Pictures and steps on how to cut the bumpstop brackets off.
Go Back   S-10 Forum > General Tech > S-Series How-To > Chassis How-To
Old 04-09-2006, 03:59 PM   #1
Just a member
burple's Avatar
burple will become famous soon enough
There's a new story entry added:
well first start with a thin grinding disk. dont get it thick. thinner is better in this case use saftey glasses also a hooded jacket because the sparks hits your hair/neck and stings. this way your eyes are fine and a hooded jacket protects most of your neck
Old 04-10-2006, 05:29 PM   #2
simple man
5timedime's Avatar
5timedime is on a distinguished road
wrong photos?
the 7th, 8th, and 9th photos are the exact same photo. can somebody say oops
Old 04-10-2006, 05:32 PM   #3
Just a member
burple's Avatar
Re: wrong photos?
I will take care of it.
Old 04-11-2006, 08:50 AM   #4
big pimpin'
02dime's Avatar
02dime is on a distinguished road
does the truck have to be lowered to do this and feel the effects cuz i have an 02 zq8 and i was wondering if this will effect it in a positive way,thanks
Old 04-12-2006, 03:17 PM   #5
Yes-Man
oweezy9's Avatar
oweezy9 is on a distinguished road
Re: Pictures and steps on how to cut the bumpstop brackets off.
Unless you bottom out, it doesn't effect the ride. However, for the small amount of times that you DO bottom out, it keeps your axle from hitting the frame. Metal on metal is bad.
Old 04-12-2006, 03:19 PM   #6
Give me 3 yrs...
JollyRojer's Avatar
JollyRojer is on a distinguished road
i just did mine this weekend, my blazer is droped 3/4 or 3/5 cant really tell and its a dream, it was alot tuffer then this guy made it sound with my 87 lol i ended up getting frusterated and just hacking them off peice by piece, i couldnt get the welds from 87 to crack so i just well cut um off lol but it helps alot i hit the bumps on my road that at 30 would normally slam the back end around, and it road like a dream wata big difference just a stupid peice of metal with a rubber end makes
Old 04-12-2006, 03:54 PM   #7
Yes-Man
oweezy9's Avatar
Again, this is only necessary if your truck is dropped more than that of a stock zq8. So if you put a 3" drop, you MIGHT need to.
Bottomline, if you have more than 3in's of drop in the rear, I would.
Old 04-14-2006, 02:32 AM   #8
crazy_s_dime is on a distinguished road
yeah, i have a 3 or 3 and a half inch drop in the rear and i can feel it hit hard when there are big bumps, so this would be ok to do to my truck to keep it from hitting so hard?
Old 04-20-2006, 02:51 PM   #9
s10f Simpsons Expert
xFatDaNnx's Avatar
xFatDaNnx is on a distinguished road
liquid nails?
Did you just use the liquid nails to glue the bump stop to the fram is that what you did?
Old 04-20-2006, 04:04 PM   #10
xFatDaNnx's Avatar
Re: liquid nails?
double post sorry
Old 04-20-2006, 07:55 PM   #11
AyJay96350 is on a distinguished road
96 s10
i have a 1996 s10 lowered 5 and 6. if i do this will i have enough clearance or will it be to low?
Old 05-03-2006, 01:15 PM   #12
98' Cowl Induction
GiveMeBreak's Avatar
GiveMeBreak is on a distinguished road
Has anyone tried these bumpstops on summit?
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ENS%2D9%2D9132G&N =0&autoview=sku
oh and I SOOOOO need to do this from the weekend drop...my god does it ride like crap
Old 05-03-2006, 04:20 PM   #13
Just a member
burple's Avatar
Re: liquid nails?
Liquid nails will work. But that is really only needed if you go down to a 6 in the back. And still then, depending on the clearance, a notch may be in order.
Old 05-03-2006, 04:23 PM   #14
Just a member
burple's Avatar
Re: 96 s10
Each truck is different. Some people with a 6 in the back have 2 inches of clearance after cutting out the brackets. Others have maybe 1/2 inch of clearance after cutting them out. Only thing I suggest is to remove them and measure. If you have around 2 inches of clearance and good shocks in the back you should be OK. You will still hit on larger bumps but not all the time. But after cutting them out you find you do not have enough clearance or you still hit often, you may need to look into a small c-notch.
Old 05-04-2006, 09:33 PM   #15
xFatDaNnx's Avatar
Re: liquid nails?
yeah i've been rollin on it for about 2 weeks without bumpstops and have not hit once...i was thinking about putting the bump stop on the flat plate that hold the U bolts in, just in case...but like i said, 3 inch drop...no issues with them gone...now i gotta do the front.
Old 05-05-2006, 08:51 AM   #16
AlexCoppas is on a distinguished road
Post I love yours site
Heh..Where is here some web gallery about site creators?I'm need it.For example, as here - Google, I'm really have seen ithere.Good luck!
Old 05-05-2006, 09:11 AM   #17
Primer Spots
mrshaft696's Avatar
mrshaft696 is on a distinguished road
Re: I love yours site
wtf who is that guy? this is the test forum what the hell is going on, i see no pics and isnt this a repost
Old 05-05-2006, 09:08 PM   #18
Just a member
burple's Avatar
man this is where all of the comments from the main page how-to's go. Look at the main site. Comments for the drupal links are left in this forum.
Old 05-11-2006, 05:06 PM   #19
Daves03's Avatar
Daves03 is on a distinguished road
Thanks!
started lookin under my truck the other day when me and my bud were working on my truck weldin the rollpan up and me and him seen it at about the same time and we though dang the axle isnt supposed to sit on the bump stops like that is it? sarcastically so he got out the plasma cutter and we pulled a jesse james monster garage style but its lower and it rides better than it did stock. No wonder it beat me to death everyday!
Old 05-12-2006, 09:22 AM   #20
Post Well... its really cool!
Old 07-13-2006, 05:57 PM   #21
hobocob86's Avatar
hobocob86 is on a distinguished road
Re: liquid nails?
i did this quite awhile back........the clearance is great.....still not enough.....c notch is on the way
Old 07-13-2006, 06:01 PM   #22
hobocob86's Avatar
clearance
the clearance is great, however, still not enough though......c notch is gonna be neccesary
Old 07-18-2006, 04:01 PM   #23
hobocob86's Avatar
very easy.....but now i still want more clearance.........time to notch
Old 08-26-2006, 03:59 AM   #24
COSTLY CAN CRUSHER!
xxphatmattxx's Avatar
xxphatmattxx is on a distinguished road
IF YOU CUT OFF THE BUMPSTOPS WITH A ZQ8 SUSPENSION, YOU WILL MOST LIKELY BOTTOM OUT THE SHOCKS, NOT THE AXLE ON THE FRAME.
Old 01-27-2007, 03:39 AM   #25
no longer ''xtreme''
get layed's Avatar
get layed is on a distinguished road
stupid me didn't remove mine when I lowered my zq8, so im going to remove mine in the first of spring when it warms up. What all did you have to do to prepare? just remove the tires and jack it up on stands. Thanks for any advice..
Old 04-21-2007, 04:59 PM   #26
DzMiniz's Avatar
DzMiniz is on a distinguished road
old topic, i know.
are you guys just gluing the stock bumpstops back up? Mine are gone... what else are you guys using?
thanks
Page generated in 0.20240 seconds with 12 queries
