The best way to clean up the frame
The 91 ex cab 2wd, that i purchaced a while ago is my next V8 swap project. I started to do some poking around with the truck to see what all needed to be done to clean her up. I removed the bed to do some work on it, when i noticed that the frame seemed a little to rusty for my taste, and kinda gave up on it for awile. But to day i had the notion to poke around some more, and much to my shagrin, the rust turned out to be just some kind of undercoating. I started to scrape along the surfice of the frame in different places, and the undercoating started to come off. Some of it had to be perswaited, but none the less i believe i'll tare the whole truck down to clean the frame up, and do some work on the floor of the cab. My ? is, should i have the thing blasted, or would something like POR15 be good enough.
Re: The best way to clean up the frame
If you're gonna do it, don't halfass it. Get it blasted, or clean it yourself. Don't just cover it up.
Yeah i tried that approach, with some bed liner spray. But it started to chip off in different places, which is why i decided to poke around with the frame. Once i realised that the frame was in much better shape than i had thought, i got pumped and went to town on it. The only problem with getting it blasted is, i have to haul the frame to the shop. I did a frame with POR15 a few yrs ago, which seemed to work out ok but it did'nt have all the crap on it like the frame i have now. I think blasting is around $100 to a buck 50, whare POR15 is about 1/2 that.
The How-To Guy
Location: Cache, OK User is: OffLine ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
my undercoating is starting to chip off here and there, mostly up front by the wheel wells.
also if you have a pressure washer you can blast that stuff off with that. I plan to do that someday and get the frame repainted but thats a long time from now. |
Molon Labe
Get a wire brush and some brake cleaner. It should come off easily with that combo--just a little more work than a blaster would be. Even if you get it all off, use the POR15 anyway, it's good stuff.
