LinkBack (11) | Thread Tools |
#1
Suicide Hood Guru
1st Gen Suicide Hood How-to... Redone with new pics.
NOTE: If you have a 4.3 you might need to relocate your coolant reservoir
![]() Here you can see where it can be relocated. **First off ya need to make a trip your local junkyard and get the hood hinge assembly from a Buick LaSabre (there are a couple other models that have them as well but I don’t remember what they are), I know '84-88 LaSabres have the hinge. Anyway, they aren't hard to find, most junk yards have the hoods open on all the cars anyways. While your there, pick up an extra set of hood snubbers.(I bought my hinge kit for like 30$) **After you get the hinges home, first thing ya need to do is measure the distance between the inside of the fenders…. Also measure the width of the new hinge assembly. The new hinge assembly should be about 2-3 inches wider than your fenders. You'll need to cut a section out of the support bar for the hinge assembly, which keeps the hood from twisting when you open or close it. What I did was cut the support bar in the center… and put a 1/2" diameter 8” long bolt that was a bit smaller diameter than the support bar on the hinge into the support bar and re-welded it together to make it fit on the water runoff lips. I originally used a v8 manual fuel pump pushrod hammered into the support bar, It fits very well. ![]() ![]() **Set your hinge assembly on the water runoff lip of the fender and mark where your gunna mount your hinge. The rubber stop bracket should almost touch the radiator support. Mine is about ¼ away from the support. After you get your holes marked and drilled, mount the hinge from the BOTTOM of the lip and attach with bolts. I used bolts that I got at a local hardware store like Home Depot. I used 3/8" bolts and I used nuts to go along with it. I used 2 washers on top of the water runoff lip and 2 washers under it to have a little more support on such a thin piece of metal (the runoff lip is very thin.. but holds very well when washers are used). ![]() **After both sides are installed. Fold the hinges down into the closed position (Removing the spring from the hinge may help in allowing it to stay closed). Remove the inner fender wells, and jack the truck up to have access to the bottom of the hood. You can remove the front wheels if you want to give you more room I did and it makes the job easier this way. Others have done it without pulling the fender wells… I prefer pulling them cuz it assures the correct placement on the hood without having to adjust it later. If pulling the fenderwells is out of the question or you just dont wanna do it that way, another way you can do it is by taping markers inside the upper hinge bracket on the new hinge. Then when you close the hood the markers will mark the location on the bottom of the hood. Another way one person did it was by removing the headlights and reaching his hand in and marked the spot. Last edited by Nite Dragon : 11-21-2004 at 09:04 PM. |
#2
Suicide Hood Guru
Re: 1st Gen Suicide Hood How-to... Redone with new pics.
**Close the hood (that is still attached to the stock hinges). From the fender wells,or which ever method you decided to use to mark the upper mount, position the new hinges so they are in contact with the bottom side of the hood. Mark your holes on the hood with a marker or a scribe.
Raise the hood and drill your holes. The holes should line up with one of the support beams on the bottom of the hood. You can drill a larger hole about 3/8" away from the mounting hole or you can use a cutting wheel and make 2 slots in the side of this support beam for clip nuts (or speed nuts whatever you call them (like the ones on the fender wells and rad support). ![]() Heres a pic of the clip nuts and bolts used to mount the upper hinge bracket to the hood. **Once you have your holes drilled and clip nuts installed set the hood back into it original position (like the stock hinges were still connected to bracket). At this point… close the hood and from the fender wells line up your new hinge with the drilled holes and mount using bolts (I used ones from the fenderwells). Now if you didnt pull the fenderwells you can have someone help you hold the hood while you bolt it to the upper hinge bracket. There is plenty of room for adjustablility on the hinge assembly for adjustment if need be. **Release the hood latch and pop the hood open, pull up/forward and fold the hood down in front of the grill to make sure everything operates properly. Also check to make sure the hood is not banging into your grille or bumper while it hangs. If everything looks ok… you are ready for the next step. (if the hood bangs into the grille or bumper, you might need to go back and reposition where the lower hinge is located. It would have to be moved closer to the rad support). Also check and make sure the rubber stop is not cracked. If so you should be able to get new ones from the dealer. ![]() **Now you will need to remove the windsheild wiper arms and cowl. Should only be a bolt on either side. Now you can remove the bolt on either side that holds the upper hood hinge to the lower bracket under the cowl. Leaving the stock hinges attached to the hood so that they can still be used later on. Next, You will need to cut the lip of the stock hinge bracket located under the cowl. The bracket stands straight up… you will need to cut enough off of it so that you can hammer the bracket down covering the slip where the stock hinge was located. This will latch the rear of the hood into the firewall. Make sure you shoot some paint over it so it doesn't rust. Doesn't have to be pretty the cowl will cover it all up. ![]() This is a pic of the bracket cut and hammered down. this is how it should look. **Next close the hood till the stock hinge hits the bracket you just hammered down. Mark this spot on the stock hinges and cut it. (you may need to cut it at an angle so it allows for easier operation on the hood when opening and closing it. Open and close the hood several times and make sure it closes properly and the rear hooks clear the bracket. (when hood is fully closed… the stock hinges should slide under the hammered down bracket and touch them from underneath… this will work to keep your hood from flying open..) ![]() This is the cut of the stock hinges. ![]() This is a pic of how the stock hinge should slip back into the stock bracket after it s cut. this will hold the hood down. ** Next reinstall the cowl. Now you can mount your extra set of hood snubbers to keep the rear of the hood level with the body and keep it from bouncing going down the road. If you decide not to use hood snubbers.. you will just hear a very annoying rattle while driving… I suggest using them. You can mount them in the runoff tray off the cowl. That’s it, now your hood flips open to the front. A very easy and inexpensive modification. From beginning to end it took me about 2 hours… some it may be faster. Heres some pics of the finished product. ![]() ![]() ![]() Last edited by Nite Dragon : 11-21-2004 at 09:05 PM. |
