poping noise and cant figure out there is nothing els to replace eveyrhting is tight
Old 07-03-2008, 09:09 PM   #1
PimpingA1997Jimmy is an unknown quantity at this point
OK i have a popping noise coming when i have the wheel cut all the way to the right
I thought it was the idler arm because it was the last thing that was loose i don't understand what els could be the problem the axle was replaced a month ago ball joint before that everything is tight under there there nothing els is loose what could the problem be ?
Old 07-04-2008, 08:42 AM   #2
Polished off two tires
yellonoma_ss's Avatar
yellonoma_ss is on a distinguished road
Re: poping noise and cant figure out there is nothing els to replace eveyrhting is ti
I assume the popping is while in motion, is it when you are going over a bump when the wheel is turned to the right or otherwise.
On my 2WD I had a problem with my front swaybar being a bit loose and beat out, but it sounds like you have a 4x4. You checked the hood hinges for loose-ness?
There are quite a few threads you can search on front end popping noises that might help you out if you haven't already.
Old 07-04-2008, 09:40 AM   #3
I went into a empy parking lott cut teh wheel all the way to the left and just put my foot on the gas and drove in a circle a couple times and heard the popping
the wheel has to be cut all the way to the right not just part of the way but all of the way to the right
it use to do it the same way in revers but that stoped when i repalced the passanger front axle but it doesnt hapen when i turn the will a little it has to be all the way to the right and and have to be moving like a full circle and it sound like a popping clunking noise
Old 07-06-2008, 07:51 PM   #4
guess this is a hard one yikes no one can help
Old 07-08-2008, 10:55 PM   #5
jwood562's Avatar
jwood562 is on a distinguished road
ball joints or tie rod ends?
Old 07-09-2008, 09:43 AM   #6
simple man
5timedime's Avatar
5timedime is on a distinguished road
pics of the truck would help. maybe a tire rubbing?
Old 07-09-2008, 12:03 PM   #7
Senior Member
Power Performance is on a distinguished road
ball joint
Old 07-09-2008, 03:47 PM   #8
blown snowplow
rentedmule's Avatar
rentedmule is on a distinguished road
I still have that exact problem after a brand new steering linkage, steering box, idler arm, and a different swaybar setup and my balljoints were perfect according my mechanic. The thing I've heard suggested in other threads is control arm bushings.
Old 07-12-2008, 01:06 PM   #9
onebad43's Avatar
onebad43 is on a distinguished road
mine pops really loud..but i figured out what mine was..when i turned to the left a bit it popped and when i hit a bump it but i rocked the truck back and forth one day and my buddy looked under there..well it was my torsion bar crossmember smacking the shit out of my frame...but i havent fixed it..but i know thats what it is..
Old 07-18-2008, 09:15 AM   #10
the ball joints where just replaced on the passanger side but the ones on the drivers side are older but not that bad
not sure about the tire rod ends the axle was just replaced and so was the idler arm
Old 07-20-2008, 03:29 PM   #11
gadget73's Avatar
gadget73 is on a distinguished road
"not that bad" has a lot of room for wiggle. I consider any movement at all in a ball joint bad. Other people consider it not that bad till it fall out of the socket. I'm also generally of the theory that if one side was bad, the other side is shot too just because its got the same mileage on it. Pump it up with grease and see if the noise goes away. If it does, replace the ball joint. Also, how are you checking the ball joints? They cant be checked properly unless the suspension is loaded. Put a jack under the lower control arm and pick the wheel off the ground. See if there is any movement that way. If you check it with the suspension at full droop, the joints will be loaded by the spring or torsion bar and you won't be able to tell if they're shot.
Page generated in 0.14163 seconds with 12 queries
