how do you fix engine surging - S-10 Forum
post #1 of 10 Old 04-04-2010, 11:24 PM Thread Starter
Dakota421's Avatar
User is: Dakota421 is offline
I just got a Sonoma ZR2 highrider and everything on it is good except sometimes when it tries to go into overdrive it goes in and out and its startin to worry me
post #2 of 10 Old 04-05-2010, 01:32 AM
bumperguy
donaldps10's Avatar
User is: donaldps10 is offline
Re: how do you fix engine surging
you check tranny fluid?
what year? how many miles?
is there a specific time it occurs? suck as specific RPM's? only going up hill? etc...
1994 Subaru SVX -sold-
2001 S10 2.2L 5-Spd stack exhaust -sold-
2000 Noma Highrider 4x4 4.3 with stuff -toy-
2004 4-door blazer 4x4 4.3 T-bar crank to level on 30x9.5 BFG KO's -hers- -sold-
2003 yellow crew S10 ZR5 4x4 4.3 stock for now -his-
http://www.dfw-tx4wd.org/
post #3 of 10 Old 04-05-2010, 02:38 PM Thread Starter
Dakota421's Avatar
its got transmission fluid but im bout to change it and the filter. its a 96 with 140,000 miles.it does it after its been running awhile at about 50ish mph alot of the times when its going up a hill
post #4 of 10 Old 04-05-2010, 05:30 PM
Game Pop. Control Agent
Tyhuck's Avatar
User is: Tyhuck is offline
is your A/C on? if your compressor is running it will cause a slight surge feeling when it kicks on an off. Its very slight though. If yours is more than slight then it probably something else.
-- 2001 S-10 ZR2. Too many mods to list. It upsets me too much to add up all the money I spent.
Some day, Vortec 5.3 swap, SAS, and a bedlined body.
Tyhuck is offline
post #5 of 10 Old 04-06-2010, 08:36 AM
User is: ZR2Owner? is offline
The transmission would down-shift going up hill.
post #6 of 10 Old 04-06-2010, 02:45 PM Thread Starter
Dakota421's Avatar
only on a steep hill but whenever its under a load it goes in and out of overdrive
post #7 of 10 Old 04-06-2010, 03:52 PM
bumperguy
donaldps10's Avatar
mine downshifts all the time... i hear it's the 3.73 gearing. it is always trying to find the right place. when your cruise control is on it downshifts and stays like that for a long time most of the time before finally going to a lower RPM. i hear you can re-gear to 4.10 and it will make it much better.
post #8 of 10 Old 04-06-2010, 04:24 PM
Tyhuck's Avatar
Check you TPS and your MAF. Alot of times they can malfunction and not throw a SES light so you dont know its not working right. If either of those sensors is not opperating properly, then it will affect transmission shifting.
I may be way off, but thats what Ide check first given the symptoms.
Tyhuck is offline
post #9 of 10 Old 04-07-2010, 07:50 AM
donaldps10 is right, its probably just hunting for the right gear. If it really annoys you, just shift into 3rd and call it a day. OD is really just made for cruising, not working. So when your truck is under a load, going up hill or passing its going to down-shift and then up-shift when it feels it should.
post #10 of 10 Old 04-09-2010, 06:46 PM
User is: aubewon is offline
It also could be your IAC ( Idle air control) It thinks it needs more fuel
aubewon is offline
