Install: Step Notch Step By Step
Go Back   S-10 Forum > General Tech > S-Series How-To > Chassis How-To
Old 04-27-2003, 03:06 AM   #1
I AM A LUNATIC!
suicidedoors.com's Avatar
here is a step notch install done by my 2 brothers and myself. luke tore it apart, adam did all the welding, and i played boss.
adam's welding skills are amazing. he can run a perfect bead vertical, horizontal, overhead, and anyway you can imagine. i was going to do the install myself but he insisted on doing most of the work, so i didnt argue.
i hope this step by step clearly shows you what is involved to properly install one of these. it took us a total of about 10 hours. that was from the start of pulling the bed and gutting everything to make room to move, to the very last bead. of course you dont have to go through all of this to install one of these, but we like to take our time and do it right.
this pic is right after we pulled the bed off. very familiar site to most of you im sure.
Old 04-27-2003, 03:08 AM   #2
I AM A LUNATIC!
here is after pretty much all of the stuff was stripped out.
Old 04-27-2003, 03:11 AM   #3
I AM A LUNATIC!
we scraped all of the undercoating off in the notches future home area with a puddy knife.
Old 04-27-2003, 03:13 AM   #4
I AM A LUNATIC!
then we wiped the rest of the gunk off with a rag and brake cleaner. that stuff works really well.
Old 04-27-2003, 03:14 AM   #5
I AM A LUNATIC!
good bye brake line hanger.
Old 04-27-2003, 03:17 AM   #6
I AM A LUNATIC!
we felt that the old shock crossmember was in the way, and ugly. the plasma made it easy to remove this.
Old 04-27-2003, 03:19 AM   #7
I AM A LUNATIC!
here is the frame again, a little cleaner this time.
Old 04-27-2003, 03:23 AM   #8
I AM A LUNATIC!
we threw the axle back in there to find dead center of the notch. we took the time to lift the entire truck off the ground and get it perfectly level. when the frame was level, we were able to put another level on the center of the axle to find our center point in the frame.
Old 04-27-2003, 03:29 AM   #9
I AM A LUNATIC!
once we marked the frame where the center of the notch would be, we double checked our measurements from a few different places to make sure we were exact. this pic shows a measurement being taken from the bolt sitting in the front spring hanger. 28-13/16" is what we got. to make sure we didnt goof up, extra time was spent triple checking everything. measure many times..... cut once.
Old 04-27-2003, 03:32 AM   #10
I AM A LUNATIC!
the remainder of the factory bump stop was cut out of the way. it was interfering with the new step notch plate. i had removed most of the bump stop about 3 years ago when i first bagged it.
Old 04-27-2003, 03:35 AM   #11
I AM A LUNATIC!
in this pic, adam is cutting the bottom of the step notch plates off to match the shape of the frame. we clamped them in place and made sure they were perfectly level, then scribed a line in them even with the bottom of the frame. the plasma makes this job pretty easy.
Old 04-27-2003, 03:38 AM   #12
I AM A LUNATIC!
the plate is then clamped into place to make sure it fits to our liking.
Old 04-27-2003, 03:42 AM   #13
I AM A LUNATIC!
the inside of the frame rail on a s10 is jacked all to hell. it needs to be trimmed so that its parellel with the outside plate. the distance between the inside of the plates is 2-7/16". this pic shows the upper frame rail after its been trimmed.
Old 04-27-2003, 03:45 AM   #14
I AM A LUNATIC!
after we marked the lines, a straight edge was clamped into place to make getting a nice cut a piece of cake.
Old 04-27-2003, 03:48 AM   #15
I AM A LUNATIC!
cut off disks are nice. they slice through s10 frames like butter. here you can see the straight edge clamped in place with the cut off wheel being guided by it.
Old 04-27-2003, 03:55 AM   #16
I AM A LUNATIC!
once the top of the frame was cut, it was time to move to the bottom. the step notch plate was put in place and held level. lines were then scribed on the frame to show where it needed to be cut. because the notch plate was level, we needed to measure inward past the line a 1/8". that is where the cut will be made to allow for a outside corner to be welded up.
