1st gen Blazers; post pics here
Go Back   S-10 Forum > Specific Model Forums > 1st Gen Forums > Blazer / Jimmy / Bravada
LinkBack (1) Thread Tools
Old 07-21-2007, 09:18 PM   #501
Street Issue Customs
low-blazer's Avatar
low-blazer
Re: 1st gen Blazers; post pics here
Guess I'll throw up a couple of mine...it's been a while since I posted over here anyway..
very far from done, but at least she's drivable Hoping to have the body work done and it torn down for paint this winter..
Old 07-21-2007, 09:35 PM   #502
SFBD 4 door
TrYiN2LaYaDiMe's Avatar
TrYiN2LaYaDiMe is on a distinguished road
damn that looks hot with them boyd's
Old 07-21-2007, 09:46 PM   #503
Day Dreamin
lohenslohe's Avatar
lohenslohe is on a distinguished road
Quote: Originally Posted by TrYiN2LaYaDiMe
up keep = maintance
is there anything wrong with the air ride system?????
no not really. It's just that I need money for a fuel sender, and to get that stupid passenger door open. Sender is about $100 or so, but the fixing the door, I'm not sure.
Old 07-21-2007, 10:47 PM   #504
SFBD 4 door
a sender 100 bucks. wow never looked into one of those. but ill tell ya this a sender only filters and holds the pump. the pump is what would be bad if ur not getting fuel
if u got a bad unit ull know cuz it will work or it wont plain and simple.
Old 07-21-2007, 10:59 PM   #505
Day Dreamin
lohenslohe's Avatar
lol, nah the pump is fine, the gauge isn't reading the gas levels right at all. When it's like almost empty it reads around where it should be full or some gas in the tank. When it's pretty full or something in the tank, it reads like it's empty.
Old 07-21-2007, 11:11 PM   #506
Dead Project Truck
rivbluenoma's Avatar
rivbluenoma
You might pull the gauge cluster and look at the back of it, see if theres anything wrong with the flexible plastic "ciruit board" that runs all of the gauges. The gas guage on my old sonoma acted the same way. Turned out the previous owners kid had layed a chocolate popsicle on the dash one hot summer day and forgot about it. Guess it melted and ran down behind the gauge cluster and gooped up the "circuit board" deal back there. I had a spare gauge cluster sitting here, popped it in the dash to see if that fixed it and no more problems.
Old 07-21-2007, 11:39 PM   #507
Day Dreamin
lohenslohe's Avatar
easier said than done though.
Old 07-22-2007, 12:22 AM   #508
Dead Project Truck
rivbluenoma
Its not that difficult. A couple hours work might save you $100. And its a lot easier than dropping a tank and changing out the fuel sender, especially if the new sender doesnt fix the problem.
Old 07-22-2007, 12:26 AM   #509
Day Dreamin
lohenslohe's Avatar
okay you talked me into it. I'm going to have some free time maybe not this Tues, but the next. Could you give me a step by step on how to go about taking the dash out and what I need to check for? I would take it to a shop, but I don't got much funds and I like doing it on my own so I can do it again if needed ya know?
Old 07-22-2007, 12:53 AM   #510
Dead Project Truck
rivbluenoma
You dont take the whole dash out, just the gauge cluster. You have to pull off the headlight switch panel and disconnect it, pull out the hvac panel--you may be able to get away with not disconnecting it, Im not sure. Disconnecting the heater/ac controls is kind of a bitch to do without breaking anything. Maybe some one else has a suggestion for that part? After all of thats out of the way remove the 4 nuts holding the housing to the dash. Pull the gauge cluster housing off and then you can unbolt the cluster and remove it from the dashboard. Dont forget to remove the little clip that runs from the gauge cluster to the steering column before removing the cluster. Otherwise youll break the little wire and your gear inidcator on the dash wont work any more. Before pulling the cluster out, mark where the little metal clip on the column is sitting so you can get it back into the right spot later without wasting time trying to get it adjust it correctly.
Old 07-22-2007, 12:58 AM   #511
Day Dreamin
lohenslohe's Avatar
I tried taking out the heater controls, it didn't happen at all. It's too jammed in there. I was affraid of breaking something so I just didn't bother and put it back. I'm gonna see if I can find someone to elp me out on this. If anything, hopefully someone that likes beer will do it for me.
Old 07-22-2007, 01:34 AM   #512
SFBD 4 door
if u lived closer id help ya you seem like u need some help lol..........damn females hahahaha. but seriously id help you on the door and any other thing u had to fix and best of all i dont charge just some mountain dew is all i ask.
Old 07-22-2007, 05:17 PM   #513
Oaktown Trucks
Mystic_Knight's Avatar
Mystic_Knight is on a distinguished road
Looking good Doug. I can't wait to see it painted.
