 the old owner put that on same as a chevy front grill. its really a s15 jimmy because the owner ship and on the dash says s15.
Old 11-06-2009, 06:07 PM   #6
Pop off the trans linkage and put it in neutral using the lever out of the trans? As for steering it, well thats another problem!
Old 11-06-2009, 07:42 PM   #7
Long live the Rat Fink
Big Pappa's Avatar
wheel dollies.
Old 11-06-2009, 08:12 PM   #8
take the driveshaft out.....four 11mm bolts at the axle....then wrap a sandwhich bag around the tail shaft of the trans and secure the bag with an elastic band or tie it on nice n tight with string. ...FAST AND FREE!!!!!!!
Old 11-06-2009, 08:16 PM   #9
Busy at school
jtcfanof3's Avatar
I agree with the ignition switch, buy a new key switch, pull the steering wheel dig in a little bit and replace it with a new one. Put it back together and your golden! But if all you need to do is move it, just pull the steering wheel and remove the lockplate with the GM lockplate remover tool, but ya if you replace the whole key switch then you can pull the shifter out of park, or as mentioned above, the shifter on the side of the tranny is easy to unhook and shift it out of Park.
Old 11-06-2009, 08:18 PM   #10
Busy at school
jtcfanof3's Avatar
See, you should be glad you came to this site, we just gave you what, five different methods for moving the truck!
Old 11-07-2009, 03:39 AM   #11
furious_cruzer's Avatar
well you can allways just break the egnition switch and turn it, allows you to shift into N and unlocks the steering, best method if you dont want to spend $$$ right away
my key broke wile i was at the mall, tried to get it started, long story short, undercover came, i explained the problem, gave my I.D. and then the cop told me how to pretty much steal a s10 blazer, he must know cause he got my truck running with a pair of sizzers so i could get home
what he said was to get a flat head screwdriver (about the size of the key hole), put it in the slot and use a 4lb sledge hammer to bang it in to break the pins, you do that and turn the screw driver to "start", you will be able to shift to N and unlock the steering assuming all goes as planned
your gunna have to buy a new egnition switch anyway due to you not having a key, and like you said, "its not running" so you wont have a problem with someone trying to steal it, lol
Old 11-07-2009, 08:20 AM   #12
thanks guys
jtcfanof3: i used to own a 1987 s10 i picked it up for $200 and fixed it and sold it for $1000 so this site is not new to me.
Old 11-07-2009, 05:26 PM   #13
forum idiot
orangesonoma's Avatar
drag it out with a winch onto a roll back
Old 11-07-2009, 09:37 PM   #14
1st Gen Mod
fetuss10's Avatar
^ i agree
Old 11-08-2009, 06:51 PM   #15
forum idiot
Quote: Originally Posted by fetuss10
^ i agree
thats a first
Old 11-10-2009, 06:44 PM   #16
Just go to auto parts store and get a steering wheel puller and a lock plate compressor and remove the ignition lock.Your going to have to do it any way.Its easy
Page generated in 0.58015 seconds with 31 queries
[Output: 90.04 Kb. compressed to 83.44 Kb. by saving 6.60 Kb. (7.33%)]
