My truck pulls to the right. - S-10 Forum
post #1 of 14 Old 11-03-2008, 02:37 PM Thread Starter
ɔıɹɔ&
circa's Avatar
User is: circa is offline
My truck has pulled to right ever since i got it.
It is really annoying.
My front right caliper is always a bitch to get off and on. Anyone else ever have this problem?
I have changed calipers (front right seized), rotors, spindles steering linkages and bearings.
Dropped it 5/6 got an alignment and still pulls to the right.
It's not a hard pull to the right but a slight one.
circa is offline
post #2 of 14 Old 11-03-2008, 02:39 PM
I SHIT BRICKS
OneLowSdime's Avatar
User is: OneLowSdime is offline
Send a message via AIM to OneLowSdime Send a message via Yahoo to OneLowSdime
Re: My truck pulls to the right.
they are factory to pull to the right only for the fact of if u fall asleep behind the wheel the right will take u into a ditch.............. lol but check balljoints
post #3 of 14 Old 11-03-2008, 02:54 PM
s-series #2?
greencactus3's Avatar
User is: greencactus3 is offline
unless you are really dragging the brakes it would be a camber/caster issue. do you have a readout from when you got the alignment?
post #4 of 14 Old 11-03-2008, 04:15 PM Thread Starter
ɔıɹɔ&
circa's Avatar
not on hand, im at work.
balljoints were not the greatest i have seen but no where near being trashed
circa is offline
post #5 of 14 Old 11-07-2008, 04:40 AM
'02 Sonoma X-Cab
actafool4187's Avatar
User is: actafool4187 is offline
Send a message via AIM to actafool4187
alignment maybe?
Check out midwestminis.net
post #6 of 14 Old 11-07-2008, 11:08 AM
Bringindanois's Avatar
User is: Bringindanois is offline
Check Your suspension for any play, and make sure your camber/caster are within spec.
2002 4.3l 4x4
post #7 of 14 Old 11-07-2008, 05:27 PM
Certified Slacker
beat-ol truck's Avatar
User is: beat-ol truck is offline
just because your camber/caster are in spec, does not mean that they wont cause a slight pull. If you have a printout of your alignment, im sure someone could help diagnose if it is an alignment issue.
Have you rotated the tires at all??
This is my signature.
post #8 of 14 Old 11-08-2008, 10:19 PM
Those crazy ass dogs!!!
01cherryreds10's Avatar
User is: 01cherryreds10 is offline
Check the left brake line going to the caliper? It may be kinked.
01' Ext.Cab sold and dont miss it
79' Malibu LQ4/4L70e 11.23@118 1.50 60'
07' Silverado 1500 Classic
post #9 of 14 Old 11-10-2008, 02:47 AM Thread Starter
ɔıɹɔ&
circa's Avatar
tires are all new, lines appear perfect.
I will get the readout in the morning, it's buried in the truck somewhere.
circa is offline
post #10 of 14 Old 11-10-2008, 06:13 PM Thread Starter
ɔıɹɔ&
circa's Avatar
Bad numbers are from the new steering linkages and a shaky at home alignment haha
circa is offline
post #11 of 14 Old 11-11-2008, 02:01 PM
Certified Slacker
how drastic of a pull is this, and are you sure it is not just an offset steering wheel?
0.6 cross caster CAN cause a pull, but I dont think it would be a significant pull.
post #12 of 14 Old 11-11-2008, 02:17 PM Thread Starter
ɔıɹɔ&
circa's Avatar
its a very slight pullto the left, when i slight turn to the right the steering wheel has tension as if something is binding a little. but there is nothing to bind up
circa is offline
post #13 of 14 Old 11-16-2008, 02:24 PM
Thanks For Your Support
terryl's Avatar
User is: terryl is offline
Do you mean pull to the right? You said right before. If it is a pull to the right, it could be the fact that almost all roads have a slight lean to the right. This will cause a drift to the right. Could that be your problem? If so, you don't have a problem. You can also try swapping the front tires with each other to see if that makes any differrence. Make sure air the pressure is the same in each tire.
02 Black S-10 Xtreme ext. cab 4.3, additional 2/2.5 drop and a bunch of other stuff
terryl is offline
post #14 of 14 Old 11-17-2008, 09:18 AM
User is: ahartz28 is offline
looking at the you printout you have too much camber on the left side you should have it closer to 0* or a positive on the left side..also your caster is higher on the left which is not within spec or even close!
just because your tires are new doesnt mean they will not cause a radial pull either.. i would get the alignment redone it looks like they didnt know what they were doing or they dont like doing the shim adjustments..no one does
ahartz28 is offline
