Gmc Highrider? - S-10 Forum
post #1 of 14 Old 07-11-2007, 01:04 AM Thread Starter
HA CHA CHA CHA
syco133's Avatar
User is: syco133 is offline
Send a message via AIM to syco133 Send a message via MSN to syco133
Gmc Highrider?
I have a 2002 GMC quad cab 4x4 4.3 vortec with an auto tranny that I am trying to find out for sure if its a highrider or the zr2 or a regular old 4x4 and cant get a for sure way or answer to what it is.It has the paper work from when I got it used and it says it has the rear locker and the highrider package I know it has the locker I have had it in the mud and did a killer burnout in it allready but not sure on the highrider package.How can I know for sure which one it is? Hers the pics of the truck.
ID:	89329   Click image for larger version
Name:	slo mo front.JPG
ID:	89330   Click image for larger version
Name:	slo mo side.JPG
ID:	89331   Click image for larger version
Name:	burn 5 small.JPG
syco133 is offline
post #2 of 14 Old 07-11-2007, 12:56 PM
no longer has a 95
95 S_Trucker's Avatar
User is: 95 S_Trucker is offline
Send a message via AIM to 95 S_Trucker
Re: Gmc Highrider?
Definatly not a highrider. They were only extended and reg cab. They were never offered on crew cabs. Your tires would be 31s if you had a HR, and You would have fender flares, but you dont. It would also be 3-4 inches taller.
This is a highrider
http://images.safeform.com/stock/300...02/3PU-4-L.JPG
99 Blazer 2 Door, 4wd, NV3500, 8.5
99 K2500 LS CCSB 7.4, 4L80E
post #3 of 14 Old 07-11-2007, 01:02 PM
s-series #2?
greencactus3's Avatar
User is: greencactus3 is offline
Re: Gmc Highrider?
not a zr2 but i think 4drs could hav come with the zr5 package? i dunno much tho
post #4 of 14 Old 07-11-2007, 01:22 PM
no longer has a 95
Re: Gmc Highrider?
Its not a ZR5 either. They had fender flares, a roof rack, red rails, running boards/ nerf bars and five spoke aluminum wheels. The ZR5 is just an apearance package. Same engine, same suspension.
http://www.pickuptruck.com/html/news/zr5.html
post #5 of 14 Old 07-11-2007, 01:53 PM
s-series #2?
Re: Gmc Highrider?
oh . lame. so 4drs arent meant to go offroading in?
post #6 of 14 Old 07-12-2007, 09:41 PM
Jersey 91/93's Avatar
User is: Jersey 91/93 is offline
Re: Gmc Highrider?
Apparently not according to GM.
Tim
93 Black/Silver Typhoon #1485 - Show toy
07 Canyon, 3.7L I5 Auto, Crew Cab, 4wd Z71 - Daily Driver
84 Chevy M1009 ex-Army Blazer
85 Chevy M1009 ex-Army Blazer
03 S10 - Totalled *** 02 S10 - Traded In *** 91 S10 - Sold
post #7 of 14 Old 07-13-2007, 07:24 AM
Just a country boy.
distortedzr2's Avatar
User is: distortedzr2 is offline
Re: Gmc Highrider?
ummm NO it is not a Zr2 as others mentioned.
post #8 of 14 Old 07-13-2007, 12:52 PM
flip switcher
vielecustoms's Avatar
User is: vielecustoms is offline
Re: Gmc Highrider?
heres my highrider.
I think the most noticible things over a normal 4x4 is it sits higher, the fender flares and the 31 x 10.50 tires.
post #9 of 14 Old 07-13-2007, 04:56 PM Thread Starter
HA CHA CHA CHA
syco133's Avatar
Re: Gmc Highrider?
Welp I went to the dealer and asked them to get me a orignal window sticker it cost but I got one.It does list my truck as a highrider and with the rear locking diff but I was very sure it wasnt so who the heck knows.
syco133 is offline
post #10 of 14 Old 07-13-2007, 06:22 PM
no longer has a 95
Re: Gmc Highrider?
