Hissing Noise From Heater Control - S-10 Forum
post #1 of 13 Old 04-08-2007, 07:28 AM Thread Starter
User is: Chain Saw is offline
What do I hear a hissing noise from my heater/AC control? Is this normal?
post #2 of 13 Old 04-08-2007, 08:00 PM
tmitbyh's Avatar
User is: tmitbyh is offline
Re: Hissing Noise From Heater Control
I just purchased a 1994 S-10 Blazer and mine does the same thing.
tmitbyh is offline
post #3 of 13 Old 04-08-2007, 09:08 PM Thread Starter
I replaced my heater control assy. with the same results. Kinda thinking it might be a cracked vac. line or the heater control I just replaced (used) has the same problem.
post #4 of 13 Old 04-08-2007, 09:12 PM
import killer
syclonekid43's Avatar
User is: syclonekid43 is offline
Send a message via AIM to syclonekid43 Send a message via Yahoo to syclonekid43
mine does the same problem.
91' syclone (0465)
88' tuneport gta
93' 4dr jimmy
93' blazer
88' s-10 blazer (2 wd)
01' raptor
97' mxz 670 yamaha ysr 50 with a 125 cc 6-speed
THE SURGEON GENERAL WARNING NEVER SAID ANYTHING ABOUT SMOKING A FORD
post #5 of 13 Old 04-08-2007, 10:02 PM
User is: Dave_The_BMXER is offline
I had the same problem, but replacing the control fixed it.
Stanceiseverything.com
91 Black 2wd, 2dr.
System,5/6'd Notched, Irocs
Broken into and destroyed.
post #6 of 13 Old 04-08-2007, 10:55 PM
4x4 v6 blazer
neo71665's Avatar
User is: neo71665 is offline
This is gonna be a guess but it sounds like the vac line on the back of the switch are not making a good seal.
neo71665 is offline
post #7 of 13 Old 04-09-2007, 05:45 PM
Mr. Sparkle
Onimun's Avatar
User is: Onimun is offline
Thats normal. Its the Vaccum being created to shift Modes. If that made any sence at all
Onimun is offline
post #8 of 13 Old 04-09-2007, 05:49 PM
forum idiot
orangesonoma's Avatar
yeah you hear noise during the shift but not all the time..i say crack or the vacuum plug is not seated correct..
Brian
orangesonoma is offline
post #9 of 13 Old 04-09-2007, 08:35 PM Thread Starter
I hisses all the time. Not just between shifts. When I get the time I will remove the heater control and plug all the vac. lines and listen.
post #10 of 13 Old 04-09-2007, 08:47 PM
User is: Criticalbeatdown95s is offline
All it's doing is moving the vents open/close
post #11 of 13 Old 04-09-2007, 08:50 PM Thread Starter
Yea I know but the problem I am after is that the heat flapper does not work. I thought maybe to fix the hiss problem first then find out why the heat flapper doesn't work.
post #12 of 13 Old 04-09-2007, 08:52 PM
1st gen...i'd change the controls out then also.
post #13 of 13 Old 04-09-2007, 09:07 PM Thread Starter
I bought a used one and replaced it. Did the same thing. Not to say the new used one isn't bad also. I've seen that before.
