95-97 blazer headlights
Go Back   S-10 Forum > Specific Model Forums > 2nd Gen Forums > The 'SS'
Old 01-21-2009, 09:00 PM   #1
24digger's Avatar
What all is needed for this conversion? Does everythng come mounted on the light to bolt to the core support?
I know I need the headlight pigtail, just wandering if everything is on the light.
Old 01-21-2009, 09:16 PM   #2
03XBLAZER's Avatar
Re: 95-97 blazer headlights
All you need are the pigtails for the lights. The one's I got are PULSE FX #'s 84792, for the 9005 bulbs, & 84793, for the 9006 bulbs. These are rated for high wattage and high temp. Think I got them from Autozone. I've got the wiring diagram somewhere. If you need it, PM me. The headlights I got were complete and bolted up almost perfect. I put them in my 97 truck. Core support will work, but one of the mounting screws is kinda in a tight spot, but they will fit.
Old 01-21-2009, 09:20 PM   #3
24digger's Avatar
Ok, sounds pretty simple, thanks.
Old 01-23-2009, 02:23 AM   #4
Crazy As ****
leadsled2020's Avatar
you also need these clips..... 2 will be enough.....
they go here.....
here is a thread that should help you out....
http://www.s10forum.com/forum/f72/blazer-lights-361102/
Old 01-23-2009, 07:16 AM   #5
24digger's Avatar
Thanks for the info and link