RPO ZR2
From Wikipedia, the free encyclopedia
Jump to: navigation, search
RPO ZR2 (optional S-Series package) Manufacturer General Motors Also called S10 ZR2
GMC Highrider
blaZeR2 Production 19942005 Class Compact pickup truck The RPO ZR2 was a special Off-Road/Suspension package offered by General Motors primarily on their 4x4 2nd Generation S-Series line. It made its debut in 1994 when it was introduced in both the Chevrolet S-10 and the GMC Sonoma (Highrider) pickup trucks. In 1996 it was expanded to the 2-Door Chevrolet Blazer (dubbed blaZeR2 by fanatics) and later offered with the Chevrolet Tracker.
RPO stands for Regular Production Option, ZR2 doesn't stand for anything, its just the code that GM assigned to it its also the name generally given to these vehicles. The RPO ZR2 was gradually phased out along with the entire S-Series when the Chevrolet Colorado and GMC Canyon were introduced in 2004. s
Contents
[hide]//
[edit] What is a RPO ZR2?
2000 S10 ZR2
The following factory-installed features are what made the ZR2 standout from other 4x4 trucks offered in the S-Series class.
  • Ladder Type Frame with Modified Mounting Points
  • 100mm wider track (3.9 inches wider than regular S-10)
  • Increased Ground Clearance (Approx 3" over Regular S-Series 4x4)
  • Enhanced front (7.25" ring gear) and rear (8.5" ring gear) axles w/ 3.73:1 rear-axle ratio
  • Larger wheel and axle bearings
  • 31 x 10.50" BFG A/T Tires (Pickup), 31 x 10.50" BFG Longtrails (Blazer)
  • Fender Flares
    • Spectra Gray on the Chevrolet Models, despite body color. Body color on all GMC Models.
  • 46mm gas pressurized Bilstein Monotube shocks
  • Rear Track Bar (Pickup), Front Anti-Sway Bar (Blazer)
  • Skid Plates [1]
  • Front/Rear Disc brakes (1998-2005) , Disc/Drum brakes (1994-1997)
  • Full Size Spare Tire
[edit] ZR2 Facts
  • Not all S-Series 4WD's are ZR2's, and not all ZR2's are 4WD's.
  • The ZR2 option was never offered with any of the Crew Cab, 4-Door Blazer, or GMC Jimmy (USA) models. [2]
  • The S10 ZR2, GMC Highrider, and many Blazer ZR2's feature Insta-Trac (three-button) 4WD. The Blazer ZR2 was also offered with the option of Auto-Trac (four-button) 4WD.
  • Being that the ZR2 featured a full size spare tire and the Blazer lacked considerable space both underneath and inside the cab; an exterior mount was created for the ZR2 Blazers. The mount was placed at the rear of the vehicle overlapping the tailgate and rear glass, this created a severe blindspot. To remedy the situation a small company manufactured a lowering kit that would relocate the mount a few inches down.
  • A ZR2 equipped S-Series vehicle is worth several thousand dollars more than a non-ZR2. Therefore ZR2 decals are commonly used on non-ZR2's in attempts to trick an un-informed buyer into spending more money. This practice is especially common among online marketplaces and independent Auto dealers. ZR2 verification can be done by checking the RPO tag affixed to the inside of the glove compartment.
[edit] The Life of the RPO ZR2
  • 1994 - ZR2 package is introduced with the Regular Cab 2nd Generation S-Series Pickups
  • 1995 - ZR2 package expanded to Extended Cab S-Series Pickups
  • 1996 - ZR2 package extended to 2-Door Blazer models. [3] 3rd door was offered on extended cab models.
  • 1998 - Disc brakes are now standard on the Front and Rear wheels. Interior updated along with front grill and headlights.
