drag~N~spark
HOW TO TAKE OUT 3RD BRAKE LIGHT AND LENSE HOUSING
HERES WHAT TO DO, TAKES ONLY A FEW MIN. YOU CAN EITHER PUT A DIF LENSE IN OR SHAVE IT UP!! GOOD LUCK!:thumbup:
drag~N~spark
ok u need a t-15 bit the adapter and tool
drag~N~spark
all 3 put together..
drag~N~spark
unscrew counter clockwise..
drag~N~spark
drag~N~spark
tool and the 2 screws
drag~N~spark
lift brake lense up
drag~N~spark
lense gone
drag~N~spark
lense 2 screws and tool
drag~N~spark
How To Take Out 3rd Brake Light
TOOLS NEEDED ARE #2PHILLIPS SCREW DRIVER, 7MM SOCKET, PICK
THIS IS DONE IF U NEED TO REPLACE THE HOUSING, OR IF YOUR GONNA SHAVE THE 3RD BRAKE LIGHT. THE DOME LIGHT IS ATTACHED SO ITS A GOOD IDEA TO SCRAP THAT UNLESS U REALLY NEED IT. ALL THIS CAN BE DONE FROM INSIDE THE CAB. THESE PICS ARE TAKEN AFTER THE 3RD BRAKE LIGHT HAS BEEN REMOVED, BUT IF U FOLLOW THE INFO AND PICS U WONT HAVE A PROB, HERES PICS.. |
drag~N~spark
Tools
drag~N~spark
Pull the plastic lense
drag~N~spark
Pulling away
drag~N~spark
Where my 2 fingers are pointing use the #2 phillips screwdriver
drag~N~spark
Unscrew pass. screw
drag~N~spark
Unscrew drivers screw
drag~N~spark
The 2 phillips screws out
drag~N~spark
Pull the chrome plate
drag~N~spark
Pulling away
drag~N~spark
Take the 7mm socket
drag~N~spark
Unbolt the pass. side screw
drag~N~spark
Unbolt the drivers side screw
drag~N~spark
2 7mm screws out, from the inside push the 3rd brake light housing up and with a pick pull on the edge of the housing and it will come out, do this carefully.
#24 |
drag~N~spark
This plate is behind the 3rd brake light lens and housing inbetween the outside and inner cab metel, lift up and pull out
#25 |
drag~N~spark
All 3 pieces
#26 |
drag~N~spark