Here's my truck at Draggin' Detroit last weekend. I took 2nd place for under construction. All the led's on the truck were bought from Doug @ Street Issue Customs.
This is a pic of the led's out back. Kind of dark but I'll try getting a better pic tonight with them lit.
Old 07-22-2007, 09:55 PM   #514
STREETSQEG's Avatar
STREETSQEG is on a distinguished road
I Havent Been On Here For A Wile So I Guess Ill Try And Throw A Few Of Mine Up Im About To Put It Back Under The Knife And Try To Finish Up The Frame And Body .....http://www.streetsourcemag.com/issue...PM29401_tn.jpghttp://http://www.streetsourcemag.co...PM92341_tn.jpg
Last edited by STREETSQEG : 07-22-2007 at 10:25 PM. Reason: TRYING TO MAKE PICTURES WORK AGAIN....
Old 07-22-2007, 10:09 PM   #515
STREETSQEG's Avatar
Sorry My Html Skills Suck Big Time
Old 07-22-2007, 10:20 PM   #516
SFBD 4 door
baldwyn is where at in mississippi??? how far from jackson or tunica????? and what rear is that it dont look like a 1st gen blazer...
Old 07-22-2007, 10:22 PM   #517
STREETSQEG's Avatar
Its About A 2 Hour Drive North Of Jackson And About A 2 And Half Hour Ride From Tunica... Its Close To Tupelo If That Helps Any.... No The Rear Hatch Is Off Of A 2003 4-runner ....
Old 07-22-2007, 10:35 PM   #518
SFBD 4 door
awe my girls sister lives in tupelo and her parents own a business is dorcey so ya i know the area.
the hatch work looks good. might have to stop over and see it when i get to tupelo again. u near 78????
Old 07-22-2007, 10:41 PM   #519
STREETSQEG's Avatar
Thanks Man... But Naw Man Im About 20 Miles North Of 78 Up In The Sticks ..... But Hey If Your Welcome To Ride Out When You Out This Way Its Easy Directions....
Old 07-22-2007, 10:42 PM   #520
SFBD 4 door
cornith or iuka area or not that north. i hate iuka, when i come in from alabama i come in 78 all the way into tupelo
Old 07-22-2007, 10:52 PM   #521
STREETSQEG's Avatar
No Thats To Far North I Dont Blame Ya About Iuka Corinth Is About 30 Or 40 Miles Past Were I Live.... Ive Got A Some Friends Over In Alabama I Think They Live Over In Huntsville They Use To Be In The Same Club As Me ....
Old 07-22-2007, 10:58 PM   #522
Dave_The_BMXER is on a distinguished road
Baby steps..
Old 07-22-2007, 10:59 PM   #523
SFBD 4 door
VC?? i know a few guys in huntsville but i dunno if u know them or maybe u do.... and ya iuka blows hahahaha
Old 07-22-2007, 11:03 PM   #524
STREETSQEG's Avatar
Ya Vc. Im The Pres Of The Mississippi Chapter.. The Few I Remember I Only Know There First Name So That Want Be Much Help Im Sure...
Old 07-22-2007, 11:08 PM   #525
SFBD 4 door
kerry, joey and i think thats all i know.
Old 07-22-2007, 11:08 PM   #526
SFBD 4 door
btw whats the requirements to be in VC
Old 07-22-2007, 11:17 PM   #527
STREETSQEG's Avatar
YA I REMEMBER KERRY I THINK HE USE TO BE THE PRES OF ALABAMA CANT REMEMBER THO.. BUT AS FOR JOINING VC YOU HAVE TO GOTO THE SITE WWW.VERTICALLY-CHALLENGED.COM AND GO INTO THE LOOKING TO JOIN FORUM AND TALK TO THE PRES OF THE STATE YOUR FROM AND GO FROM THERE .. WE HAVE REQUIRMENTS, LIKE YOU HAVE TO BE A PROSPECT FOR SO LONG, YOUR RIDE HAS TO BE MODIFIED EITHER BAGGED, MAJORLY DROPED OR JACKED WAY THE HELL UP, BODY MODS ...ECT..
Old 07-22-2007, 11:19 PM   #528
SFBD 4 door
ok
Old 07-22-2007, 11:28 PM   #529
Dead Project Truck
rivbluenoma
Quote: Originally Posted by Dave_The_BMXER
Baby steps..
That looks pretty good, got any daytime pics of it since the drop? How much is it dropped?
Old 07-23-2007, 10:40 AM   #530
No day time pics of that drop (5/6) I will post some up soon.
Here is a daytime 5/3 shot.
Old 07-23-2007, 12:55 PM   #531
lcplgideon's Avatar
lcplgideon is on a distinguished road
