#1
forum idiot
98+ s10 head light install how-to
welcome...if you are reading this...you may have tried to install your new head lights into your truck...and once you have installed them do the tops touch the hood? is there a large gap under the light between the grill??? but you say "i installed the clips and they fit back" or " i will just adjust them down...no one will know"
if this sound like something you have said...listen up... you installed the lights wrong....there are little tabs that secure the lower part of the bracket to the core support... edit....this also works for gmc trucks too...but it is harder to tell if they are in wrong... if you installed them wrong they may look like this... or this...(drivers is in wrong) this is how it should look... these are the tabs i am talking about ...see where the line of rust is... these are the slots they go into on the support... this is how the tabs fit into the slot(from the back side of the support...) and this is how the clips go in with or with out the tabs in there correct slots... now some times this is made easy with the removal of the grill shell...but you may need a long flat head screw driver to push the tabs in place...but they will go and it is the correct way to install your lights do it this way to avoid being flamed be members of the forum... actual flame from member... actual testimony from members i have helped... there you have it folks...a few simple steps and your front end never looked better...or jason and I will make sure you hear about it... me fixing headlights at a meet...man does this bother me...lol ![]() ![]() link to the videos of me fixing the headlights... http://www.danswebhosting.com/brian/...ightpolice.wmv Last edited by orangesonoma : 12-02-2009 at 09:59 AM. |
