How low can you go ?
Go Back   S-10 Forum > Specific Model Forums > 1st Gen Forums > Blazer / Jimmy / Bravada
Old 11-05-2009, 07:26 PM   #1
I just bought a 94 blazer 4 door and am wondering how low can I go before i have to c notch it ?
It sits level at 32" to top of wheel arch, I'm thinking a 5/4. Any and all sugestions considered.
Thanks guys
Philip
Old 11-05-2009, 08:18 PM   #2
Busy at school
jtcfanof3's Avatar
Re: How low can you go ?
I'm at 4 in the back on my 2 door and no notch, but if you go lower then that you should atleast put in a bolt in small notch.
Old 11-05-2009, 08:24 PM   #3
thanks for the info
how much travel do you have back there ?
Old 11-05-2009, 09:31 PM   #4
Busy at school
jtcfanof3's Avatar
Couple inches before the bumpstops roughly.
Old 11-05-2009, 11:04 PM   #5
Blazin across Fort Worth!
93_Blaze's Avatar
Hard bottom outs? What did you use to drop it?
Old 11-05-2009, 11:10 PM   #6
Half-Bagged for now
leroyme's Avatar
I had to remove the bump stops (not hard to do, just gotta have a torch or a cutoff wheel) with 4" drop in the rear. I used drop blocks. If you only use blocks, you don't need drop shocks. If you use lowering springs, you need drop shocks.
Old 11-05-2009, 11:13 PM   #7
93_Blaze's Avatar
I see... does anything have to be adjusted when using 4 inch blocks to comply with driveshaft? About how much of a drop does pulling a leaf give?
Old 11-06-2009, 09:24 AM   #8
Busy at school
jtcfanof3's Avatar
Pulling a leaf is ~ 1.5 inch drop. Ya I used four inch angled blocks, I still have my bump stops, but that is because I still have a full exhaust and I don't want to bang the axle against the exhaust, besides I don't hit the bump stops much unless it's a big bump.
Old 11-06-2009, 11:57 AM   #9
Day Dreamin
lohenslohe's Avatar
if where your around the most is bumpy, your going to get harsh bumps (also how fast you drive). I had 4" blocks on mine and got pissed each time I went "donk" in the back. Suicide Doors has a bolt in c-noth that accommodates the crooked frame. For my bump stops, I used a cut off wheel and grind wheel to clean up the left overs.
Page generated in 0.56563 seconds with 31 queries
[Output: 68.55 Kb. compressed to 64.45 Kb. by saving 4.11 Kb. (5.99%)]
