93 jimmy no start
Go Back   S-10 Forum > Specific Model Forums > 1st Gen Forums > Blazer / Jimmy / Bravada
Old 06-23-2008, 09:53 PM   #1
97 4 bangin'
sexytruck21's Avatar
sexytruck21 is on a distinguished road
93 jimmy no start
my buddy has got a 93 jimmy 4x4 that wont start. it cranks and cranks but wont fire. the truck was running fine (as fine as it could i guess) on the way to work when it just died, at 75 mph on the freeway just shut off. Still have power in dash lights etc. the fuel pump was replaced a lil over a month ago and fuel filter last week. cap and rotor done right before fuel pump. I have no idea where to go next. please help. with gas the way it is and me losing my car pooling buddy i need it to run.
Old 06-23-2008, 10:00 PM   #2
I lead the blind
Speedy2222's Avatar
Speedy2222 can only hope to improve
Re: 93 jimmy no start
did it run out of gas? is it getting gas? spark?
Old 06-23-2008, 10:06 PM   #3
97 4 bangin'
spark for sure its about 60 miles into a full tank and its getting gas but still have yet to test fuel pressure. i depressed the test valve with a small screw driver while cranking and got a 2 inch high burst and that was it.
Old 06-23-2008, 10:07 PM   #4
I lead the blind
Speedy2222's Avatar
pull some plugs n see whats up with em..
Old 06-23-2008, 11:15 PM   #5
sparks383iroc's Avatar
sparks383iroc is on a distinguished road
Possible pickup coil. Did you actually test for spark at the plug? Mine did the exact same thing and that was what it turned out to be.
Old 06-24-2008, 04:38 PM   #6
97 4 bangin'
i checked for spark off the distributer wire, will check plugs and wires prolly just replace im not buying parts will get back to you.
Old 06-24-2008, 05:24 PM   #7
fodobaggins's Avatar
fodobaggins is on a distinguished road
I've even seen the plug come off the coil and cause the same problem!
Old 06-28-2008, 11:00 PM   #8
97 4 bangin'
ok heres the update, now i really need help. Bought fuel pressure guage and found i have 58-60psi. changed plugs, wires, cap and rotor. nothing happened. tryed starting fluid truck fired for a few seconds and nothing. so now im stuck and have no clue where to look next. I'm thinking injectors or pcm. thanks again much appreciated.
Old 07-01-2008, 09:32 PM   #9
Well if it tried to run after starting fluid and you have 50-60#s of pressure, I would guess you have a non-functioning spider injector.
Old 07-09-2008, 09:25 AM   #10
xtremebilly's Avatar
xtremebilly is on a distinguished road
same exact thing happened to me a month ago. did everything you did. found out it was the ignition control module. try replacing that. then my 89 started right up.
Old 07-14-2008, 08:08 PM   #11
Bill Wheats's Avatar
Bill Wheats is on a distinguished road
When you check for spark, you need to see continuous spark, not just one spark.
Page generated in 0.11236 seconds with 11 queries
