How To Relocate Tail Gate Handle To The Inside
Go Back   S-10 Forum > General Tech > S-Series How-To > Exterior How-To
Old 07-04-2003, 12:01 AM   #1
drag~N~spark
DropindaS-Mini's Avatar
Click this link http://www.buildyourride.com/tech/relocatortemp.doc to get the template. You can buy the tail gate kit from Sir Mic's. or from FBI, or get the kit from EMA Customs out in Cali. like I did. Then follow these pics and in less then 1 HR. you can have the handle to the inside. After you relocate the handle you can then shave the outside.
Old 07-04-2003, 12:04 AM   #2
drag~N~spark
Take tail gate off and put on some saw horses..
Old 07-04-2003, 12:10 AM   #3
drag~N~spark
another shot
Old 07-04-2003, 12:12 AM   #4
drag~N~spark
Use a socket and a t40 bit.
Old 07-04-2003, 12:14 AM   #5
drag~N~spark
Unscrew them
Old 07-04-2003, 12:16 AM   #6
drag~N~spark
Bolts unscrewd
Old 07-04-2003, 12:18 AM   #7
drag~N~spark
Now go to the sides of the tail gate and use the same socket and t40 bit and unscrew the 2 bolts on boths sides.
Old 07-04-2003, 12:20 AM   #8
drag~N~spark
Unscrew top bolt.
Old 07-04-2003, 12:22 AM   #9
drag~N~spark
Unscrew bottom bolt.
Old 07-04-2003, 12:24 AM   #10
drag~N~spark
Top and bottom bolts unscrewd
Old 07-04-2003, 12:28 AM   #11
drag~N~spark
Now flip the tail gate on the other side and pop the trim thats around the tail gate handle, pull it off and then pull the handle up and unclip the 2 clips that hold the rods then lift the rods off the handle and pull the handle out.
Old 07-04-2003, 12:30 AM   #12
drag~N~spark
Tail gate handle out of the tail gate.
Old 07-04-2003, 12:33 AM   #13
drag~N~spark
Pull the rods up and slide some cardboard under it so u dont loose them inside the gate.
Old 07-04-2003, 12:36 AM   #14
drag~N~spark
Slide out the latches and rods both left and right sides. Make sure u dont drop the rods or disconnect them from the latches, lay the rods on the floor the same way they are in the tail gate.
Old 07-04-2003, 12:37 AM   #15
drag~N~spark
Pull out the other side and lay on the floor.
Old 07-04-2003, 12:39 AM   #16
drag~N~spark
Both rods layin on the ground. Make sure the rods come off the latches.
Old 07-04-2003, 12:44 AM   #17
drag~N~spark
Now flip the tail gate back over and check out the area where the 3 bolts u had taken out are.
Old 07-04-2003, 12:47 AM   #18
drag~N~spark
Get some tape, a razor, and a pen or marker.
Old 07-04-2003, 12:49 AM   #19
drag~N~spark
Now take the template u printed out from the link in the first post, and check it out.
Old 07-04-2003, 12:52 AM   #20
drag~N~spark
Now after u read the printout/template, tape it to the area it says listed.
Old 07-04-2003, 12:54 AM   #21
drag~N~spark
Now take the razor and cut out the dot-dot line, and cut that section out.
Old 07-04-2003, 12:57 AM   #22
drag~N~spark
Dot-dot section ready to pull out.
Old 07-04-2003, 12:59 AM   #23
drag~N~spark
Pull the cut section out.
Old 07-04-2003, 01:03 AM   #24
drag~N~spark
Nother shot.
Old 07-04-2003, 01:06 AM   #25
drag~N~spark
Cut section gone.
Old 07-04-2003, 01:08 AM   #26
drag~N~spark
Nother shot.
Old 07-04-2003, 01:12 AM   #27
drag~N~spark
Now take the pen. or marker and go all along the edge, making sure u hold the edge so it doenst move around.
Old 07-04-2003, 01:14 AM   #28
drag~N~spark
Top right and go down to the bottom.
Old 07-04-2003, 01:16 AM   #29
drag~N~spark
Bottom right to bottom left.
Old 07-04-2003, 01:18 AM   #30
drag~N~spark
Then bottom left to top left.
Old 07-04-2003, 01:21 AM   #31
drag~N~spark
Just a pic of me LOL
Old 07-04-2003, 01:25 AM   #32
drag~N~spark
Ok now u can take a cut off wheel on an air tool or use a Dremel.. I decided to use the Dremel cause I have mad cuttin skills, just check out my Maltese Cut Crosses cut in the roll pan of my s10!
Old 07-04-2003, 01:28 AM   #33
drag~N~spark
Now start cuttin!!
Old 07-04-2003, 01:30 AM   #34
drag~N~spark
This pic shows half cut.
Old 07-04-2003, 01:32 AM   #35
drag~N~spark
Now put something (i used a piece of cardboard) under the half cut section so it wont bounce around and once cut wont fall in the tail gate.
Old 07-04-2003, 01:36 AM   #36
drag~N~spark
This pic shows the metal almost cut except a tiny section in the upper left corner.
Old 07-04-2003, 01:38 AM   #37
drag~N~spark
Lift up the cut metal.
Old 07-04-2003, 01:40 AM   #38
drag~N~spark
Pull the metal out and either scrap it or save it for w/e.
Old 07-04-2003, 01:43 AM   #39
drag~N~spark
Now I cut the plate out but left about a 1/4" left to be trimmed so the final cut will be hella smooth.
Old 07-04-2003, 01:46 AM   #40
drag~N~spark
Close up shot after the first cut.
Old 07-04-2003, 01:47 AM   #41
drag~N~spark
Now the final cut has been made and its really smooth.
Old 07-04-2003, 01:49 AM   #42
drag~N~spark
Handle housing
Old 07-04-2003, 01:53 AM   #43
drag~N~spark
Handle housing 2
Old 07-04-2003, 01:54 AM   #44
drag~N~spark
Handle housing 3
Old 07-04-2003, 01:56 AM   #45
drag~N~spark
Handle housing 4 showing the welds.
Old 07-04-2003, 01:57 AM   #46
drag~N~spark
Now put the handle housing in the tail gate.
Old 07-04-2003, 02:01 AM   #47
drag~N~spark
Looking inside the handle housing.
Old 07-04-2003, 02:03 AM   #48
drag~N~spark
Now take the handle housing out and then take the handle and line up the 3 holes both on the handle and the handle housing.
Old 07-04-2003, 02:04 AM   #49
drag~N~spark
Nother shot.
Old 07-04-2003, 02:06 AM   #50
drag~N~spark
And another.
Page generated in 0.68627 seconds with 32 queries
[Output: 211.68 Kb. compressed to 190.06 Kb. by saving 21.62 Kb. (10.21%)]
