Still 2 High
Why is my damn tv fuzzy?
Ok, I know zero about tv's, I turn it on a picture shows up... that's all I got
I have an older apex, no fancy flat screen or anything just a regular tv... The higher the channels go, the fuzzier it gets. All the other tv's in the house are fine, and I know it's not the set itself cuz when i watch movies it's fine. I'm pretty sure the cable is spliced into the main line in the basement, with a 4-1 type adapter, at the other end of the house. Any ideas? I'm getting sick of watching fuzzy tv, food network is almost un-watchable ![]() |
Re: Why is my damn tv fuzzy?
That adapter/splitter could be bad Ive had it happen.
You definitely have a loss of signal. I'd have the cable company come out and check.
Wow, how weird. I just had Time Warner out to my house this morning. |
Still 2 High
Educating da masses
2. The leg that that TV comes off of from the splitter is bad. 3. The run to that TV is longer than the others and causing signal degredation due to drop loss. 4. Bad fittings. 5. The run to that TV is just shot and needs to be replaced yourself. I could actually go on with a few other things, but it's best to have your cable company can come out and test the signal with a meter. Don't be surprised if they charge you to replace the run if that's what's needed. Shouldn't be much. The cable company I used to work for only used to charge $10 per outlet. That's cheaper than going out and buying the cable yourself. If I were closer, I would come out. I still have all my tools, and a foot or two of cable. |
Still 2 High
Hmm... there is probably 20 or 30' of cable run in the basement before it comes up into my room. I've wiggled the cables coming out of the splitter and that didn't seem to help at all. |
Educating da masses
Fronkensteen
Have you tried and Amp? I had shitty picture in the garage, threw an amp inline and it fixed the picture.
Did it just suddenly change? The best way is to throw a meter on it and check for signal strength. If you can't do that, pull the tv and take it to where you know another TV is working fine and hook it up.
Still 2 High
Not really, it's always been kind of fuzzy... The cable company changed all the channels around a month or two ago and since then it's been a little worse (I think, the higher channels are worse than lower ones and most of what I watch is on the higher channels now that they changed them all)
Jake--I didn't even know they made such a thing My tv by far has the most cable run to it from under the house so maybe this is it... |
Fronkensteen
Yea, excess cable could definitely be a factor. And yeah just go to like ace hard ware or a radioshack, I can't gurantee it'll work for you, but it did for me. Basically it just boosts the signal to the TV. You're not running a cable box in this room are you? it's just cable direct into the back of the TV?
Poor signal strength shows on higher channels. You got mice in your house? LOL
Still 2 High
Nope, no cable box. There are 2 or 3 connections under the house before it get's to my room... I'm gonna move my tv around and see what happens before I start looking into different splitters and amps. Performin Norman-- nope, no mice. |
Still 2 High
Ok, moved the tv to my sister's room and the picture is 10x better... What do you guys think? Amp or splitter?
BuenosDingDongDiddlyDias
I'd check your cabling type first.
Educating da masses
Old School Rob
But i would pick up a signal booster should work for you. |
crap
I have the same prob. I had my Direct installed back in 2004 and
have never updated the wiring. or maybe it's the TV I bought back in 1998/99 I guess..It doesn't even have a dig tuner. The actors have a red ghosting effect to em sometimes.. I am definitely a cheap ass.. Last edited by bg's : 11-01-2009 at 02:15 PM. |
Old School Rob
after i made the coment, was only kidding with you Juice |
I'm a little late on this one but...
1. Make sure all of your connections are tight. 2. Upgrade any splitters to higher bandwidth models (1-2Ghz) 3. Replace cables with higher RG6 (like someone above mentioned) Check to see if there are any bends in the cable run to the tv with bad reception. If a coaxial cable gets bent, it can degrade the signal dramatically. This is more than likely the problem. |
