When is a ZR2 NOT a ZR2?
Go Back   S-10 Forum > Specific Model Forums > 2nd Gen Forums > ZR2 - BlaZeR2 - Highrider
Old 08-29-2009, 09:34 AM   #1
I talked to an owner of a 2000 ZR2 ext cab today and he said his ZR2 had no ZR2 RPO. It's not a clone as I checked the suspension so it's a legit model. He said the only difference between his truck and a "real" ZR2 was the sticker on the side of the truck. I didn't check the RPO sticker in the glovebox but he said he bought it brand new so he should know. (He sounded like he was fairly familiar with the S10s and ZR2s.) He also said he pays a lot less for insurance as it's not listed as a ZR2.
Anyone else come across this before? Kind of interesting.
Old 08-29-2009, 10:40 AM   #2
Re: When is a ZR2 NOT a ZR2?
Maybe he took the sticker off?
Old 08-29-2009, 10:50 AM   #3
Lifts are for 4wds!
andysutt's Avatar
Even if he took the sticker off, that wouldn't make insurance go down...
Old 08-29-2009, 11:07 AM   #4
my blazer zr2 model doesnt have a sticker on the side of it, but it is still a zr2 model.
a few things to make it a legit zr2 model.
inside the glove box, on the rpo codes, it needs to state ZR2.
the zr2 has boxed a arms. should have a boxed frame. the suspension mounting points are lower than that of a regular s10/blazer to give it the raised ride height. it also has a 3.9" wider track width.
obviously the raised arch fenders, wheel flares, the inner fenders on the front also have zr2 stamped on them.
but mainly, if it is a true zr2, it will have the zr2 rpo code in the glove box.
i dont remember if my truck came back as a zr2 or 4x4 in the vin when i ran it through carfax when i purchased it. but i know its a legit.
could it be that he bought a wrecked zr2 and swapped the frame w/ his non zr2
and pictures of said vehicle?
Old 08-29-2009, 12:49 PM   #5
I don't know the guy. Just happened to meet him outside the vets office this morning. It's a legit ZR2. I checked the suspension. He said he bought it new so I'm pretty sure he didn't swap frames. He didn't remove the sticker. It just didn't come with one. And he seemed pretty sure it didn't have the ZR2 RPO. (I asked him and he seemed familiar with both the location of the RPO sticker and the ZR2 code.) I asked if it had the Z85 suspension RPO and he said he thought it did but wasn't sure.
Assuming the frame wasn't swapped (as I'm sure it wasn't), I guarantee it was a ZR2. I could clearly see the front mount for the rear springs. Instead of being flat like my non-ZR2 Blazer, it had a drop of a couple inches or so. Nothing welded on but looks just like every ZR2 I've ever seen.
Since I just met him, I wasn't about to ask for the VIN or to see the RPO sticker for verification.
Old 08-29-2009, 10:17 PM   #6
forum idiot
orangesonoma's Avatar
no zr2 rpo...then its not a zr2
but i think he was yanking your chain you should have asked to see the glovebox..
unless the glove box door was not for that truck
Old 08-30-2009, 12:11 AM   #7
Stickers were sometimes let up to the dealers choice to put on or not.
Also the truck Z's are the ones with the dead give away front rear spring perch, suvs dont have it...
Old 08-30-2009, 12:24 AM   #8
This truck definitely had the lower front rear spring perch. That was the first thing I noticed when I was looking to see if it was real. If the SUVs don't have it, how do the ZR2 Blazers get the extra lift in the rear?
Old 08-30-2009, 12:32 AM   #9
I belive it is lowered on out suvs too, but it does not stick out like the giant triangle on the trucks...
Old 08-30-2009, 12:36 AM   #10
Useless posting member
Wrkn prgs's Avatar
No RPO in the glovebox? Then no ZR2.
Old 08-30-2009, 12:29 PM   #11
Overhead Console Expert
raven2510's Avatar
just look at the spring perch and the front fender well. the well will have ZR2 stamped in it.
Old 08-31-2009, 12:10 AM   #12
WICKED 6 RACING
disturbing V6's Avatar
The stickers were from what I understand could be ordered left off. My 00 did not come factory with the stickers. The dealer opted not to have them put on when they ordered it. But everything is number matching to a tee. RPO codes are in the glove box the tire chart for the 31's are in the door.
Old 09-25-2009, 08:42 PM   #13
sixfeathers's Avatar
Its a simple answer . An SR2 is not an SR2 as soon as you put it on a trailer.
Old 09-25-2009, 08:44 PM   #14
You can also eyeball the tires. The rears hide under the bed. The front tires stand out wider. You can use wheel spacers to fix this. but most folks dont bother.
Old 10-02-2009, 01:32 AM   #15
JDP
I have yet to see a ZR2 that has a 5 spd have a ZR2 sticker. I have always assumed the ones without a sticker were the base model and the ones with the ZR2 sticker were fully loaded.
Old 10-02-2009, 09:57 AM   #16
I had a 97 s10 zr2 w/ a 5sp. And yes it was a true zr2, had the code in the glove box...I've never seen another one though, I think it was a special order?
Old 10-10-2009, 12:43 AM   #17
I have one. 5 speed manual.
Old 10-11-2009, 07:02 PM   #18
bigb19812000's Avatar
my GMZ has no Zr2 RPO codes and the wrong sticker on the door for the tire size and it is a 1998 Jimmy with no stickers .The way I know this is that is wider and taller than a regular 4x4 blazer,the front fenders are stamped ZR2,and my jack is stamped ZR2 and it has billstien shock under it
Old 10-17-2009, 01:57 PM   #19
draggin azz
livindalowlfe's Avatar
i have an 01 zr2 with a 5 speed and it has all the stamps/stickers/ and code in the glove box proud owner of 3 slammed dimes and 2 zr2s!!!
Old 02-25-2010, 03:54 PM   #20
you truck looks like a zr2 but your sticker doesnt match to a zr2 's were it says p16under it says v54 yours hase two ** but a zr2 says ZR2 *
Old 02-25-2010, 04:02 PM   #21
but my buddy has the same thing sa you so we called gm after 6 hours on the phone we were told the at some point the zr2 were short stock and gm started to take blazer bodys and put them on zr2 frames .. i dont really remeber everthing that gm told use there was alote of information ..
Old 02-25-2010, 04:11 PM   #22
drag racin > dragin frame
v8lonoma's Avatar
you spent 6 hours on the phone with gm?? over this? lol
Old 02-25-2010, 04:51 PM   #23
s10gmconversion's Avatar
i still think that its funny how hes saying "real" zr2 like its a limited edition ferarri or something. call gm over something that stupid? get a life
Old 03-01-2010, 12:02 PM   #24
WHAT YOU TALK ABOUT ME GETTING A LIFE LOL ... i wont even bother with you guys..lol
Old 03-01-2010, 08:32 PM   #25
I'm not calling your a lier or anything, but wouldn't the blazer bodies be the same as the ZR2 blazer bodies anyway? Minus the stickers which I would assume would be put on somewhat last.
Old 03-04-2010, 05:34 PM   #26
i was told that no there were made in the same place i dont remeber the place zr2 were made but tyhey seemed to telling me that it was made at another truck plant
