Weird clunking noise when turning and hitting bumps
I own a 2000 chevy s10 ZR2 with about 124,000 on it. Whenever I turn very hard, or hit a hard bump I hear a clunking noise. I have jacked it up and jerked both tires back and forth and there is no play so I don't believe it to be a ball joint. I tried my best to check the cv shafts and found no play. It honestly feels like it is coming from the torsion bar crossmember. I replaced the two bar link assemblies on the crossmember and it seemed to help for about an hour and then started doing it again. Any suggestions!
thanks, steve |
Better post-em.
Re: Weird clunking noise when turning and hitting bumps
YES! same problem here it sounds like the front is bottoming out and makes a clunk noise, i cant figure out what it is either... i haev drop spindles but stock coils so i duno what is goin on
Suicided Member
Not sure if it's the same problem I had, or not, but here's what happened to me. When I turned the wheel all the way and drove (like making a tight turn) I got a cluncking sound and felt a slight "shift" in the truck (like something had dropped). After playing hell trying to find what it was, I took it to the dealer and had them look at it. It turned out to be a bushing. I sold that truck, and got my 02, and guess what same thing. Since it was still under warranty, I took it to the dealer, and had the bushing replaced, and haven't had the problem since.
Exactly which bushing was it ? Thanks........................
Gots me a 4x4 too!
Mine just started doing this today. I'm bagged with drop spindles, and i am 100% sure it has nothing to do with the bag. I've been bagged for a year with no problems/strange noises. How long can i drive like this before I get it fixed? I work full time and it is hard to make time to fix it.
Better post-em.
is it the bushing on the stabilizer bar?
mine had the same problem, I put some grease under there (http://www.s10forum.com/forum/f198/how-to-lube-your-front-end-103812/), problem solved!
I have noticed it is not doing it now since it is so cold, it does it more when it is warmer out, so i'm thinking it is a bushing too. Maybe a body bushing, the front left right under the drivers floorpan to be exact. Has anyone else heard of this. Every once in a while when I hit a bump I feel like a tin can effect with my foot on the floor.
Gots me a 4x4 too!
I have a 4x4 and mine does the same thing. The noise sounds like it is coming from the pasenger side steering components.
mike |
Better post-em.
hmm mine started doing it ever since i changed from my sumer rims to my winter stockers... it feels like somethign is bottoming out cuz if i hit abig enough bump i can feel the truck jerk upwards from the bump...i know the back bottoms out on the bumpstop brckets btu it feels like theres somethign up front going on...
In need of a V8
I think I have the same problem. It's kind of a clunking crunching noise. Actually it sounds like if you take a piece of rubber and try sliding it against something dry, so it's probably a bushing. It's only from the passengers side and only seems to happen when I'm turning or stopping really slowly. I'm going to check it out when I put my new drop parts on in a few days.
Certified Lunatic
Most of you should be looking at the idler arm. It is on the passanger side [duh... except for you oddballs with right-hand-drive Xtremes] and especially prone to wear on the ZR2s. This is because (a) we ZR2 owners beat the hell out of our trucks and (b) as far as I can tell, it is the same idler arm as a regular 4x4. In fact, I wouldn't be suprised if it is the same part [FA1114] as EVERY S/T 10/15 out there from 1994 up, though I will check tonight when I go to work. Anyway, has anybody ever tried McQuay Norris Extreme suspension components? And if I can't match up the arm tonight, does anybody here know for a fact whether the ZR2s use the same arm? Any other suggestions for some heavy-duty steering components for a stock suspension?
Maryland blows (:
ditto on the prob. 99 4x4 blaze.
getting fixed after winter! |
Neil
Old thread but ill chime in...Had this problem a while ago. 02 with 4.3 the passenger side control arm bushing couldnt take the heat i suppose from the manifold. Literally made it fall apart and the cross shaft was clunking around during turns. New bushings on all arms, problem solved
| Sponsored Links | |
Advertisement | |
