new zr2 has a few issues
I have just bought a 2000 S10 ZR2 pick up the guy i bought it from said it needed a mass flow sensor and i drrove it for about 100 miles and it hesatated at start and then straightend out but after a 100 miles it final through the check engine light came on i pulled 4 codes out a po101, po171,po174 and po507 i was going to start with a mass flow sensor and was wondering if the outher code came up because of it
Game Pop. Control Agent
Re: new zr2 has a few issues
The first code is the MAF sensor. The second and third mean that its running lean. Dont know about the last one. Never had that one before.
Clean or replace the MAF sensor, clear the codes, and see if they come back. If not, check for air leaks between the MAF and the intake. If that doesnt work, Seafoam it and see if maybe you have really dirty injectors. Im no Mechanic, but thats my $.02 |
bags=fags
x2
try EGR? |
yea kinda figured it out it was mostly that the intake is all carboned up. that is makein it bog and hopefuly the codes but ill let every one know
