Oil Filter Access Door Bolt/Latch - S-10 Forum
post #1 of 3 Old 11-17-2010, 07:59 PM Thread Starter
bikemobile's Avatar
User is: bikemobile is offline
I dont have the little screw/bolt that keeps the Oil Filter access door closed on my aluminum front skid plate. Any Ideas on a replacement or an alternative?
post #2 of 3 Old 11-19-2010, 06:21 AM
Professional Insultant
TokoDragon's Avatar
User is: TokoDragon is offline
Send a message via MSN to TokoDragon
Re: Oil Filter Access Door Bolt/Latch
I saw my door flapping in the wind once after off-roading, I Just went over to our large collection of bolts and grabbed one about the right size and it worked perfect.
I don't think there are any threads on that door, its more like the grille kind of nuts holding the bolt.
So really, any bolt the right diameter will work.
Mine is not the aluminum skids though, maybe they have threaded nuts for the door on them. I'm doubting it though...
post #3 of 3 Old 12-05-2010, 02:38 AM
Wilson4x4's Avatar
User is: Wilson4x4 is offline
i drilled another little hole, zip ties work wonders. just replace it after every oil change. no more flapping.
Black 06 Sierra z71 crew cab, 5.3, 33" mickeys, 4:10s, g80 locker, pro comp wheels, tool box, 3/4 ton leafs with aal... Wayyy too much.
Black 96 S10 ZR2' new winter beater/ mud monster. 2" body lift, 2" suspension lift, 33" duratracs, tool box, camaro wheels..
$400 first truck now beater.. 97 regular cab, auto, 4x4, 4.3, Flow 40, 98+ front end, HIDs, 2'' body lift, 2" shackles, zr2 tbars, z28 camaro wheels, John Deere green, 31'' MTRs.
