Looking for tubular upper control arms for a 4X4 - S-10 Forum
Old 08-17-2009, 02:23 PM   #1
AWD V8's Avatar
Title says it all.
I've search the net and only found them for 2wd.
I'm looking for lighter weight & more turning clearance for my C5 wheels.
Any ideas??
Old 08-17-2009, 09:37 PM   #2
Re: Looking for tubular upper control arms for a 4X4
Superlift and Rough Country sell them as part of their 2" lift kit. You might have to buy the whole kit and just use the control arms. Also, I think that Synergy Offroad sells just the control arms.
Old 08-17-2009, 10:13 PM   #3
AWD V8's Avatar
Rough Country
Upper control arms with a newly redesigned ball joint mounting location [Improves ball joint operating angle]
Likely NOT suitable for a lowered truck, angles would work against me.
Superlift
Doesn't say what their arms are but likely the same deal.
Also I'm needing more clearance for my wide wheels. I may just have to make them myself. <sigh>
Thanks
Old 08-17-2009, 10:30 PM   #4
**** New Jersey
Tim99Zr2's Avatar
2wd ones wont work?
Old 08-18-2009, 01:04 AM   #5
AWD V8's Avatar
Quote: Originally Posted by Tim99Zr2
2wd ones wont work?
I know, bummer
Old 08-18-2009, 07:28 AM   #6
Sold
Twin-10s's Avatar
you try http://www.syty.org/ sure they would have more info for you.
Old 08-18-2009, 01:11 PM   #7
AWD V8's Avatar
Thanks, I've looked there and not found anything.
Old 08-18-2009, 02:58 PM   #8
Sold
Twin-10s's Avatar
check out http://www.jsmanufacturing.com/
Old 08-18-2009, 04:15 PM   #9
AWD V8's Avatar
Yes a complete coil over suspension would be sweet.
I'll start busting my piggy bank open this afternoon.
Was hoping for some sort of a half way point on this. Guess I'll just have to bite the bullet on this and go all or nothing.
Old 08-18-2009, 06:05 PM   #10
Under construction
he will sell you just the upper arms if you want
Old 08-18-2009, 06:08 PM   #11
AWD V8's Avatar
I'll look into that.
Old 08-20-2009, 12:37 PM   #12
992drjimmy's Avatar
You are right the superlift or roughcountry arms will work against you on the angles.
Old 08-27-2009, 03:20 PM   #13
GRM Challenge Truck
call tony at ub machine. he custom made a set of uppers for a tall ball joint swap on a 2wd that he now sells, and may be able to help you out for about 150-200 bucks.
hope that helps. tell him michael crawford at hellbilly hotrods sent you.
Old 08-27-2009, 06:04 PM   #14
AWD V8's Avatar
I'll check that out, thanks
