Best way to connect PC to TV
Go Back   S-10 Forum > OT Forums > Geek Squad Central
Old 10-10-2009, 10:31 AM   #1
Avgas's Avatar
Ok, so I want to connect my Pc to a 32" TV I got in my bedroom, mostly to watch .avi format movies. I got a second monitor output as well as s-video output. My PC also has a TV tuner that I plan to use to DVR tv shows, then play on the TV. Which connection would work best for me?
I also got a ps3 that I could use as a media server, how would I transfer all my media to the ps3?
edit - TV has VGA inputs as well as s-video inputs
Old 10-10-2009, 11:06 AM   #2
Avgas's Avatar
Re: Best way to connect PC to TV
edit - I also see a DVI output on the PC
Old 10-10-2009, 11:19 AM   #3
drunk and bored
Sir Toad's Avatar
well..to use dual outputs in my experience,you must use one dvi output and one analog output....vga and s-vid are analog,you will only be able to bounce between two analog displays not view both at the same time.
dvi-vga adapter for your tv and vga for your monitor
Old 10-10-2009, 12:48 PM   #4
baggin
AmDD's Avatar
s-video is going to give you very low quality video. dvi is probably your best bet unless you have HDMI.
Old 10-10-2009, 01:22 PM   #5
The Blown Blazer's Avatar
x2.... works for everyone I've seen.
Old 10-10-2009, 04:11 PM   #6
Avgas's Avatar
How about a dvi to hdmi cable?
http://www.newegg.com/Product/Produc...ted-_-12339007
Old 10-10-2009, 04:15 PM   #7
drunk and bored
Sir Toad's Avatar
sure! that's how my monitor is connected
Old 10-10-2009, 04:41 PM   #8
Avgas's Avatar
cool, going with this one
http://www.meritline.com/6-hami-male...--p-22431.aspx
Old 10-21-2009, 04:57 PM   #9
Avgas's Avatar
ok, I bought a DVI to HDMI adapter, and I connected my PC's dvi out to my TV's HDMI port, however, I get no signal, what I am missing here?? Display settings? Im on Vista
Old 10-21-2009, 05:02 PM   #10
BuenosDingDongDiddlyDias
xJuice's Avatar
Was the computer off when you plugged the cable in? If not, restart.
Yes you need to enable the monitor in the display settings (can't remember off hand where exactly that is in vista). Should say somethign to the effect of: Extend my desktop onto this monitor.
Old 10-21-2009, 05:20 PM   #11
Broken Handed Superman
MeltingPlastic's Avatar
i use a DVI to HDMI adapter from my media center to my tv and it works just fine! just check around your settings and see whats up
Old 10-21-2009, 05:22 PM   #12
Avgas's Avatar
Ok, I messe with the setting and got it to show up as an extension of the monitor, but how do I make them both show the same image?
Old 10-21-2009, 05:35 PM   #13
Avgas's Avatar
I pulled up Nvidia control panel, and there is a option to clone the screen, but it won't let me set the resolution of the second screen, and it wont show up
Old 10-21-2009, 07:57 PM   #14
xJuice's Avatar
Well you can't clone the screen w/o them both being the same resolution. Quite possibly the tv doesn't want to display the resolution you're using.
Old 10-21-2009, 09:31 PM   #15
Overhead Console Expert
raven2510's Avatar
that right there^^
Old 10-21-2009, 09:48 PM   #16
Short White kid
Stehl's Avatar
download a program called utlramon. its not free but not expensive. It lets you run two seperate displays at any resolutions you want. You need a decent graphics card tho. thats how I do it. I browse the computer on my widescreen monitor and watch movies on the big screen. or when im not watching movies, I put my messenger and itunes on the big screen. You can also move your mouse freely between the screeens.
Let me know if that solved your problem.
Old 10-21-2009, 09:49 PM   #17
crap
bg's's Avatar
Going off post as usual, but for some of the best cables
with a lifetime warranty, good prices & free shipping go
here.
I use their Cat 5 cable and am very happy with them. The
no snag feature on the ends make it easier not to get that
da*n lock stem broken off when releasing etc.
http://www.optimization-world.com/
Old 10-21-2009, 10:06 PM   #18
Educating da masses
SgtM's Avatar
Cables:
www.monoprice.com
If you go in to the dispaly properties, you should see 2 monitors listed. You should also be able to control the resolution for each one individually. What you're looking for though, is the check box to extend your desktop to the second monitor. That should clear it up.
