steering wheel bounces when hitting bumps - S-10 Forum
post #1 of 8 Old 06-02-2009, 05:43 PM Thread Starter
worm's Avatar
User is: worm is offline
Just like the title says. What causes the steering wheel to bounce when hitting bumps in the road? Is it due to worn out parts in the suspension? Can anyone give some info?
worm is offline
post #2 of 8 Old 06-02-2009, 05:53 PM
No longer a pizza tech.
90blueS10's Avatar
User is: 90blueS10 is offline
Re: steering wheel bounces when hitting bumps
i would guess its more steering related than suspension... is it the wheel itself? wiggle the wheel and see if its loose, if its the column there should be two big nuts on the bottom you could tighten or some bolts on the firewall.
Ryan
90 2.5 5 speed, bag project
01 Jimmy 2dr 2wd daily driver
post #3 of 8 Old 06-02-2009, 06:43 PM Thread Starter
worm's Avatar
The steering is nice and tight. It's just when I'm going down the road and hit a bump or going across kinda rough railroad tracks. The steering wheel gets a bump or a jolt in it.
worm is offline
post #4 of 8 Old 06-02-2009, 06:44 PM
90blueS10's Avatar
im not talking about how tight the steering is, im talking if you pull down on the steering wheel does it move at all?
Ryan
post #5 of 8 Old 06-02-2009, 06:51 PM
AWD V8's Avatar
User is: AWD V8 is offline
You need to check everything up front.
Steering shake when hitting a bump can be worn ball joints, tie rod ends, loose control arm bushings, very loose wheel bearings, very loose idler arm, bad shocks, bad tires, bad wheel balance.
A guess, I'd go with shocks, tires or wheel balance.
AWD V8 is offline
post #6 of 8 Old 06-03-2009, 09:20 PM Thread Starter
worm's Avatar
Thanks guys, I'll check all of that.
worm is offline
post #7 of 8 Old 06-03-2009, 11:45 PM
It's "Neanderthal"
SH-60B's Avatar
User is: SH-60B is offline
There is a clamp under the dash too, check those bolts.
Teamsters Local 1150
SH-60B is offline
post #8 of 8 Old 06-10-2009, 12:03 PM
The Eye is watching you!!
kamesama980's Avatar
User is: kamesama980 is offline
Send a message via AIM to kamesama980 Send a message via Yahoo to kamesama980
get new, good shocks if everything else is tight. the steering wheels connected to the wheels and if they're bouncing around all over the place so will the steering wheel.
-Russell
1990 Toyota Cressida 7MGE 3l I6/5-speed manual
1987 S10 2.5 not even power brakes it's so base model
"You don't get to judge me for how I fix what you broke."
read this and obey or face my wrath
