Need Ignition Switch assistance please.
Have new ignition switch. Gotta pull the wheel cuz it has tilt steering. Any links to a how to that anyone knows of? It's my daily & i cant be w/out it for long.
93 blazer 4door 4wd 4.3l w Thanks in Advance guys! |
Re: Need Ignition Switch assistance please.
how to pull the wheel?
Take off the center cap on the steering wheel. Loosen the nut in the middle of the wheel. Go to autozone and get a wheel puller Strap the puller around the wheel and center the puller over the bolt where you took the nut off And tighten the puller with a wrench tell it pops off. |
Again, thanks for the quick response WORD! Ryan |
Crazy for a square body
I can post some pictures after i get home from work around 6pm or so. I have some showing it taken apart that might help. If you have all the tools it can be done in a day. Mine took two because i didn't have everything and had to make a stop by the store.
Are you replacing the switch or the cylinder assembly?
The job wasn't too bad. Unfortunatly, i pulled the horn's spring loaded ground clip to hard when i took the cover off & broke the plastic notch. Now, no horn. I have another parts s-10 I can take it from there. But that is 2 steering wheels & pressure plates to remove just to have a horn. anyone know any quick fixes? I guess i could cut another notch w/ a hot knife.......... I also took pics if anyone would care to see. |
Lol,i did the same thing with the horn. I also didn't get my hi-beams hooked up so now when i pull back it won't click and go on the hi-beams.
"The Recruiter"
Kiko,your rod is out of the end on the high beam switch under the dash.
"The Recruiter"
Ya,you should be able to get the rod back into the switch w/o pulling things apart,its got enough free play that it should slip back in,I did once after pulling things apart then realizing I didnt have it back in after buttoning things up.
What is that anyway? A spring to make the highs click on? The handle for wipers,CC, & blinker all work fine......but the high beams never worked ever since i got It. Would love to hear a quick fix! |
"The Recruiter"
Ya,there is a rod that runs along the side of the column that goes into a push button switch,most likelly its out of position.