  • 1999 - GM replaces the Aluminum Skid Plates with Composite Skid Plates. Side mirrors are updated. (much stronger)
    • Last model year the ZR2 option was offered on a regular cab pickup.
  • 2001 - ZR2 package extended to Chevrolet Tracker
  • 2002 - ZR2 Trackers were upgraded to LT Editions, offering optional leather upholstery
  • 2003 - (sometime during production year) ZR2's start shipping with General Ameritrac tires instead of the classic BFG's.
    • GM discontinues S-Series Pickups, this is the last year that the ZR2 is available on a pickup
    • A ZR2 Jimmy surfaces in Canada. This came as a surprise because it was unavailable in the USA. [2]
  • 2004 - ZR2 only available on Blazer models. In a shocking move, for the first time the ZR2 is offered with a 2WD model.
  • 2005 - This is the last year for ZR2 Blazers (USA) /Jimmys (Canada)
    • GM discontinues ALL remaining S-Series models, ZR2 is phased out.
Though several inquiries were made by interested parties, the ZR2 production numbers are unknown.
[edit] Woes of "ZR2 Specific" in the Aftermarket
Unlike many automobile lines, especially those in the Four-Wheel Drive category, the ZR2 did not garner much aftermarket support. One of the reasons could be a simple lack of knowledge by aftermarket companies about the differences between the ZR2 and the Regular S-Series models and the ZR2 incompatibility of their S-Series applications. Or simply because it wouldn't be cost effective to pursue ZR2 Specific applications due to the scarcity and seemingly low production numbers of the ZR2.
During its production only a small handful of lift options were available to ZR2 owners:
  • 5" BDS Suspension Lift
  • 6" Superlift Suspension Lift
  • 2" Superlift Suspension Lift
  • 5" Trailmaster Suspension Lift (the TM5 was shortlived, and has been discontinued)
  • 2" Performance Accessories Body Lift (1998+ Models)
  • 2" BDS Body Lift (1998+ Models)
  • 3" Performance Accessories Body Lift (Pre-1997 Models)
Another hindrance was the Wheel Backspacing (6") and size of the wheel wells. Generally tire size could only be upgraded 1-2" (diameter) without having to make modifications by way of cutting. Many enthuisiasts did find that certain Suspension/Body lift combinations made way for more room thus requiring less cutting, however this still didn't allow for a tire larger than 33x10.50" (this is the subject of much debate within the ZR2 community).When it comes to wheels many are available with the correct bolt pattern, however the majority do not have the correct backspacing. Thus leaving very few Tire/Wheel options.
With the ZR2 having a wider track, many accessories that "bolt-on" to the frame had to be ZR2 specific. This meant that non-ZR2 Safari Bars, Brushguards, and Receiver Hitches that are "S10 Compatible" required special unorthodox modifications in order to be installed. These modifications often required a skilled welder or machinist in order to ensure safety hadn't been compromised.
Compared to the regular S-Series, the ZR2 was equipped with a "beefier" front end consisting of components that were supposed to be built stronger in order to sustain the punishment an off-road vehilce. Despite this, the front end components like Ball Joints, CV Joints, CV Axles, and Idler/Pitman arms were susceptible to premature wear & tear and failure. Again the lack of aftermarket support comes into play because many of the Discount/3rd Party Auto Parts retailers do not recognize the difference between a 4WD S10 and a ZR2. This meant that ZR2 owners were left with no option but to make their repairs with the same weak (but expensive) parts available from GM. This went on for years until a couple aftermarket part companies took notice to the ZR2 and began manufacturing ZR2 Specific replacement parts. However due to their small distribution, finding the parts in a local store is near impossible. Therefore purchases are usually made via the internet.
