hinge pin/bushing replacement
Go Back   S-10 Forum > General Tech > S-Series How-To > Exterior How-To
Old 04-17-2004, 01:00 PM   #1
Blown Mod
Jess's Avatar
i did mine yesterday. a while back i tried doing it with the lower pin still in, but the top hinge would not move apart far enough to get the bushings out. so the door needed to be seperated from the body. as you probably know, a door is not light, or easy to handle. so i made a jig to hold the door. it worked VERY well. so if you have no one to help you, this is the way to do it. if you have help, a floor jack w/rags and 2 buddies could work ok.
so, build a jig like this, pic 1 . then remove the little washers that hold the pin on. i used a door spring tool for the spring, i didn't want to pry it out and damage the paint. then hammer the pins out. then get the bushings out, pliers and a very sharp screwdriver are what i used. move the door away from the body.
i used pliers & hammer/punch to put the new bushings in. make sure you note how they came out & put the right one in the right place. there are 2 different bushings, test them on the pin first.
move the door back into place. hammer the pins in. replace the retaining washers. put the spring back in.
oil them up and your done.
its not as hard as it sounds.
Page generated in 0.56416 seconds with 32 queries
[Output: 41.51 Kb. compressed to 40.14 Kb. by saving 1.37 Kb. (3.30%)]
