gonna buy but with 4wd problems...
Go Back   S-10 Forum > Specific Model Forums > 2nd Gen Forums > ZR2 - BlaZeR2 - Highrider
Old 08-17-2009, 10:27 PM   #1
offroadwnc's Avatar
Question gonna buy but with 4wd problems...
Hey from Carolina guys!
anyways i think i found a pretty good deal for my first truck. a 2001 blazer zr2 with 89k miles for $4000 bucks. at least its good compared to what the others around my area are .
the only problem is that the electronic 4wd dont work right. all the modes will engage but the lights dont tell me what im in. none of the lights work except if i press and hold 4 low they all flicker. might this just be a loose wire or something in the mechanical part? thanks
Old 08-18-2009, 03:10 AM   #2
bags=fags
donaldps10's Avatar
Re: gonna buy but with 4wd problems...
so the 4wd works?
Old 08-18-2009, 11:01 AM   #3
offroadwnc's Avatar
well yea half the time. we had it in 4 low and pressed the 2wd button and thought it went in but it didnt. so we started down the road in 4 low which is definately no good. i just wonder if the lights are gonna be a fairly easy fix before i buy it because i hate messin with electrical stuff
Old 08-18-2009, 12:14 PM   #4
Game Pop. Control Agent
Tyhuck's Avatar
Just go to you local auto parts store and buy a replacement 4wd switch. They should have an exact replacement. Try that first. If thats not it, you may have a bad switch to the t-case.
If you parts guy is as cool as mine he will let you switch it out and see if that is the problem. If it is, great. If no he will let you return it and help you figure out what the next problem is.
Old 08-18-2009, 12:15 PM   #5
Tyhuck's Avatar
Wait. Do you have the truck already or are you looking at buying. If you havent bought it, see if the seller will replace that switch, or knock the price of the switch off of the selling price.
Old 08-18-2009, 03:19 PM   #6
offroadwnc's Avatar
yea we aint got it yet. the guy is gonna take a look at it wednesday morning but i aint gonna push him too hard since he already dropped the price by $2000. that switch just plugs in right?
Old 08-18-2009, 03:57 PM   #7
Tyhuck's Avatar
Yes, You will have to remove the dash trim (make sure you search this so you dont break it) and push the switch out from the back. Then unplug the wireing harness plug the new switch into it, and put it all back together. Real easy. I dont know about the T-case switch but it should be similarly easy.
Old 08-18-2009, 04:17 PM   #8
offroadwnc's Avatar
alright thanks bud
Old 08-18-2009, 08:25 PM   #9
Tyhuck's Avatar
Dont thank me, thank the guys on here. Majority of the info I know about S10's is because they are so helpful and full of info.
Old 08-19-2009, 04:04 PM   #10
Rollin' 32's!
Br&on's Z's Avatar
No you don't. You can take a small object tht won't scratch the dash and pop the 4x4 switch right out. It only takes about two seconds. But also I hit a water hole in mine once and the 4wd lights would just blink like that and I unhooked the battery for like 10 minutes or so to let the computer reset and it worked fine after that. It would definately be worth a shot before you go and buy a new switch and if it doesn't work all you wasted was 10 minutes! Good luck!
Old 08-22-2009, 01:15 PM   #11
2002zr2crackaa's Avatar
hey dont buy it yet, i gotta 02 zr2 blazer with 85k miles on it and the 4wd works! lol gotta lot of mods on it from tires, lights, cb, antenna everything, i live in winston so send me a message cuz its for sale
