strange vibrations...
Old 06-26-2008, 11:58 PM   #1
stayin static
blazeshaska's Avatar
blazeshaska is on a distinguished road
well ive had my truck lowered for a while, and i just never noticed it before until i drove my mom's honda civic around... my truck has serious vibrations when i drive.
i thought it might be the tires stiff in the morning, but now i think its more serious. whenever i drive straight, my steering wheel shakes. whenever i brake, the entire truck shakes, like an up and down feeling, kind of like a hump in the tires! its getting pretty serious, and i had it aligned recently, but it seemed to just make it worse.
Old 06-27-2008, 06:58 AM   #2
Sucking dick while being Banned
SH-60B can only hope to improve
Re: strange vibrations...
I would look for a wheel balance or bent, then look at the driveline angle. Can you rotate the wheels from back to front? If you do that and the steering wheel stops shaking when you drive straight, then one or both of those wheels are out of balance.
Old 06-27-2008, 08:00 AM   #3
I'll do it tomorrow maybe
terryl's Avatar
terryl has a spectacular aura aboutterryl has a spectacular aura about
Could be an out of round tire. Just jack it up and spin it. Place a stationary object as near the tread as posible and watch for a variance when it spins. Under braking an out of round tire will tind to hop a little. But could be a lot of things. Check your suspension and steering joints.
Old 06-28-2008, 12:58 PM   #4
stayin static
well those can be cancelled out. i just got new tires 2 weeks ago, and they balanced them. these vibrations have been goin on forever, i just thought it was normal really... but its worse now that i have smaller tires. so it could be something more serious? also when i brake sometimes it shakes, and the brake like... lets go i guess. its scarry if i had to brake hard. i really need to figure this out
Old 06-28-2008, 01:33 PM   #5
terryl's Avatar
Whens the last time you changed rotors? It's sounding more and more like a bad out of balance rotor.
Old 06-28-2008, 11:20 PM   #6
stayin static
yea but it vibrates even when i dont brake. it just intensifies when i step on the brake. then when i reach speeds of 50+ it goes away...
Old 06-29-2008, 01:23 AM   #7
terryl's Avatar
If it's bad enough, you could get a shake without applying the brakes. Just a possiblity. You didn't say when the last time you changed or turned your rotors.
Old 06-30-2008, 11:10 AM   #8
stayin static
hm ive never changed the rotors... only the pads. ill look into that next thanks man
Old 06-30-2008, 01:25 PM   #9
mqdff22 is on a distinguished road
I had a similiar problem, except mine would only vibrate when I was moving not braking and it turned out to be a u-joint that was going bad not really sure but you might want to check.
Old 07-17-2008, 04:37 PM   #10
Jayston1 is on a distinguished road
my truck did the wheel hump when i was going 15mph or slower and it was the u-joint
Old 07-18-2008, 04:22 PM   #11
KILLBOY POWERHEAD's Avatar
KILLBOY POWERHEAD is an unknown quantity at this point
yup cut the rotors or replace em
Page generated in 0.13144 seconds with 11 queries
