HP Laptop Troubles
Go Back   S-10 Forum > OT Forums > Geek Squad Central
Old 09-28-2009, 09:45 AM   #1
'02 Sonoma X-Cab
actafool4187's Avatar
HP Laptop Troubles
I recently scored an HP Pavillion dv5000 laptop for a low price off a buddy of mine. I got a new battery for it, because the old one didn't hold a charge, and I reformatted it because it ran like ass. The only issue it is having is that occasionally, it will just randomly shut itself off. It was doing this before it was reformatted when it had too many things open at once, but it did happen once last night as well, and all it was doing is downloading some Windows updates. I believe that it is a cooling issue, but the fan works fine. As long as I have a cooling station underneath, it's fine. This is OK at home, but it's extra space and cords when I take this outside of my home. Any ideas?
Old 09-28-2009, 11:14 AM   #2
Fannatick's Avatar
Re: HP Laptop Troubles
Its most likely a cooling issue. I would open the fan case and use compressed air to blow out dust and other crap. The older the comp the more dust you'll get out which will help keep your laptop running cooler and reduce over-heating issues.
Also make sure you don't have a lot of programs open in the background, this will increase your CPU work load causing more heat.
As for when your out and about, theres not a whole lot you can do. Only do simple things that don't require a lot of CPU power (more CPU power = more heat) and keep the running programs to a minimum.
Old 09-29-2009, 09:04 PM   #3
VortecSonoma's Avatar
ive got a DV9000, the DV-series are famous for having shitty motherboards, more than likely its just the board, ive replaced mine twice, but it was free because it was covered under hp's recall which is expired now.
Old 09-29-2009, 10:32 PM   #4
'02 Sonoma X-Cab
motherboard and hard drive were already replaced, and ram upgraded
Old 09-30-2009, 12:16 AM   #5
hmm, now that you have me thinking, i remember i had a client that had a Toshiba tecra 9000's, and it has a similar problem, with cooling, fan worked great, but it would give the blue screen of death every-time it got to hot, i ended up having to modify .... i cant remember, when i go into my shop tomorrow ill see what it was and hit you back.
Old 09-30-2009, 12:29 AM   #6
'02 Sonoma X-Cab
i'm pretty sure it's just cooling. i have had it running for a few days now. as long as it's on the cooling station, no problems
Old 09-30-2009, 09:27 PM   #7
did you take it apart and clean it?
Old 10-01-2009, 02:36 AM   #8
'02 Sonoma X-Cab
negative. until the cooling fan cannot keep it cool, it will be fine. then i'll tear it apart and compressed air the mess out of it
Old 10-01-2009, 03:21 AM   #9
Educating da masses
SgtM's Avatar
Why wait? Spray some compressed air through the side vent.
Old 10-01-2009, 01:10 PM   #10
Fannatick's Avatar
Yeah, I would hit it with some compressed air in the vents. There should be a screw or two holding the fan/cover, you could slightly open it up enough to get compressed air in there.
Old 10-02-2009, 04:50 PM   #11
rmoore911's Avatar
just take it apart already. . .it doesn't take but a few minutes to do. . .and any bit of overheating could be your last bit of overheating. . .it only takes one good cooking to screw it up permanently. . .my desktop had a problem where it was running a bit warm, but i always had my BIOS set up to shut down the system if it was starting to get too warm. . .well, i walk into my room one day, and it's entirely way to hot in that room, and it wasn't from the outside temp. . .my computer is running and my temp monitoring program said the CPU core temp was over 90 degrees C. . .the computer never got that warm again, but it was only a matter of a week or 2 before it needed to be replaced because of damage to the motherboard and processor. . .
Old 10-02-2009, 05:24 PM   #12
Fannatick's Avatar
^^X2
Old 10-28-2009, 09:43 PM   #13
'02 Sonoma X-Cab
ok, i have determined that it must be battery related somehow. it started shutting itself off again. if i remove the battery and just let it run straight off the charger, it works. before doing this, it says my battery has no charge! it is a brand new battery, so idk wtf is going on. anymore ideas? this way works fine, but if i accidentally unplug it, it will die and i will lose whatever i am doing
Old 11-06-2009, 09:31 PM   #14
Nate8727's Avatar
The contacts where the battery are supposed to charge might be dirty or broken. Take the battery out and have a look. If they're dirty, try cleaning them with a q-tip and some rubbing alcohol. Since the battery is new those contacts should be fine.
Old 11-11-2009, 01:56 PM   #15
ZzzzZZoooOOOmMmMMmm
eriley's Avatar
dv5000 anything sucks dick, throw it away and get a real computer. I ****ing hate mine, its on its 4th hdd, 2nd screen, 2nd touch pad, 2nd case, and the disc drive pops out randomly I will never buy hp again.
Page generated in 0.58132 seconds with 31 queries
[Output: 88.33 Kb. compressed to 82.07 Kb. by saving 6.26 Kb. (7.09%)]
