Steering & General Suspension How to's and Useful Threads
tilt column repair how to
Replacing Idler Arm How To Shock Talk Sway Bar Talk Power Performance Steering Linkage Replacement Flaming River U joint steering mod. Last edited by 98layinframe : 03-30-2009 at 09:28 PM. |
Have a nice day!
Re: Steering & General Suspension How to's and Useful Threads
how about the rag joint replacement how to?
got a link to it?
Have a nice day!
make a separate post with pics and i can add it.
What about power steering..........stuff?? I dont have a link thats I posted this.
me got truck
The shock talk link just takes me to the main forum index.The others work okay.
Have a nice day!
power steering info would be nice, i have a ws6 box sitting here and i need a new steering pump
Misses the vette
info on what to do with that pittman arm when upgrading box's would be pretty usefull as well. i have a iroc box sitting in my 'to do box'
Have a nice day!
Misses the vette
i know this, but isnt there something special i need to do to line them up? i know i need to mark the arm. but marking it to line up to the original box isnt going to help much when the box is being replaced.
Have a nice day!
it can go on 4 ways. it's pretty easy to tell which one is right... spin the input shaft until it's halfway between lock to lock, and install the pitman arm straight out from that.
crap
I'd like to add this link. A lot of guys are switching over to
quick ratio box's and Jim Shea has some great info on different box's, hoses, etc. This is for A & F body rides but a Saginaw 600 or 608 [80mm dia bore] will go in. Our box's used to be Saginaw model 800's but are now referred to as model 700's [70mm dia bore] or 708 for bigger rides [80mm dia bore]. I use a model 700 Alpha code YA out of late 80's Monte Carlo SS's and it's worked really well. What one should know for instance is that F body box's will have less pitman arm travel distance and take more effort to turn, where A body box's though allowing more pitman travel in the end, might cause tires to rub on a-arms, etc, so one needs to choose what steer box one wants carefully. I use Open Office to view these articles. I think before one goes changing a steer box to fast ratio, one should know which one might work best for the app. There is a lot of other good info in this link and I hope people here will take a look at some of the articles. http://jimshea.corvettefaq.com/?page_id=5 HTH's. Last edited by bg's : 03-25-2008 at 09:50 AM. |
crap
This has got to be one the most in depth how-to's on
rebuilding a GM steering column I've ever run into. Though it's for a Fiero, it mirrors almost every component of the s-10 column and explains clearly with pics how to go about it.There are a few differences, but will work for the basic rebuild. http://www.fiero.nl/forum/Forum2/HTML/088020.html Last edited by bg's : 05-03-2008 at 01:20 AM. |
Misses the vette
woo, long live pennocks! great bunch of people. in every location.
crap
I'd like to add this info for those thinking about a quick
ratio box and what to use. Should be useful. GM/Saginaw quick-ratio steering box donor car cheat sheet Late Model 12.7:1 quick-ratio gearbox ID markings YA, WS and HX Line Thread Size: M18x1.5 and M16x1.5 Number of Mounting Holes: 3, (missing leg H-pattern) Input Shaft Diameter: ¾-inch Output Shaft Diameter: 1 ¼-inch Number of Turns Lock to Lock: 2 ½ - 3 1984-'88 Monte Carlo/Malibu with Z65 suspension 1983-'88 Malibu, El Camino 1982-'92 Camaro except FE1 soft ride suspension 1984-'87 Regal with FE2 or FE3 sport suspension 1983-'84 Hurst/Olds 1985-'87 Cutlass with 5.0 (VIN code 9) 1982-'85 Trans Am 1986-'92 Firebird except FE1 suspension 1986-'87 Grand Prix with FE2 touring or F41 heavy duty suspension Pre-'76 12.7:1 quick-ratio gearbox Line Thread Size: 11/16 x 18 and 5/8 x 18 Number of Mounting Holes: 4, (H-pattern) Input Shaft Diameter: 13/16-inch Output Shaft Diameter: 1 ¼-inch Number of Turns Lock to Lock: 2 ½ - 3 1967-'76 Camaro, Firebird 1970-'76 Monte Carlo/Malibu 1964-'76 Chevelle 1977-'79 12.7:1 quick-ratio gearbox Line Thread Size: 11/16 x 18 and 5/8 x 18 Number of Mounting Holes: 3, (missing leg H-pattern) Input Shaft Diameter: ¾-inch Output Shaft Diameter: 1 ¼-inch Number of Turns Lock to Lock: 2 ½- 3 1977-'79 Camaro, Firebird 1977-'79 Monte Carlo, Malibu 1977-'79 Chevelle Jeep/S-10 14.0:1 quick ratio gearbox Line Thread Size: M18x1.5 and M16x1.5 Number of Mounting Holes: 3, (missing leg H-pattern) Input Shaft Diameter: ¾-inch Output Shaft Diameter: 1 ¼-inch Number of Turns Lock to Lock: 3 - 3 ½ 1991-'92 Fleetwood 1992-'95 Grand Cherokee 1984-'93 Comanche 1984-'95 Cherokee/Wagoneer 1983-'86 Bonneville 1982-'93 2WD S-10 Blazer and pickup Weatherhead conversion fittings (from your local auto parts store) Part number M41157X6X16 - AN6 male to metric 16 O-ring male Part number M41157X6X18 AN6 male to metric 18 O-ring male Part Number 1446 - female inverted flare thread (5/8-18) to male 16 X 1.5 metric o-ring Part Number 1447 - female inverted flare thread (5/8-18) to male 18 X 1.5 metric o-ring Part Number 1444 - 11/16-18 thread O-ring Male to 5/8-18 female inverted thread adapter HTH's. bg |
yep need we need a new "shock talk" link here also....
aka WickedTaz
shock talk link not working!! |
Re: Steering column mounting to firewall
I just swapped cabs for my S10 went to a 1985 cab and used all the wiring harnesses from the 1993 S10 I had swapped the cab on, getting to the steering column I found that the mounting on the ends of the column are differant, do I need to disassemble both shafts to swap out the end tubes to fix the misallaingment or does some one have an easier way to do it? Im sure someone else has come up with this same situation before, any help would be appreciated thanx,
crap
