Polishing Guru
How To Trenz Billet Grill Install
I am doing a Trenz Billet Grill install on my 1998 s10 that has an Envoy conversion. This how to will cover the grill only.
First picture is of the grill before any work was done. ![]() Last edited by samandjen1 : 12-28-2007 at 07:35 PM. |
Polishing Guru
Tools needed:
Polishing Guru
Remove the grill from the truck.
![]() Last edited by samandjen1 : 12-28-2007 at 07:37 PM. |
Polishing Guru
Ok time to get cutting.
First of all Trenz install instructions SUCK! They don't specify which lip to cut or leave! My first cuts were to remove the GMC letters and the bars that are in the center of the grill. I did this to make the grill easier to hold and to make it easier to cut the rest of the center out. Cuts were made at the red circles. ![]() Last edited by samandjen1 : 12-28-2007 at 07:37 PM. |
Polishing Guru
what you will have when done.
![]() ![]() Last edited by samandjen1 : 12-28-2007 at 07:38 PM. |
Polishing Guru
ok there is an about a 2" lip of plastic that needs to be removed so the grill will sit flush.
To make it easier to get a good final cut I removed most of the gray plastic and I left about a 1/2" To do this I used my Dremel tool with a cut off wheel. The area to be removed will be the gray area of your grill and in the end all you will have left is what is painted like the body color. ![]() ![]() Last edited by samandjen1 : 12-28-2007 at 07:42 PM. |
Polishing Guru
Whats left
![]() Last edited by samandjen1 : 12-28-2007 at 07:43 PM. |
Polishing Guru
Now you are left with a 1/2" to 1/4" lip.
If you have a chrome grill I high recommend you buy some blue masking tape and cover all the cover or you will scratch it up. To remove this I used the Dremel tool and cut relief cuts at the corners to make it easier to remove the corners of the lip. DON'T CUT TOO FAR and GO SLOW AND TAKE YOUR TIME! After I cut the relief cuts I took a razor and ran it along the edge between the painted and gray using the painted area as a guide to cut a straight line. Use a brand new blade. Do a couple of passes appling light pressure. Don't try to cut all the way through on the first pass after about 4-5 passes the the knife will cut all the way through very easy. USE CAUTION WHEN NEAR THE CORNERS! It is very easy to slip and cut to far into the painted surface(I did this but, the cuts will sand out) ![]() ![]() Last edited by samandjen1 : 12-28-2007 at 07:47 PM. |
Polishing Guru
what is left is the painted surface only.
I used the Dremel tool with a barrel sandpaper wheel, to knock down some of the ruff spots. ![]() Last edited by samandjen1 : 12-28-2007 at 07:48 PM. |
Polishing Guru
Ok, sorry for the delay. I was bizzy on Monday with the grill and removing my rear bump stops and it got to late to finish th thread.
So here we go after I used the dremel tool to remove the high spots I sanded the entire grill with 240 grit sandpaper to remove any scratches and razor slip ups.I also sanded down the seam mark form the mold when it was made. (where the hood release handle and spring is on the upper part of the grill). Then I sanded the entire grille with 320 grit sandpaper. I then test fit the grill.I mounted mine so that all bars would show.(see pic) ![]() ![]() ![]() Last edited by samandjen1 : 12-28-2007 at 07:50 PM. |
Polishing Guru
Trenz gives you pop rivots to mount the grill. But I did not use them I want to be able to remove the grill if I wanted to and make it easy to and not have to drill pop rivots out.
I used stainless steel bolt, nuts and washers. They are long and need to be cut down. I applied locktight the threads and doulbe nutted them for safety. The 4 mounting tabs need to be bent to match the contour of the grill. I just eyeballed it when I drilled the holes. The next couple of pics are of the mounting. ![]() ![]() ![]() Last edited by samandjen1 : 12-28-2007 at 07:52 PM. |
Polishing Guru
top pic of mounting bolt. one left and one on the right.
![]() Last edited by samandjen1 : 12-28-2007 at 07:53 PM. |
Polishing Guru
Pic of the grill mounted for a test fit.
![]() Last edited by samandjen1 : 12-28-2007 at 07:54 PM. |
Polishing Guru
Ok next i removed the trenz grille from the factory grill.
washed it down and dried it off applied a coat of primer when dry I wet sanded it with 400 grit and then 600 gritt used a tack cloth to remove dust primed and wet sanded again used a tack cloth to remove dust applied white color matched paint(they say it is matched) wet sanded with 600 grit ,washed,dried,and tach clothed applied 2nd coat white color wet sanded with 600 grit,washed,dried,and tach clothed applied 3rd coat white color wet sanded with 600 grit,washed,dried,and tach clothed applied 3 coats of clear. let factory grill sit in sun for about 3 hours then I reinstalled the trenz grill. Last edited by samandjen1 : 06-26-2004 at 12:45 AM. |
Polishing Guru
pic of new grill mounted!
![]() Last edited by samandjen1 : 12-28-2007 at 07:55 PM. |
Polishing Guru
another pic
![]() ![]() Last edited by samandjen1 : 12-28-2007 at 07:57 PM. |
Polishing Guru
Finished install pics.
![]() ![]() ![]() ![]() Last edited by samandjen1 : 12-28-2007 at 07:59 PM. |
Thanks a lot for the step by step, i too have the envoy front bumper, and at the moment i have the trenz grill laying in my living room. I'm looking forward to the lower grill install.
proud stepsider
yeah I am too; using the bolts instead of the rivets was a good idea
Polishing Guru
THE ANTIBOWTIE OUTKAST!!!
NICE :headbang:
Hardcore 1st Gen'r
very nice how to. i was going to get a speed grill for my highrider but i think i'm definately gonna go billet now.
miss me?
hey look u have the same truck as me.
#24 |
True Ambition
nice job
#25 |
Primer Spots
Re: How To Trenz Billet Grill Install
nice thats exactally how i did mine, alot of people install grills with that 2in of plastic without cutting it out i think flush is the way to go
#26 |
Strictly Domestic
Both of my Trenz grilles will be going in soon..Main grille and the one for the lower fascia... The main grille is all cut out and painted, just have to snap it off and put it in. SHould have pics soon.
#27 |
thanks for the step-by-step, i wasn't sure how the grille actually set in there, but now it is pretty much crystal clear.....
#28 |
xtremnut
Nice job bro. Well done.If I had a Sierra, I would use that.
#29 |
Polishing Guru
Updated chrome grill
![]() ![]() ![]() ![]() Last edited by samandjen1 : 12-28-2007 at 08:10 PM. |