Old 10-22-2009, 06:58 PM   #19
Avgas's Avatar
Quote: Originally Posted by SgtM
Cables:
www.monoprice.com
Both monitors work fine, and I can set the resolution for both individually IF I am using the second monitor as an extension. However I want both to show the same thing.
I downloaded Ultramon, but as soon as I enable the second monitor, it automatically shows up as an extension, how do I make both show the same??
Old 10-22-2009, 07:19 PM   #20
Avgas's Avatar
ok there is a "mirroring" option on ultramon but it uses a lot of resources
Old 10-22-2009, 11:09 PM   #21
VortecSonoma's Avatar
you should be able to do it with out 3rd party software.... might just be me, but if your tv has VGA Input and your computer has a VGA output, i would have just went with the Vga, yes its not Digital, but i dont really see that big off difference in the quality. whats the make and model of your video card and whats the make and model of your tv?
Old 10-23-2009, 12:07 AM   #22
Short White kid
Stehl's Avatar
ultramon is what i use. But i built my computer and its like high up in specs. so it runs fine.
Old 10-23-2009, 10:07 AM   #23
Fannatick's Avatar
specs of said computer?
Old 10-23-2009, 10:31 AM   #24
bigb19812000's Avatar
use tversity in tandem with your ps3.
Tversity is free and it turns your PC into a media server that you can acess through your local network and even through the internet as long as you have a wireless router
hers a link http://tversity.com/
Old 10-23-2009, 06:07 PM   #25
cars4fun2004's Avatar
Try this. turn the computer off. Unplug the cable going to the tv. Turn the computer back on. Boot it up using its screen. Then once you have your desk top up plug the cable back into the tv. see what you get. thats how I get mine to work the way you want. I can then set each one up by itsself.
Mike
Old 10-23-2009, 06:25 PM   #26
Short White kid
Stehl's Avatar
Probably nothing much these days compared to the new tech.
But ,
Has
3.0 quad core
8gb of ram.
two 500gb sata drives.
Nvida 9600 gfx card
Liquid cooled.
some kool lighting.
Old 10-24-2009, 05:57 AM   #27
crap
bg's's Avatar
Boy those are good prices at monoprice.com Beat the heck out
of my place..
Old 10-24-2009, 12:22 PM   #28
Fannatick's Avatar
3.0 quad core
8gb of ram.
Nvida 9600 gfx card
Liquid cooled.
some kool lighting.
Those are some good specs. 8 gb of ram is sick.
Old 10-25-2009, 12:28 AM   #29
All motor... boating ;)
Diablo's Avatar
I use my 360 with PlayON. I can view HULU and control it directly through my 360. Free trial at the media mall site for playon. I ended up buying it, I believe there is a sale for 30$ going on right now. It's an excellet program, also has some plugins so you can view spike tv (web episodes) NBC, justintv, and many other plugins available.
Old 10-25-2009, 12:29 AM   #30
Diablo's Avatar
From now through Halloween get PlayOn for only $29.99. Don't miss out on this 25% off treat. Knock on our door by clicking the buy button now and enter Coupon Code OCT09. Hurry over though, after Halloween all we'll have left is tricks.
http://www.themediamall.com/playon/
** You HAVE to purchase this software, there are NO serialz or any cracks anywhere. They monitor the IP and if it's used by more than one IP, they will contact you and then eventually cancel that serial **
But it's well worth the money!
Old 10-27-2009, 04:17 PM   #31
VILLE
wen my xbox took a shit i connected my laptop to my tv using an svid cable and then a cable i got with a camera that converts an audio jack to red and white av cables for the sound worked perfect for my likings
Old 10-28-2009, 05:06 PM   #32
Avgas's Avatar
I just configured Tversity here, pure awesome!
Old 10-28-2009, 05:36 PM   #33
be careful, i have to use an older version of tversity, the newest version has some issues with my xbox 360 for some reason... kept getting a lot of buffering notices making it unbearable to watch anything
Old 10-29-2009, 12:22 AM   #34
Short White kid
Stehl's Avatar
Thanks. Thats my other hobby besides working on my truck. Computers.
Old 10-29-2009, 12:11 PM   #35
Fannatick's Avatar
Same here. I'm waiting for Black Friday/Christmas to build me a new comp. Nothing too extreme (it's my first actual build) but something solid that will last a couple of years (and easily upgradable).
Old 11-01-2009, 09:53 AM   #36
Yes tversity is the shit .It even has preset optimum settings for almost all platforms
Page generated in 0.62920 seconds with 31 queries
[Output: 163.86 Kb. compressed to 149.98 Kb. by saving 13.89 Kb. (8.48%)]
