4wd #15 (10 amp)blowing '98 Blazer - S-10 Forum
post #1 of 4 Old 12-22-2009, 11:18 AM Thread Starter
User is: sobtom is offline
Fuse #15 (10 amp) blows and takes with it the temperature gauge, shift indicator light, and fuel gauge. Also the 4wd buttons no longer light up and the 4wd doesn't work. What's the likely cause?
Thanks
sobtom is offline
post #2 of 4 Old 12-22-2009, 07:30 PM
User is: MadMikeZ28 is offline
Re: 4wd #15 (10 amp)blowing '98 Blazer
Maybe ask this in the second gen section.
If I acted like some of the people here do and ran to someone when ever my feelings were hurt I would have been called a sissy and then ridiculed for that as well. I suppose I just grew up in a time when we were all tougher and turned out to be men and women instead of staying crying children.
post #3 of 4 Old 12-24-2009, 02:51 PM
User is: cauzindrama is offline
I bet a short is cauzin it
post #4 of 4 Old 12-27-2009, 07:27 PM
ASE certified MasterTech
jtcfanof3's Avatar
User is: jtcfanof3 is offline
Send a message via AIM to jtcfanof3
A short to ground or a high amperage draw, you need to check the amerage at that fuse if you have a multimeter. If the draw is not more than it's supposed to be you likely have a short to ground. Use a test light and connect one side to a 12V + source, then touch the fuse with the end of the test light(even though it is blown)(top of the fuse has two little windows on the top of the fuse) and if it lights up you found which side has the short. Then you need to trace the wiring.
1989 Chevrolet Blazer 3.4
1989 Chevrolet Blazer 4.3 4x4
1989 Chevrolet Blazer 4.3 Edelbrock equipped
2003 Chevrolet S10 4.3
1999 Chevrolet S10 Xtreme 2.2
