DRL and AHL "how to"
Go Back   S-10 Forum > General Tech > S-Series How-To > Exterior How-To
LinkBack (13) Thread Tools
Old 08-16-2002, 11:09 PM   13 links from elsewhere to this Post. Click to view. #1
I BURN THINGS
Flamed 98's Avatar
Flamed 98 is on a distinguished road
Post How to disable DRL and AHL
How to disable AHL and DRL
99 and up AHL
Remove passenger side speaker grill on dash. Unplug wire from the light sensor (little ball sticking up from the grill). Insert 2.2k Ohm 1/2 watt resistor into plug, and use a zip tie to strap the plug down to the dash. Reinstall grill.
98 AHL
Remove passenger side speaker grill on dash. Unplug wire from the light sensor (little ball sticking up from the grill). Insert 680 Ohm 1/2 watt resistor into plug, and use a zip tie to strap the plug down to the dash. Reinstall grill.
98 and up DRL
Remove the cover on the fuse box under the hood. Locate the DRL relay. Locate pin 87A and 30 on the relay. DO NOT MODIFY PINS 87A OR 30. Bend or cut the other pins off the relay. ( I recommend bending the pin incase you bend the wrong one, you can always straighten it). Then plug the realy back in and check to make sure the DRLs are off and you still have high beams.
94 - 97 DRL
If you don't have factory fog lights just pull fuse #15.
If you have factory fog lights...
Originally posted by trruuck
Tell you what, I just did this mod yesterday.
If you don't have factory fog lamps, pull the #15 fuse. But if you have the foglamps, here is how you do it:
First, disconnect the battery so you don't shock yourself (trust me, I learned the F-ing hard way)
Second, you need to pull of the front of the dash (take out the two screws in the cluster area, then just pull it off.
Then unscrew the fuse box. Locate the #15 fuse on the back of the fuse box. You will notice, there is one orange wire in, and two orange wires out. the two going out is what you focus on. One is for the fog lights, and the other is for the DRL's. Cut one, connect the battery and turn the ignition on. Pull the e-brake. If the DRL's are off, GOOD GUESS!! If you cut the wrong wire, connect the wire you just cut, and cut the other one. Your done and enjoy.
All of this will work on the S-10, Sonoma, Blazer and Jimmy (not sure about the Envoy's)
Old 11-14-2002, 02:31 PM   #2
Jedadiah's Avatar
Jedadiah
Instead of modifying the DRL relay, I just ran a jumper wire from where the 87a pin inserts to where the 30 inserts. It works fine, and that way if I ever need to have the DRL (if I ever sell the truck, or if the insurance company ever looks to see if I deserve the DRL discount) then I can just reinstall the relay.
Old 11-21-2002, 02:59 PM   #3
PA Roads SUCK!
weareweird69
Nevermind, im dumb lol
Old 11-23-2002, 08:21 PM   #4
xplizid kreations
miroe's Avatar
miroe
on my 2002 the dome override switch if you push it 4 times it will make a dinging sound, and the auto lights will shut off 4 more times and they come back on
Old 11-24-2002, 02:24 AM   #5
I BURN THINGS
Flamed 98's Avatar
No more whoring the thread
LinkBacks (?)
LinkBack to this Thread: http://www.s10forum.com/forum/f199/drl-and-ahl-how-to-14740/
Posted By For Type Date
Automatic headlights, (not DRL's) - The 1947 - Present Chevrolet & GMC Truck Message Board Network This thread Refback 01-23-2008 10:16 PM
daytime running lights - Blazin Low Forums This thread Refback 01-17-2008 07:58 PM
Automatic headlights, (not DRL's) - The 1947 - Present Chevrolet & GMC Truck Message Board Network This thread Refback 12-26-2007 02:00 PM
Free mods to be done?? - Blazin Low Forums This thread Refback 11-02-2007 01:52 PM
Free mods to be done?? - Blazin Low Forums This thread Refback 11-01-2007 03:15 PM
Free mods to be done?? - Blazin Low Forums This thread Refback 10-31-2007 10:38 PM
Free mods to be done?? - Blazin Low Forums This thread Refback 10-31-2007 10:29 PM
Free mods to be done?? - Blazin Low Forums This thread Refback 10-31-2007 09:21 PM
Free mods to be done?? - Blazin Low Forums This thread Refback 10-31-2007 07:39 PM
Free mods to be done?? - Blazin Low Forums This thread Refback 10-31-2007 05:36 PM
Free mods to be done?? - Blazin Low Forums This thread Refback 10-31-2007 03:47 PM
Free mods to be done?? - Blazin Low Forums This thread Refback 10-31-2007 03:38 PM
Free mods to be done?? - Blazin Low Forums This thread Refback 10-31-2007 03:18 PM
Page generated in 0.10002 seconds with 12 queries
