no indicator lights for shifting 4 wheel drive on 2000 Blazer - S-10 Forum
post #1 of 6 Old 10-27-2011, 07:18 PM Thread Starter
User is: big dog babbs is offline
I lost capability to shift into 4 wheel not a light is lit. Checked all related fuses for system, pulled tccm out and checked for corroded terminals. Pulled out switch and checked for power to switch is ok. Any suggestions out there. I think it"s probably the tccm.
post #2 of 6 Old 10-29-2011, 10:40 AM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
Re: no indicator lights for shifting 4 wheel drive on 2000 Blazer
Have you checked for ground? You say you have power but you also need a ground.......
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
post #3 of 6 Old 11-03-2011, 06:07 PM Thread Starter
checked power at switch ok. checked for grd. at switch ok. decided it is probably switch. ordered and installed. same problem. no lights on switch. is there a reset procedure? currently I have battery disconnected to try reset.
post #4 of 6 Old 11-03-2011, 07:07 PM
jtcfanof3's Avatar
Let me pull up a diagnostic procedure tomorrow on AllData, it may be an encoder motor issue, Etc.
post #5 of 6 Old 11-04-2011, 08:35 PM Thread Starter
Did you get any more info on my problem? I'm ready to take to dealer for diagnosis.$$$
post #6 of 6 Old 01-05-2012, 04:25 AM
User is: jtaylor304 is offline
did you find out what the issue is because i am currently have somehwat the same problem. it just started getting below 32* around here and once it hits raound 20* my service 4x4 light comes on in my dash and by indicator lights won't come on at all but once i sat it in teh garage for a hr or two to try and trace vacum lines to see if it was a leak(which i found nothing). i pulled it out and everything was good again
