Intake manifold...leak or no leak?
I have an '00 ZR2 4.3L. Pretty stock. I have heard that the intake gasket is subject to failure. Is this true?
Is there a way to check? I have a vacuum guage. I am trying to diagnose what I am coming to believe is "poor injector design syndrom" or PIDS. If you have suffered from stinky PIDS I'd love to see pics of the swap to the (is it?) newer injector design. Sorry I think I messed up the thread already. |
Ticket Magnet
Re: Intake manifold...leak or no leak?
You don't need a vaccum gauge...your peeprs will tell right away if there is a coolant leak. As for the spider...if it ain't broke.....
I do see a rust mark that always looks fresh down in near the stat, but I'm sure its not the stat.
To be clear the fault in the intake is coolant related? Not air flow related? |
if your not losing coolant, and theres no coolant down the side of your block then your gasket is fine
Game Pop. Control Agent
I you think the stat housing is leaking, just get some RTV sealant and a new stat. remove the old stat and put the new one in, then put a thin bead of sealant on the housing (being careful not to get it too close to the inside of the housing) and cinch it all back down. Wait a couple hours before you drive to let the sealant set.
sweet. cross that one off the potential to do list.
Why is the inside of my rad cap covered in crap? Not milky just oily rusty stuff. |
Ticket Magnet
