s-10 pulls to the right - S-10 Forum
post #1 of 11 Old 04-13-2008, 07:24 PM Thread Starter
skylarkmk's Avatar
User is: skylarkmk is offline
HI,
My 1994 4x4 s10 has 100,000 miles on it and it is pulling to the right. Tires are in good shape, brakes are not grabbing, and it has just been aligned. What could be causing it?
post #2 of 11 Old 04-13-2008, 08:38 PM
The Eye is watching you!!
kamesama980's Avatar
User is: kamesama980 is offline
Send a message via AIM to kamesama980 Send a message via Yahoo to kamesama980
Re: s-10 pulls to the right
most likely: tire inflation, uneven tire wear (rotate them and see what happens)
alignment (unless the place is good, there's a lot of tolerlance), brakes dragging (takes a lot less than you think), wheel bearings
-Russell
1990 Toyota Cressida 7MGE 3l I6/5-speed manual
1987 S10 2.5 not even power brakes it's so base model
"You don't get to judge me for how I fix what you broke."
read this and obey or face my wrath
post #3 of 11 Old 04-13-2008, 09:10 PM Thread Starter
skylarkmk's Avatar
hmmm,
A wheel bearing can cause a vehicle to pull? I never new that, that may be my problem.
thank you
post #4 of 11 Old 04-13-2008, 09:33 PM
s-series #2?
greencactus3's Avatar
User is: greencactus3 is offline
if steering components or sus components are worn, an alignment wont do anything. it will jump right back out of alignment.
of course, a good honest shop would not have aligned it if they noticed worn components, but sadly, most shops tend not to be
post #5 of 11 Old 04-13-2008, 09:45 PM
1996S10's Avatar
User is: 1996S10 is offline
Check and see if the wheel is vertical lined. It may be leaning in ward that will make it pull bad. Check the control arm for bad bushings.
1996S10 is offline
post #6 of 11 Old 04-13-2008, 10:49 PM
Molon Labe
BudRacing's Avatar
User is: BudRacing is offline
Send a message via AIM to BudRacing
It's probably a worn idler arm.
post #7 of 11 Old 04-14-2008, 01:06 PM
a.graham52's Avatar
User is: a.graham52 is offline
Send a message via MSN to a.graham52 Send a message via Yahoo to a.graham52
Originally Posted by skylarkmk View Post
HI,
whats really funny is.... MINE DOES THE SAME THING. same miles, year, but mines 2x4
post #8 of 11 Old 04-14-2008, 10:20 PM
User is: pfallone001 is offline
Road Crown??? Or have the front end checked. (ie Balljoints, idler/pitman, tierod ends, bushings, wheel hub assy or bearings loose? tire problem causing the pull? there are several different scenarios for a pull, these are most common however
post #9 of 11 Old 04-15-2008, 12:05 AM
User is: Word is offline
Mine pulls to the right too, and has done so for as long as i remember, it's a '99 s10 has 186000 miles on it. I dont think it's really gotten worse but the suspension, brakes and tires have all been replaced along the way so the problem is probably elsewhere. But for some reason my older brother's '98 s10 with 230k on it doesn't have any problems. Although i believe he's replaced his bushings and done something to his wheel bearings (he likes to fiddle ;p).
Another note, be careful because if yours has the same issue as mine, it'll pull to the right until you need to slam on the brakes, then since you're compensating left, it'll swerve left, not fun...i guess that might suggest it could be the brakes...but meh..
Word is offline
post #10 of 11 Old 04-15-2008, 12:53 AM
Molon Labe
BudRacing's Avatar
I'm 90% sure it's probably worn steering linkages. Check those out first.
post #11 of 11 Old 04-15-2008, 12:57 AM
Supa
Gushers's Avatar
User is: Gushers is offline
When my brother owned my 94 it was the idler arm and a few other front suspension things... I can't remember what else though. then after that was replaced an alignment fixed it. Good luck
Matt
sold.
Gushers is offline