[edit] The ZR2 Community
Popularity for the ZR2 led to the creation of Zr2.com in December of 1998. The original administrators felt it necessary to have an information source on such a unique truck as well as a place for enthusiasts to convene and share tips. Through mostly word-of-mouth the community started to have considerable growth in mid-2001. During this time the nationwide ZR2 Community had subdivided into several regional groups, East coast ZR2 (later renamed to NEZR2), LonestarZr2 (later renamed to TXZR2), Midwest ZR2 Association, ZR2NW, ZedR2 (Canada), and SoCal. By 2005 the community grew to a membership of more than 7000 members. The community consists of enthusiasts of all age groups, and regions of North America. They are strong believers in the Tread Lightly policy, and are known for taking extra precautions for personal safety and environmental conservation.
The group was able to successfully organize several annual "National" scale events at Paragon Adventure Park in Pennsylvania, Badlands Off-Road park in Indiana, Silver Lake, Michigan, and at Moab, Utah. Aside from 4x4 Jamborees, ZR2.com was involved in several charitable programs including Toys for Tots and local Can Food Drives organized with the help of the regional groups. The group gained national attention when one of their members was chosen to participate in the Annual Petersen's 4-wheel/Off-Road "Ultimate Adventure" in 2003 with his IFS S10 ZR2 [4]. Zr2.com went strong until June 2006 when the Administrator took it upon himself to close down the site. Over the years a wealth of information was accumulated and is still available on its Forum in the form of Archives. The majority of the members have since moved onto alternative national and regional groups. (see External Links)Since the shutdown of ZR2.com ZR2USA.com has since become the main repository of knowledge for these dedicated ZR2 owners.
NEZR2 is currently recognized by the U.S. Government, and is an incorporated club of the Northeast Association of 4WD Clubs.
post #11 of 14 Old 07-18-2007, 01:40 PM
VIRev's Avatar
User is: VIRev is offline
Re: Gmc Highrider?
instead of dicking around, check your RPO codes in the glovebox. i already know for a fact that that is not a ZR2/highrider, but to prove it for your self, check in there. if it says G80, it has a locker, and if it says ZR2, its a highrider, but it wont.
VIRev is offline
post #12 of 14 Old 08-09-2007, 01:44 AM
Mutha-****in Mini-Truckin
MikeLightning's Avatar
User is: MikeLightning is offline
Send a message via AIM to MikeLightning
Re: Gmc Highrider?
i had the same questions about mine when i bought it but sure enough when i looked in the glove box it said ZR2 plain and simple. if it don't u aint go 1 ...sorry
oh and another question... what is the rear traction bar ment for? cause i broke the mount on mine and i took it off all together. i dont see a difference.
post #13 of 14 Old 08-09-2007, 02:51 AM
Mikz86TA's Avatar
User is: Mikz86TA is offline
Re: Gmc Highrider?
Its just a 4x4 Crew. Nice truck though. The ZR2 and Highrider are the same. Except the GMC Hirider had painted flares and the Chevy ZR2 had gray. The flares were added because they have the 8.5 diff and a WIDER stance. Also skid plates and higher, yada yada. The ZRS is a package on Chevy and GMC Crews like yours. They added a roofrack, some black/polished 5-spoke wheels, bed rails, decals on the rear, step bars and fog lamps. Maybe a few more items. Kinda like a Baja look to them.
2003 S-10 ZQ8 - 262/M5 1986 Pontiac Trans Am - 355/A4
The S10 Project : http://www.s10planet.com/forum/showthread.php?t=15987
The Trans Am Project : http://www.s10planet.com/forum/showthread.php?t=15435
Mikz86TA is offline
post #14 of 14 Old 08-25-2007, 07:00 AM
Professional Insultant
TokoDragon's Avatar
User is: TokoDragon is online now
Send a message via MSN to TokoDragon
Re: Gmc Highrider?
If you have the G80 RPO code you're good to go off roading in the crewcab. They have a whole site devoted to just the Crewcab s-series, there's someone on here that has a crewcab setup nice for off roading.
