U-Joint question---> -see photos
I have a 1997 S-10 Reg cab pickup 2x4, 97,000 miles and a 5 speed.
I want to replace both U-Joints on my 1 piece drive shaft. I think I have the nylon insert type on the front U-Joint ![]() But I can.t tell on the back.(maybe the same as front) ![]() From what i understand I need to use mapp gas and heat U-Joint to melt nylon out correct? What about the back U-joint?(might be the same way?) Is the front and back the same u-joint? My truck vibrates at about 45 miles per HR. |
I SHIT BRICKS
Re: U-Joint question---> -see photos
from all the ones ive done its the same.....also after you heat it take a socket thats a lil bigger then the circle on the joint and one that is slightly smaller take the smaller one and put it on the u joint and then take the bigger and put it on the opposite side put it in a vice and tighten the shit out of it.....if u dont have a hydrolic press
for an easy out with minimal tools just use a hammer and socket.
Happy with ugly truck
Just heat up the joint, the nylon shit will ooze out. Then pound it off like normal. You don't need MAP gas, propane will work. It's just plastic.
Mapp gass 5300 BTU
Propane 2500 BTU |
Dialed!
moved
I'm slap happy, bitches!
nah, it's his u-joints, look at the broken chunk out of the cap on the rear yoke joint, i can also see hit marks on the driveshaft where the thing has been hitting. you better soak those rusty assed cap bolts before you take them off.
SoCal Football
You have a plastic insert on the back joint as well.
One can see the dimple for the insert. Spicer Pro Grade are your friends. Any other is just a short ticket, unless they are Currie prepped. You can also use AC/Delco as most all of the drive line parts are Spicer. Like this, from here. ACDELCO Part # 45U0136 http://www.rockauto.com/catalog/x,ca...,parttype,2392 |
I swapped tires from front to back with NO change. Will do U-Joints this week. And let you know what happens.
I'll do it tomorrow maybe
Location: Kingston Springs, TN. User is: OffLine ![]() ![]() ![]() |
You could have the shaft balance checked.
I hate seeing all that rust and the extra effort it causes. Definitely check the shaft to make sure it runs straight; isn't twisted or bent. guess I'm spoiled living in AZ.
RicG |
U-Joints were the problem. Had NAPA put U-Joints in. $15.00 each, they had to use a acetylene torch to break the caps loose (way to much rust) I tried with Mapp gas and NO luck. Anyone know what fluid I use, to change oil in the 5 speed transmission? (1997 S10 Reg. cab 4 cyl. 5 speed 2x4)
I think I have the NV 1500 transmission. 3 qts? |
Dextron III?
http://media.gm.com/gmc/mw2ben.html |
3T40---------- Wrong transmission
