Squeak Crack Squeak HELP!!! - S-10 Forum
Old 08-05-2005, 10:42 PM   #1
Spark'n it Up
XtremelyLowRide's Avatar
I replaced all my balljoints and bushings and I still have the creaking noises. WTF?
Is it possible that tie rods can make those sounds?
Old 08-05-2005, 11:32 PM   #2
Hates 'know-it-alls'
Re: Squeak Crack Squeak HELP!!!
is the truck lowered more than factory? if so with what components?
Old 08-06-2005, 03:34 AM   #3
Spark'n it Up
Its bagd.
Old 08-06-2005, 04:30 PM   #4
when you replaced the bushings did you lube them up real good?
Old 08-06-2005, 05:26 PM   #5
WadeoH2o's Avatar
I was in the same boat, it did end up being the Hood Hinge. Sounds crazy but two 13mm wrenches did the trick. I hope u find your problem soon! those frontend noises can be a bitch!!
Old 08-06-2005, 05:41 PM   #6
Also if you have drop spindles and didn't trim the dustshields, that could be where the squeaking is coming from.
Old 08-07-2005, 01:13 AM   #7
Dragging Oil Pan!
jchargu3's Avatar
Brad...
Whilst under my truck drilling into the heads... I discovered something...
Check the tightness of the bolts that go throught he Upper Control Arm, theres one nut on either side, 22 or 24mm i believe...
I tightened them, by by creak (besides the coil spring creak)
Old 08-07-2005, 12:13 PM   #8
Spark'n it Up
Quote: Originally Posted by jchargu3
Brad...
I must try this..... I'll tell yall if thats what it was.
Old 08-08-2005, 04:38 PM   #9
Spark'n it Up
I had to pick up the upper CA to grease under it and basically the whole front end. I think this will only be a temp fix though if it was the upper CA.
