Where to get a good rag joint?
Old 10-27-2009, 03:10 PM   #1
SpiderDallas's Avatar
I was wondering is there a good place to get a replacement rag joint besides the dealer it like 260 from them. You can't just replace the joint it comes with the whole shaft. I have a 96 blazer by the way
Old 10-27-2009, 03:12 PM   #2
4x4 v6 blazer
neo71665's Avatar
Re: Where to get a good rag joint?
Take it out and replace it with an old jeep cherokee steering shaft and get rid of the rag joints all together.
Old 10-27-2009, 04:09 PM   #3
Drumer919's Avatar
Okay I dont understand how to do that, I have read everything I can find about it. I have the jeep shaft in hand but I dont see how the stock shaft attaches to the steering column so I havent taken the stock shaft out and actually tried. How does the stock shaft come off and the jeep shaft go back on? I can see how it attaches at the steering box its self, its only at the firewall connection I'm not sure of.
Old 10-27-2009, 05:26 PM   #4
got cones?
rentedmule's Avatar
If you don't want to put in a jeep shaft or a U-joint check the "HELP!" parts section at any parts store. They have rag-joint repair kits for ~$10. You just drill out the rivets holding the old piece of fabric in and then bolt in a new piece.
There's no way to take the old rag-joint off of the shaft without cutting it up - that's why the dealer only sells it as a complete setup.
Old 10-27-2009, 05:51 PM   #5
So how do you do a jeep shaft then does it bolt right up or what? I was asking that in the first place if there was somewhere cheaper to get the rag joint assembly.
Old 10-27-2009, 05:58 PM   #6
4x4 v6 blazer
neo71665's Avatar
Rag joint
http://www.summitracing.com/parts/RNB-31000
simple search on here will give you the jeep shaft how to. Most the time its only $20-40 at a j/y and uses a u-joint instead of the crappy ass rag joint.
Page generated in 0.56571 seconds with 31 queries
[Output: 56.66 Kb. compressed to 53.61 Kb. by saving 3.05 Kb. (5.39%)]