Old 04-27-2003, 03:57 AM   #17
I AM A LUNATIC!
a straight edge was clamped in place here too. it makes cutting a straight line so much easier.
Old 04-27-2003, 04:01 AM   #18
I AM A LUNATIC!
after the frame was trimmed to parellel, both of the inside plates were tacked in first. in our opinion, they are the most crucial to get aligned perfectly.
Old 04-27-2003, 04:08 AM   #19
I AM A LUNATIC!
with both of the inside plates tacked in, we sat 2 pieces of square tubing on top of them. the tubing acts as a stop when clamping the outside plates on. this way you can make sure they are perfectly straight across from each other. using 2 levels, we double checked to make sure the frame was still level, and that the notch was too.
Old 04-27-2003, 04:12 AM   #20
I AM A LUNATIC!
if you look closely you can see a metal spacer between the 2 notch plates. this helps in keeping everything aligned. this spacer gets welded in place and will stay there forever.
Old 04-27-2003, 04:30 AM   #21
I AM A LUNATIC!
here is the spacer welded in place. if you dont have this in there the notch plates will bow in when you weld the frame to the inside of the notch plates. if it bows in, the top cap will not fit properly.
Old 04-27-2003, 04:33 AM   #22
I AM A LUNATIC!
the top of the frame is then welded to the step notch plates.
Old 04-27-2003, 04:35 AM   #23
I AM A LUNATIC!
next, the bottom of the plates is welded to the frame.
Old 04-27-2003, 04:39 AM   #24
I AM A LUNATIC!
now that the frame is solid in the notch area, we can cut the frame out thats in the center of the notch. again, cut off disks rule. you have more control over a hand grinder than a sawzall. a sawzall will work great too.
Old 04-27-2003, 04:41 AM   #25
I AM A LUNATIC!
the center has exited the premisis and was chucked across the shop.
Old 04-27-2003, 04:45 AM   #26
I AM A LUNATIC!
when using a cut off disk, wear a face shield and gloves. sometimes they catch and explode. you can lose an eye or get disk debris stuck in your face. not good.
Old 04-27-2003, 04:50 AM   #27
I AM A LUNATIC!
it is now time to fit the top cap. since the frame is not square, it has to be trimmed to fit. we made a template out of poster board and transfered the shape to the cap. then zipped it with the plasma.
Old 04-27-2003, 04:53 AM   #28
I AM A LUNATIC!
when the top cap fits like you want it to, tack it in place.
Old 04-27-2003, 04:57 AM   #29
I AM A LUNATIC!
on the drivers side you have the tail light wiring to deal with. here we cut an access hole to run the wires inside the notch. it will shorten the overall length of the wires some, so you may have to add a few inches to get reconnected. we havnt made it that far yet. if we have to lengthen the wires its no biggie.
Old 04-27-2003, 04:59 AM   #30
I AM A LUNATIC!
here is the access hole. you will need one on both sides of the drivers side notch. make sure to smoothen the jagged edges.
Old 04-27-2003, 05:02 AM   #31
I AM A LUNATIC!
the top cap is now being fully welded in place. this pic doesnt do justice to how smooth my bro's beads are. im jealous.
Old 04-27-2003, 05:04 AM   #32
I AM A LUNATIC!
here is another pic of the top cap and the outide plates getting fully welded.
Old 04-27-2003, 05:06 AM   #33
I AM A LUNATIC!
the top cap is now finished. the inside cap has been trimmed to fit and tack welded into place.
Old 04-27-2003, 05:08 AM   #34
I AM A LUNATIC!
after the inside cap is tacked and checked over, it is fully welded.
Old 04-27-2003, 05:14 AM   #35
I AM A LUNATIC!
here they are. all done... almost. they still need to be coated with either some good paint or undercoating to keep them from rusting.
this frame will now lay out on 20's easily. i think it might even lay on 22's. i'd have to re-measure to see.
now you dont have to go through all the bull crap we did to install a step notch. it just depends on how much time you have and if you want to move around inside the frame. it does make the install go alot smoother and cleaner.
last pic........
Page generated in 0.64689 seconds with 32 queries
[Output: 164.77 Kb. compressed to 149.43 Kb. by saving 15.34 Kb. (9.31%)]
