Front axle wont engage in 4hi or 4lo... HELP!! - S-10 Forum
post #1 of 12 Old 04-12-2009, 07:36 PM Thread Starter
User is: BelviZR2 is offline
Hey guys
I just picked up an 03 ZR2 and i went to go take it for its first off road adventure and i found out the 4 wheel drive wont engage!!! The transfer case engages like its supposed to but the front end still free wheels. Am i missing a motor or a vacuum line some where? hopefully some one had the same problem and can point me in the right direction. Thanks
BelviZR2 is offline
post #2 of 12 Old 04-12-2009, 07:53 PM
Game Pop. Control Agent
Tyhuck's Avatar
User is: Tyhuck is offline
Re: Front axle wont engage in 4hi or 4lo... HELP!!
I think everyone has had this problem or knows someone who has. First thing to do is check the actuator under the battery tray. If thats still good, then it gould be a vac. line so give em all a check. If thats not it, then check the cable that engages the front diff. It may be frozen. It could be a number of things but I would check the actuator first. That was the problem I had. But, after i replaced it I am still haveing vacuum problems. so I will try to find out how to fix that in my own thread.
-- 2001 S-10 ZR2. Too many mods to list. It upsets me too much to add up all the money I spent.
Some day, Vortec 5.3 swap, SAS, and a bedlined body.
Tyhuck is offline
post #3 of 12 Old 04-12-2009, 08:24 PM
Overhead Console Expert
Raven's Avatar
User is: Raven is offline
Send a message via AIM to Raven
yes check your vacuum actuator under your battery. if its bad then your front differential will not engage.
1999 S10 4.3L Zr2
Overhead Console Dude
Raven is offline
post #4 of 12 Old 04-12-2009, 10:30 PM Thread Starter
thanks guys ill give it a look and let ya know
BelviZR2 is offline
post #5 of 12 Old 04-13-2009, 10:20 PM Thread Starter
i found the problem. one of the three vaccum lines melted through and thats why the front axle wont engage
BelviZR2 is offline
post #6 of 12 Old 04-15-2009, 05:23 PM Thread Starter
still no luck any other thoughts?
BelviZR2 is offline
post #7 of 12 Old 04-15-2009, 09:43 PM
Tyhuck's Avatar
Im at a loss. Im also in the process of tracking down a leak but my 4wd is working OK (knock on wood).
Tyhuck is offline
post #8 of 12 Old 04-15-2009, 10:31 PM Thread Starter
could the encoder motor be bad? there isnt any vacuum anywhere in the 4wd system thats my next thought cause i ran a good line to the actuator under the batt tray and it pulled in fine
BelviZR2 is offline
post #9 of 12 Old 04-15-2009, 11:41 PM
Raven's Avatar
might be...just hit the 4hi/4lo button it neutral and listen for the transfer case to switch. if it doesn't....then that's most likley your problem.
1999 S10 4.3L Zr2
Raven is offline
post #10 of 12 Old 04-16-2009, 07:40 AM Thread Starter
it switches ok. the lo range engages on the rear axle without any problems.
BelviZR2 is offline
post #11 of 12 Old 04-17-2009, 05:31 PM
Raven's Avatar
did you replace the vacuum actuator?
or did you just replace the vac line?
i would venture to guess that your vacuum actuator is bad.
1999 S10 4.3L Zr2
Raven is offline
post #12 of 12 Old 04-20-2009, 08:06 AM Thread Starter
i finally broke down and conned my bro who is a mechanic to look at it and one of the fittings was clogged. go figure
thanks a lot tho guys
BelviZR2 is offline
