Need some help putting together front suspension
Old 10-18-2009, 08:40 PM   #1
Im setting out to rebuild my front suspension once again and this time I am wanting to spend a bit more time researching than last and do it a little better.
I have a 95 2dr 2wd blazer.
It currently has 5" drop upfront and needless to say, the geometry is all messed up. The inside of the tires are gone within a few 1000 miles. Alignment does not help. Apperently, Firestone, the only shop that would align it around here, where i have a life-time alignment pass, will only align it to stock specification which doesnt do much due to 5" drop. I really don't know what numbers I should be using, so I cant ask them to adjust it. In addition, I've been very dissapointed with ES bushings i have installed a year or 2 ago. In addition to horrible squeak, the truck feels like it's missing suspension upfront and just rides on bumpstops. I know i cant ask for alot with my drop, but I am wanting to make it the best I possibly could.
Here is what Im wanting to do.
Upgrade to 98+ blazer spindle with 2" drop for dual piston calipers.
qa1 with probably max setting to maintain 4-5" drop upfront.
Del-a-lum bushings in stock lca's
Tubular uca's w/ del-a-lum's
Now here are my questions.
Would I benefit from using tall upper ball joint?
Would I be able to correct my geometry with unadjustable uca? or would I benefit more from the adjustable ones?
Are spohn uca's a good choice?
Does anyone happen to know what would be a good start for my alignment specifications to at least get the tires flat on the asphalt to begin with?
With del-a-lum's do you simply drill a hole in the control arms for zirk grease fitting?
Old 10-20-2009, 02:57 PM   #2
turbobandit's Avatar
Re: Need some help putting together front suspension
allignment to stock specifications is what you want. STOCK means the tire is straight up and down (no camber), and caster is like toe-in toe-out. You want a degree or two of toe in.
Something is limiting you to how far your allignment is being adjusted
Old 10-27-2009, 01:25 AM   #3
How Did you drop it 5 inches? what parts did you change??? 5 inches you should have changes spindles, springs, control arms.
Sound like you use a much smaller spring to get you drop, did you even change the spindle???
Old 10-27-2009, 08:39 PM   #4
That's really not the issue I was asking about here, but spindles and 3" springs= 5" drop.
Old 10-27-2009, 08:51 PM   #5
Yeah, I've been meaning to check the printout from the last time I had it alligned, but have not gotten around to it. I think the shop might not have done it right. Wouldnt surprize me since it was firestone... I'm hearing that0-neg 1* camber and 1/16 toe in is a pretty compromizing combination. So I will try that out next time.
Old 10-27-2009, 09:21 PM   #6
Your spring is too small. I attempted the same drop and was able to remove the spring without removing the spindle. It was sitting in there and not supporting any weight of the truck. You should switch to a 2 in spring or stock spring and new lower controll arms. .
Old 10-27-2009, 09:21 PM   #7
Old 10-28-2009, 03:08 PM   #8
if it was too small and did not support any weight, my inner fenders would be sitting on top of my tires, which is not the case.
Page generated in 0.56072 seconds with 31 queries
[Output: 66.92 Kb. compressed to 63.22 Kb. by saving 3.71 Kb. (5.54%)]
