New Blazer
Go Back   S-10 Forum > Specific Model Forums > 1st Gen Forums > Blazer / Jimmy / Bravada
Old 10-31-2009, 12:14 PM   #1
New Blazer
I just bought a new Blazer.
Maybe a few of you can help me out.
My steering seems loose .
What would that be and how do i ADJUST IT . Its really loose ide like the wheel to be stiffer. Now if I let go of the wheel the blazer steers straight it does not jump left or right .
Also It has ABS can I take that out it dose not work and I just dont want it.
Were can I buy a AC delete pulley?
I also am trying to find a digital dash , the only one I found are on ebay and there alot.
Old 10-31-2009, 03:22 PM   #2
Re: New Blazer
steering i have no clue on
ditto on abs
napa, autozone ect have the delete pulleys, ebay too, ive got links for the 2.8 motor if you want, digital dash depends on your year blazer, i beleave that the 91 and down have the mechanical speedos and its a hassle to swap out, the non mechanical ones ive heard are plug and play
Old 10-31-2009, 09:05 PM   #3
Re: New Blazer
ditto on abs
Na 89+ have the Vss So Im good.
Thanks for the info on the pulleys .
Old 10-31-2009, 09:27 PM   #4
mrtibbs's Avatar
Re: New Blazer
Do a search on abs. There is a post here thats will tell you how to take it out
Old 10-31-2009, 10:10 PM   #5
Re: New Blazer
Do you have experience removing one? cant be that have right?
Old 11-01-2009, 12:20 AM   #6
Busy at school
jtcfanof3's Avatar
Re: New Blazer
Steering, or steering wheel is loose?
Ok, what motor do you have? They do not make a AC delete pulley for a 2.8, I used the one they say works, trust me it does not, I fabed some brackets for it to work.
What year is your Blazer, then I can answer the ABS question.
As far as the digital cluster, ya it's kool, but it gets old and tends to go bad all the damn time, i swapped in one in my old 91 Noma, went through 3 over a 2 year time period. You can swap one in, but you need to get a connector from the donor vehicle, analog gages use a different connector. You need to be able to do some wiring, are you up to the task?
Old 11-01-2009, 01:55 AM   #7
Re: New Blazer
really? dang that sucks, i think ill just gut my compressor or turn it in to an air compressor and hook up some train horns to it
Old 11-01-2009, 05:31 AM   #8
I am sofa king we tod did
nd4spd18's Avatar
Re: New Blazer
What year is it and what motor does it have.
I have seen the AC delete pully for the 4.3 in auto parts stores. For the dash, as said the connectors are different so you'd have to do some rewiring. The steering loose, thats just how these trucks are, up to 1 inch of play in the steering wheel is normal. Its an old steering box setup, not real responsive like the rack and pinion on todays cars.
Now the ABS if it's the 4 wheel abs with the big unit mounted to the fender, just unplug the wiring connectors from it, that will disable the ABS and no lights on the dash will come on. I did just that on my truck when that crap ABS system broke.
Old 11-01-2009, 05:58 AM   #9
Re: New Blazer
I have a 4.3 ,
Why not remove the system after unplugging it?
Old 11-01-2009, 10:49 AM   #10
Busy at school
jtcfanof3's Avatar
Re: New Blazer
Then you can use the AC delete pulley w/o modifications.
One inch of play, dude you need a new idler arm then, I have almost no play in my three first gen Blazers.......
Here is that A/C bypass on my 2.8, it can be done:
Old 11-01-2009, 01:23 PM   #11
Re: New Blazer
Ya I have a 4.3 have you been reading the thread?
Old 11-01-2009, 04:24 PM   #12
Busy at school
jtcfanof3's Avatar
Re: New Blazer
Yes I have, I was not refering to you when I posted the 2.8 pic, that was for renswic. If you look then you can see I said "then you can use the bypass pulley w/o modification".
Are you reading the posts?
Page generated in 0.56850 seconds with 31 queries
[Output: 77.84 Kb. compressed to 72.70 Kb. by saving 5.15 Kb. (6.61%)]
